    Toolhead Calibration Values Changing
    My Duet controlled machine
    • eyperry
      eyperry last edited by
      Hi, I was wondering if I could get some help. I have been following the toolchange calibration process in this video: https://www.youtube.com/watch?v=37thDl6TVnw.
      Once I completed the process and ran the toolchange_test.gcode. This worked the first time. I then ran it a second time and the toolhead moved backwards with the E3 extruder still attached.
      I noticed that the coupler was no longer horizontal, and no longer vertical.
      I homed the machine again and then modified the C values for the angle of the coupler for unlock and lock in the Coupler-lock and Coupler-unlock macros. I homed the machine again and I get a nice horizontal homed position.
      I repeated the process for my E0 extruder and I am finding the same problem - the unlock is no longer horizontal and the toolhead removes the E0 extruder with it.
      I was wondering if I could get some help? I am not sure if maybe I have done something wrong, and after repeating the process a few times now I am at a loss.
      Thanks in advance for your help.
      Best,
      Emma
        Can you post the results of M122 and M98 P"config.g" along with your config.g please? Possibly also your homing and tool change files?
        eyperry 2 Replies Last reply Reply Quote 0
        • eyperry
          eyperry @Phaedrux last edited by
          @phaedrux
          Hi thank you for getting back to me. When I run M98 P'config.g' it tells me there is no macro file even though there is one in the list of files. If i run M98 Pconfig.g it resets the wifi access point and the access point does not work anymore. So I have to roll back to older files.
          The result of M122 is:
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
          Board ID: 08DLM-996RU-N8PS4-6J9F4-3S86N-1AUZN
          Used output buffers: 3 of 24 (17 max)
          Static ram: 23876
          Dynamic ram: 77720 of which 0 recycled
          Never used RAM 12820, free system stack 184 words
          Tasks: NETWORK(ready,13.7%,237) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,319) DUEX(notifyWait,0.0%,24) MAIN(running,85.8%,395) IDLE(ready,0.4%,29), total 100.0%
          Owned mutexes:
          Last reset 00:01:44 ago, cause: power up
          Last software reset details not available
          Error status: 0x00
          Step timer max interval 0
          MCU temperature: min 32.2, current 33.1, max 33.7
          Supply voltage: min 24.2, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max not available
          Driver 1: position 0, standstill, SG min/max not available
          Driver 2: position 0, standstill, SG min/max not available
          Driver 5: position 0, standstill, SG min/max not available
          Driver 6: position 0, standstill, SG min/max not available
          Driver 7: position 0, standstill, SG min/max not available
          Driver 8: position 0, standstill, SG min/max not available
          Driver 9: position 0, standstill, SG min/max not available
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2021-09-07 11:44:58
          Cache data hit count 3837611636
          Slowest loop: 20.74ms; fastest: 0.17ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.8ms, write time 6.4ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === DueX ===
          Read count 0, 0.00 reads/min
          === Network ===
          Slowest loop: 201.72ms; fastest: 0.09ms
          Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi module is providing access point
            Failed messages: pending 0, notready 0, noresp 1
