    Pins with 5V 1A in duet2/duex?
    • RodrigoRMaraujoundefined
      RodrigoRMaraujo
      Hello. I have a duet 2 wifi and a duex5 on a voron 2.4. I would like to power an esp32cam and I need 5V and ~1A. Can I get these values ​​on any of the pins on these boards? Thanks!
      o_lampeundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @RodrigoRMaraujo
        @rodrigormaraujo
        I wouldn't recommend that. Use an external 5V switching regulator instead. (aka dc/dc buck converter)
        If you want Duet to control anything on the ESP, you have to connect GNDs of both.
        RodrigoRMaraujoundefined 1 Reply Last reply Reply Quote 0
          RodrigoRMaraujo @o_lampe
          @o_lampe Ok I'll do it. Thanks!
            dc42 administrators @RodrigoRMaraujo
            @rodrigormaraujo you can get 5V 1A from the PanelDue port, if you don't have a PanelDue connected. If you do have a PanelDue then best use a separate PSU.
              You can get devices like this that provide 5v via usb in a convenient package.
              https://www.amazon.ca/Charger-ADSDIA-Aluminum-Waterproof-Motorcycle/dp/B07PN5YZX3/ref=sr_1_5?crid=8GK4ZUT768DM&dchild=1&keywords=usb+boat+charger&qid=1631389908&sprefix=usb+boat%2Caps%2C333&sr=8-5
