Ender 3 Pro driving past end stops after stopping
Morning all.
so I converted my ender 3 to duet it all went well (I though) till I added exoslid and New extruder discovered my x going backwords. changed that M569 P0 S0
now I can't figure out why my end stops, stop machine but will drive past it .; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri May 14 2021 14:38:44 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"Ender 3 Pro" ; set printer name
M918 P1 E4 F2000000 ; configure direct-connect display; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P1 S1 ; physical drive 1 goes backwards
M569 P3 S1 ; physical drive 3 goes backwards
M92 X80.00 Y80.00 Z400.00 E936.675 ; set steps per mm 143.1 base
M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
M208 X233 Y235 Z260 S0 ; set axis maxima; Endstops
;M574 X1 Y2 S1
M574 Z0 ; configure Z-probe endstop on Z
M591 P1 C"e0stop" S1 D0; Z-Probe
M558 P9 C"^zprobe.in" H2.5 F180 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-32 Y0 Z2.810 ; set Z probe trigger value, offset and trigger height
M557 X40:230 Y30:230 S40 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
M143 H0 S150 ; set temperature limit for heater 0 to 150C
M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S275 ; set temperature limit for heater 1 to 275C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power lossand here's home all
G91 ; relative positioning
G1 H1 X238 Y240 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X238 Y240 F240 ; move slowly to X and Y axis endstops once more (second pass)
;G1 H1 Z265 F240 ; move Z down stopping at the endstop
G90 ; absolute positioning
G1 X178 Y109 F6000 -
@ap742 said in Ender 3 Pro driving past end stops after stopping:
G1 H1 X238 Y240 F240 ; move slowly to X and Y axis endstops once more (second pass)The G1 H2 move is moving in the same direction as the G1 H1 moves.
Try G1 H2 X-5 Y-5 F6000
@fcwilt Thanks that did help . but when it hits limit switch my x & y set to 0
when I tell it to move it right I guess - away from limit switch it stays there but + it'll try driving disregarding limit switch
https://drive.google.com/file/d/1C7-aKgCzSVuiECu2LyZn0p5qCil9Pxc7/view?usp=sharing -
I think I found my mistake .
M574 X2 S1 P"xstop"
M574 Y2 S1 P"ystop"had X&Y set to 1
changed it to 2 helped -
M574 X2 S1 P"xstop"
changed it to 2 helpedAs you have found out the configured endstop sensor locations (axis min or max) and the homing movies have to be in sync.
had X&Y set to 1
changed it to 2 helpedI think you might have some problems with your motor directions still. I'm pretty sure the endstop locations on the Ender 3 are at the min position. IE to the left and at the back of the moving bed, so X0 and Y0. So unless you've moved the endstops I think you have larger problems. If they are at the low end, then your homeall movements need to flip directions. The actual motor directions should move -x to the left, +x to the right, -y moves the bed back (nozzle to the front) and +y moves the bed to the front (nozzle to the back.)