            WiFi firmware version 1.23
            WiFi MAC address f6:cf:a2:66:49:81
            WiFi Vcc 3.42, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 23264
            WiFi IP address 10.22.99.163
            Connected clients 1
            Clock register ffffffff
            Socket states: 4 0 0 0 0 0 0 0
          My config file is:
          ; Configuration file for Duet WiFi / Ethernet running RRF3 on E3D Tool Changer
          M111 S0 ; Debugging off
          G21 ; Work in millimetres
          M550 P"ToolChanger" ; Set machine name
          ;M587 S"ssid" P"password" ; WiFi Settings
          ;M552 S1 P"ssid" ; Enable WiFi Networking
          M552 S1 ; Enable Networking
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          M667 S1 ; Select CoreXY mode
          ; Drive direction
          M569 P0 S0 ; Drive 0 X
          M569 P1 S0 ; Drive 1 Y
          M569 P2 S1 ; Drive 2 Z
          M569 P3 S0 ; Drive 3 E0
          M569 P4 S0 ; Drive 4 E1
          M569 P5 S1 ; Drive 5 E2
          M569 P6 S1 ; Drive 6 E3
          M569 P7 S0 ; Drive 7 COUPLER
          M569 P8 S0 ; Drive 8 UNUSED
          M569 P9 S0 ; Drive 9 UNUSED
          M584 X0 Y1 Z2 C7 E3:4:5:6 ; Apply custom drive mapping
          M208 X-35:328.5 Y-49:243 Z0:300 C0:500 ; Set axis maxima & minima
          M92 X100 Y100 Z1600 C200 E834:834:834:834 ; Set steps per mm assuming x16 microstepping
          M350 E16:16:16:16 I1 ; Configure microstepping with interpolation
          M350 C16 I10 ; Configure microstepping without interpolation
          M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
          M566 X400 Y400 Z8 C2 E2:2:2:2 ; Set maximum instantaneous speed changes (mm/min)
          M203 X35000 Y35000 Z1200 C10000 E5000:5000:5000:5000 ; Set maximum speeds (mm/min)
          M201 X6000 Y6000 Z400 C500 E2500:2500:2500:2500 ; Set accelerations (mm/s^2)
          M906 X1800 Y1800 Z1330 C400 I30 ; Idle motion motors to 30%
          M906 E1000:1000:1000:1000 I10 ; Idle extruder motors to 10%
          M574 X1 Y1 S3 ; Set X / Y endstop stall detection
          M574 Z0 ; No Z endstop
          M574 C1 S3 ; Stall detect coupler at low end of its range
          ; Z probe
          M558 P8 C"zstop" H3 F360 I0 T20000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
          G31 P200 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
          M557 X10:290 Y20:180 S40 ; Define mesh grid
          ;Stall Detection
          M915 C S6 F0 H200 R4700 ; Coupler
          ;Stall Detection
          M915 X Y S3 F0 H400 R4700 ; X / Y Axes
          M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4138 C0 ; Set thermistor
          M950 H0 C"bedheat" T0 ; Bed heater
          M143 H0 S225 ; Set temperature limit for heater 0 to 225C
          M140 H0 ; Bed heater is heater 0
          M308 S1 P"e0temp" Y"thermistor" A"T0" T100000 B4725 C7.06e-8 ; Set thermistor
          M950 H1 C"e0heat" T1 ; Extruder 1 heater
          M143 H1 S305 ; Set temperature limit for heater 1 to 300C
          M308 S2 P"e1temp" Y"thermistor" A"T1" T100000 B4725 C7.06e-8 ; Set thermistor
          M950 H2 C"e1heat" T2 ; Extruder 2 heater
          M143 H2 S305 ; Set temperature limit for heater 2 to 300C
          M308 S3 P"e2temp" Y"thermistor" A"T2" T100000 B4725 C7.06e-8 ; Set thermistor
          M950 H3 C"duex.e2heat" T3 ; Extruder 3 heater
          M143 H3 S305 ; Set temperature limit for heater 3 to 300C
          ; M308 S4 P"e3temp" Y"thermistor" A"T3" T100000 B4725 C7.06e-8 ; Set thermistor
          ; M950 H4 C"duex.e3heat" T4 ; Extruder 4 heater
          ; M143 H4 S305 ; Set temperature limit for heater 4 to 300C
