    Warning: M500: No M501 command was executed in config.g
    Firmware installation
    640
    • Dave Parryundefined
      Dave Parry
      I am trying to calibrate the home height on my Mini Kossel delta with a duet 2 Ethernet and Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta3 (2021-08-24) .
      It was working fine then all of a sudden it hit the bed when starting a print.
      I have been going through the dozuki for doing this (which I've done before) up to setting the Z=0 and probe trigger height, but when I send M500 to save the values it comes back with the message "Warning: M500: No M501 command was executed in config.g" even though there is one there. Tried rebooting power cycling on/off still the same.
      When I test H height again it is wrong again.
      Am I missing something?
        Phaedrux Moderator @Dave Parry
        @dave-parry said in Warning: M500: No M501 command was executed in config.g:
        Can you please provide the results of M122 and M98 P"config.g" and post your config.g?
          Dave Parry
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta3 (2021-08-24 13:56:10) running on Duet Ethernet 1.02 or later
          Board ID: 0JD0M-9P6M2-NWNS4-7J1DA-3SJ6M-TA2ZK
          Used output buffers: 3 of 24 (22 max)
          Static ram: 23940
          Dynamic ram: 69944 of which 0 recycled
          Never used RAM 18196, free system stack 190 words
          Tasks: NETWORK(ready,26.4%,247) HEAT(notifyWait,0.0%,310) Move(notifyWait,0.0%,364) MAIN(running,73.4%,445) IDLE(ready,0.2%,29), total 100.0%
          Owned mutexes:
          Last reset 00:00:45 ago, cause: software
          Last software reset at 2021-09-11 12:12, reason: User, GCodes spinning, available RAM 18196, slot 1
          Error status: 0x00
          Aux0 errors 0,0,0
          Step timer max interval 0
          MCU temperature: min 40.1, current 40.5, max 40.8
          Supply voltage: min 24.1, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 34640, standstill, SG min/max not available
          Driver 1: position 34640, standstill, SG min/max not available
          Driver 2: position 34640, standstill, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2021-09-11 12:13:03
          Cache data hit count 1743212367
          Slowest loop: 10.26ms; fastest: 0.16ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.2ms, write time 2.8ms, max retries 0
          DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty
          === Network ===
          Slowest loop: 31.65ms; fastest: 0.04ms
          HTTP sessions: 1 of 8
          Interface state active, link 100Mbps full duplex
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Error: No power fail script provided
          Error: G0/G1: insufficient axes homed
          ; Configuration file for Duet 0.8.5 (firmware version 1.21)
          ; generated by RepRapFirmware Configuration Tool v3.3.2 on Thu Sep 02 2021 19:22:19 GMT+0100 (British Summer Time)
          M550 P"MiniKossel" ; set printer name
          M665 R105.6 L217.29 B85 H243.1 ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X-26.2 Y-26.2 Z-26.4 ; put your endstop adjustments here, or let auto calibration find them
          M540 PBE:XX:XX:XX:XX:XX ; set custom MAC address
          M552 P192.X.X.XX S1 ; enable network and set IP address
          M553 P255.255.255.0 ; set netmask
          M554 P192.X.X.X ; set gateway
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M92 X80.00 Y80.00 Z80.00 E683.5 ; set steps per mm
          M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X20000.00 Y20000.00 Z20000.00 E3600.00 ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E450 I60 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 Z-0.1 S1 ; set minimum Z
          M574 X2 S1 P"xstop" ; X min active high endstop switch
          M574 Y2 S1 P"ystop" ; Y min active high endstop switch
          M574 Z2 S1 P"zstop" ; Z min active high endstop switch
          M558 P1 C"zprobe.in" H8 F120 T2400 ; set Z probe type to switch and the dive height + speeds
          G31 P500 X-0 Y-0 Z1.371; this Z offset is just above the bed, I fine tune with my Z offset routine.
          ; Bed Mesh
          M557 R130 S20 ; probe within a radius of 130mm from the centre with a mesh spacing of 20mm
          M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 ; define bed temperature sensor
          M308 S1 P"e0temp" Y"thermistor" T100000 B4388; define E0 temperature sensor
          M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
          M950 H1 C"e0heat" T1 ; heater 1 uses the e0heat pin and sensor 1
          M140 P0 H0 ; map heated bed to heater 0
          M950 F0 C"fan0"
          M950 F1 C"fan1"
          M106 P0 S0 I0 F500 H-1 C"Part Clg" ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S0 I0 F500 H-1 C"Bed Clg" ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M563 P0 S"Hot End" D0 H1 F0 ; define tool 0
          ; Power Failure
          M911 S21.0 R23.0 G91 M83 G1 Z3 E-5 F1000"
          T0 ; select first tool
          M501
            Dave Parry
            Dont know if its relevent but I just tried G29 S0 and all I get is response too long and console shows
            Warning: Skipping grid point X=-80.0, Y=60.0 because Z probe cannot reach it for all points.
            It does save a file to card but Hieght map says invalid
              jay_s_uk @Dave Parry
              @dave-parry heightmap invalid was a bug in version 3.2 of the DWC so you need to update the version of DWC you're running
                Dave Parry
                This post is deleted!
                  dc42 administrators @jay_s_uk
                  @jay_s_uk said in Warning: M500: No M501 command was executed in config.g:
                  Not actually a bug, it's because the height map file format was changed to support axes other than X and Y, and older DWC versions don't know about the new format.
                    Dave Parry
                    Ok Updated to 3.3, but don't have time just at the mo to see if that has fixed it. Will try later this afternoon
                      Dave Parry
                      I am getting a height map now. I think the warnings were for additional points on the command outside my print bed diameter. But still have the original problem.
                      Also get the following
                      11/09/2021, 18:11:46 G32
                      Error: Auto calibration failed because probe point P0 was unreachable using the current delta parameters. Try a smaller probing radius.
                      11/09/2021, 18:10:34 M500
                        ; Power Failure
                        You're missing a double quote mark on this line and I think that's messing up the rest of the lines after it.
                        Here's my line as comparison:
                        ; POWER LOSS RECOVERY
                        M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-1 F500"  ; Configure automatic saving on power loss
                          Dave Parry
                          Thanks for reply but still getting error message "Warning: M500: No M501 command was executed in config.g"
                          here's what I have at the end of config.g now
                          ; Power Failure
                          M501
                          SIamundefined 1 Reply Last reply Reply Quote 0
                          • SIamundefined
                            SIam @Dave Parry
                            as @Phaedrux said, here is your mistake
                            change this to:
                            M911 S21.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
                            Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                            Duet WiFi 1.02 or later + DueX5
                            RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                            Duet WiFi Server: 1.26
                            Duet Web Control 3.4.0beta4 (2021-09-27)
                              Dave Parry
                              @siam said in Warning: M500: No M501 command was executed in config.g:
                              Thanks Slam that seems to have fixed it.
                              Just have to recalibrate it now.
                              Have to say this hasn't been as easy a transition from a legacy duet to a duet 2 has I had hoped.
                              Thanks to all for their help.
