    Configuration problems
    Firmware installation
    2.1k
    • Dave Parryundefined
      Dave Parry
      I have moved from a old duet 0.8.5 to a duet 2 ethernet. Used the configuration tool and the tweeked some of the parameters to match my old config file.
      I have a couple of problems with the web control
      1 problem with the temp settings is that the hot end it wont show as active. It goes from off to standby but not active.
      Also if I set a temp in standby I cant stop it until it reaches that temp (except emergency stop).
      I also sometimes get "generic.heaterStates.disconnected "
      The bed temp wont show anything other than "generic.heaterStates.disconnected " If I set a temp under active dropdown menu and then click on Bed it does sometimes start heating and show standby but not always.
      Other thing I get is I have a extra bed cooling fan configured and when the software starts the fan momentarily starts on high and the goes to 0.
      I have also just noticed that if I click on either temp on the panel due it goes from red to yellow and the web control shows standby or off.
      Anyone have any Idea what is wrong with my config?
      Config.g
      ; Configuration file for Duet 0.8.5 (firmware version 1.21)
      ; generated by RepRapFirmware Configuration Tool v3.3.2 on Thu Sep 02 2021 19:22:19 GMT+0100 (British Summer Time)
      M550 P"MiniKossel" ; set printer name
      M665 R105.6 L217.29 B85 H250 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X-26.2 Y-26.2 Z-26.4 ; put your endstop adjustments here, or let auto calibration find them
      M540 XXX:XX:XX:XX:XX:XX ; set custom MAC address
      M552 P192.168.x.xxx S1 ; enable network and set IP address
      M553 P255.255.255.0 ; set netmask
      M554 P192.168.x.x ; set gateway
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X20000.00 Y20000.00 Z20000.00 E3600.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E450 I60 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z-0.1 S1 ; set minimum Z
      M574 X2 Y2 Z2 S1 ; set active high endstops
      M558 P1 H10 F120 T2400 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z1.73 ; set Z probe trigger value, offset and trigger height
      M557 R85 S20 ; define mesh grid
      M305 P0 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4388 R4700 ; set thermistor + ADC parameters for heater 1
      M106 P0 S0 I0 F500 H-1 C"Part Clg" ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S0 I0 F500 H-1 C"Bed Clg" ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      JawsN3Dundefined 1 Reply Last reply Reply Quote 0
      • JawsN3Dundefined
        JawsN3D @Dave Parry
        @dave-parry
        Yeah it appears you need to convert your heater and end stops to the proper rrf 3.0+ syntax unless you go to v 2.03/2.05
        A few things have changed...
        M305 is no longer used
        Self designed/waterjet/built enclosed 800x360x725 Cartesian machine.
        Duet2/duex5, Moons, Hemera
        Rpi4 as Fire Sentinel with 110v contactors.
        Everything but the kitchen sink....
        ...much like our Twin engine Oldsmobile...
          Dave Parry
          Thanks, I did use the latest config tool so would have thought it would be correct. Will see if I can sort it out.
          • JawsN3Dundefined
            JawsN3D @Dave Parry
            @dave-parry
            I'm on my phone and can't post my config. But in the post adjacent to yours mentioning print finished.....You can look at my config of the end stops for a refrence
            Edit. If you look at the first post config. G you will see I left all of my earlier 2.03 syntax settings and configurations but they are commented out. That was from all of my work converting to the new system and it might prove helpful for you as it has for me. The config. G lower on in the thread is after I did some house cleaning got rid of all of the extraneous lines
              Dave Parry
              Cant seem to get the config correct Keep getting unknown channel.
              Old config was
              Have tried various settings
              latest one was
              M308 S0 P"e0temp" Y"thermistor" T100000 B4725 ; configure sensor 1 as thermistor on pin e0temp
              M950 H0 C"e0temp" T0
              get Error: Temperature reading fault on heater 1: unknown temperature sensor channel
              also tried
              M308 S0 P"e0temp" Y"thermistor" T100000 B3950 ; define E0 temperature sensor
              M950 H0 C"e0heat" T0 ; heater 1 uses the e0heat pin and sensor 1
              • fcwiltundefined
                fcwilt @Dave Parry
                @dave-parry said in Configuration problems:
                Old config was
                latest one was
                also tried
                You are showing code for heater 0 but the error is for heater 1.
                What is the code for heater 1?
                Frederik
                  Dave Parry
                  here's the code for both
                  M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 ; define bed temperature sensor
                  M308 S1 P"e0temp" Y"thermistor" T100000 B4388 ; define E0 temperature sensor
                  M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
                  M950 H1 C"e0heat" T1 ; heater 1 uses the e0heat pin and sensor 1
                  Still have error heater 1
                  both still showing 2000 °C
                  Just changed back to old settings and temps are correct so not a sensor problem.
                  • fcwiltundefined
                    fcwilt @Dave Parry
                    Thanks.
                    What do you mean by "changed back to old settings"?
                      Dave Parry
                      I checked the sensors by removing M308 and M960 lines and put back M305 lines. and the sensor readings were back and correct.
                      • fcwiltundefined
                        fcwilt @Dave Parry
                        What firmware version are you running?
                          Dave Parry
                          WiFi/Ethernet 2.05.1 (2020-02-09b1)
                          (Thought I had upgraded to Release 3.4.0 beta 3
                          but it seems that for some reason it hasn't worked.)
                          Duet Web Control 3.3.0
                          Will try again
                            Dave Parry
                            Just tried again and the machine specific tab still says 2.05
                            • fcwiltundefined
                              fcwilt @Dave Parry
                              Will try again
                              Remember that you have to first go from 2.05.1 to 3.0.0
                                Dave Parry
                                Tried 3.1 combined.bin Cant seem to upload it.
                                • fcwiltundefined
                                  fcwilt @Dave Parry
                                  3.1?
                                  So you got it up to 3.0 already?
                                    Dave Parry
                                    No I hadnt but have now. When I looked down the list 3.1 was above 2.05 and 3.0 was below and I didnt see it.
                                    fcwiltundefined 1 Reply Last reply Reply Quote 1
                                    • fcwiltundefined
                                      fcwilt @Dave Parry
                                      You now should be able to go to 3.3.0 or (if you ok with betas) to 3.4.x.
                                        Dave Parry
                                        Thanks Frederick.
                                        Cant get 3.4 to install. Get Error: In-application programming binary "Duet2CombinedIAP.bin" not found
                                        Temps are working now but still have problem that cant set heaters to active
                                        Have tried all the way back to 3.2. Same error message
                                          Dave Parry
                                          Got it done now at WiFi/Ethernet 3.4.0beta3 (2021-08-24)
                                          • fcwiltundefined
                                            fcwilt @Dave Parry
                                            This post is deleted!