          M563 P0 S"T0" D0 H1 F2 ; Define tool 0
          G10 P0 X0 Y0 Z0 ; Reset tool 0 axis offsets
          G10 P0 R0 S0 ; Reset initial tool 0 active and standby temperatures to 0C
          M563 P1 S"T1" D1 H2 F4 ; Define tool 1
          G10 P1 X0 Y0 Z0 ; Reset tool 1 axis offsets
          G10 P1 R0 S0 ; Reset initial tool 1 active and standby temperatures to 0C
          M563 P2 S"T2" D2 H3 F6 ; Define tool 2
          G10 P2 X0 Y0 Z0 ; Reset tool 2 axis offsets
          G10 P2 R0 S0 ; Reset initial tool 2 active and standby temperatures to 0C
          M563 P3 S"T3" D3 H4 F8 ; Define tool 3
          G10 P3 X0 Y0 Z0 ; Reset tool 3 axis offsets
          G10 P3 R0 S0 ; Reset initial tool 3 active and standby temperatures to 0C
          M950 F1 C"fan1"
          M950 F2 C"fan2"
          M950 F3 C"duex.fan3"
          M950 F4 C"duex.fan4"
          M950 F5 C"duex.fan5"
          M950 F6 C"duex.fan6"
          M950 F7 C"duex.fan7"
          M950 F8 C"duex.fan8"
          M106 P1 S255 H1 T70 ; T0 HE
          M106 P2 S0 ; T0 PCF
          M106 P3 S255 H2 T70 ; T1 HE
          M106 P4 S0 ; T1 PCF
          M106 P5 S255 H3 T70 ; T2 HE
          M106 P6 S0 ; T2 PCF
          ; M106 P7 S255 H4 T70 ; T3 HE
          ; M106 P8 S0 ; T3 PCF
          M593 F50 ; cancel ringing at 50Hz (https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/)
          ;M376 H15 ; bed compensation taper
          ;tool offsets
          ; !ESTIMATED! offsets for:
          ; V6-tool: X-9 Y39 Z-5
          ; Volcano-tool: X-9 Y39 Z-13.5
          ; Hemera-tool: X-37.5 Y43.5 Z-6
          G10 P0 X-9 Y39 Z-5.062 ; T0
          G10 P1 X-9 Y39 Z-5.039 ; T1
          G10 P2 X-9 Y39 Z-13.5 ; T2
          G10 P3 X-1.5 Y37.9 Z-38.21 ; T3
          ; ;;;;;;; Y40.4????
          ;deselect tools
          T-1
          ;M572 D0 S0.2 ; pressure advance T0
          ;M572 D1 S0.2 ; pressure advance T1
          ;M572 D2 S0.2 ; pressure advance T2
          ;M572 D3 S0.2 ; pressure advance T3
          M501; load config-override.g
          M98 P"/macros/define_glob.g"
          ; Added by Soph to create access point
          M98 P"accesspoint.g"
          Example E0 toolchange file:
          ; tpre0.g
          ; called before tool 0 is selected
          ;Unlock Coupler
          M98 P"/macros/Coupler - Unlock"
          ;Move to location
          G1 X-13.5 Y200 F50000
          ;Move in
          G1 X-13.5 Y220 F50000
          ;Collect
          G1 X-13.5 Y226.5 F2500
          ;Close Coupler
          M98 P"/macros/Coupler - Lock"
          ;WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING!
          ;if you are using non-standard length hotends ensure the bed is lowered enough BEFORE undocking the tool!
          G91
          G1 Z10 F1000
          G90
          ;Move Out
          G1 X-13.5 Y150 F4000
          The homing files I have are the ones from the rrf3 - I modified the angle on in the lock and unlock Coupler macros to ensure that the toolchanger bar is horizontal and vertical for unlock and lock positions (as before they were slightly offset with the angles used inthe original macro).
          I hope this clarifies and thank you again for taking a look at this!
          Best,
          Emma
          • eyperry
            @phaedrux Hi, I was wondering if you have had a chance to look at the files I have shared below? I would be really grateful for your further help as I am still facing this problem. Thank you again for your further time and assistance. Best, Emma
              Sorry for missing your reply on this. It came right before I took an absence. Were you able to resolve your issue?
