    How Do I Calibrate My Titan Extruder and Test Print?
    115
    27.4k
    • AaronGreenundefined
      AaronGreen
      Update: the volcano nozzle inner diameter, in the top of it, not the outlet, is visibly larger than the typical E3D nozzle. So the difference between the two nozzles is that they are different lengths, and have different internal capacities. Testing the E3D out yesterday showed no blockages, but two different brands of volcano kits failed the exact same way.
      My guess is that the volcanos I've purchased have an inner capacity that causes a backup/congestion of too much filament, as opposed to the E3D, which allows less molten filament to restrict the loading filament.
      It maybe a brand/design/supplier fault, and may not be present in the common volcano, or OEM brand volcano. As I mentioned, the E3D works perfectly fine over the same period of time the volcano congests, and it has less nozzle capacity. FYI.
      • MoS-tekknixundefined
        MoS-tekknix
        Only my 2 cent, cause i'm also struggling from switch over my E3d-Hotends for the Chimera (orignal) with it's 12v/40W Heaters against the Volcano-ones with 12V/30W Heatercartriges.
        First, I've a massive Problem with the Flowrate. I've done the usual things first, like Autotune the Heaters with a P-Value of 0.7 (otherwise the Warning of Duet will say it will be overpowered),trying to crank up the Temperature (20-30°C higher as normal) but everything leads to open gaps, a massive Underextrusion happens at Print-Speeds higher as 10-15mm/s
        One interesting thing was, that my dasfilament.de PLA with a rated Temperature of 215°C has massive problems with the flow. My Prima-PLA-Filament (rated to 210°C) was without any problems! It flows even with a Extruder-Rate of 60mm/s. The same block, same Heater, same nozzle (0.6mm).
        After that, i've run the Autotuning for the Heater-Cartridges with a Value of P1.0 even with the Warning, which helps to make the dasfilament-de PLA flow more consitenly. Now, i've reached a flowrate of about 34-40mm/s.
        Another test indicates that these kind of Filament needs lower temps of around 190-195°C to flow better. Now i'm around a flowrate of 50mm/s which is not as high as the prima-PLA but it may worth to try it out. The same has deckingman in mind and i can confirm this at least for my PLA-Tests so far.
        Good luck
        • deckingmanundefined
          deckingman
          @AaronGreen:
          It maybe a brand/design/supplier fault, and may not be present in the common volcano, or OEM brand volcano..................
          Yes, almost definitely the cause of your problems if they are clones rather than genuine E3D parts. One thing to try if you don't want to pay for all the genuine parts, at least would be the genuine E3D heat breaks.
            AaronGreen
            I struggled to believe the genuine parts are any different to the clones. Normally, I know the difference, but there's not much in a hotend that I can see.
            My last attempt is to unscrew the nozzle a bit, so it's set lower, but seeing that the thermistor runs the full length of the nozzle as it is, I can't see there being an improvement. I really just think it's a bad clone, and I'll have to drop $100+ to get a genuine one here.
              deckingman
              @AaronGreen:
              I think the main difference between a genuine hot end and a clone is the heat break - hence my suggestion that you try a genuine heat break which will be a lot cheaper than the entire assembly. The heat break on a genuine part is very narrow which means that there is a sharp transition between the hot zone and the cold zone. Getting that right is difficult to machine and if the quality of the steel is less than optimum, it can can make the part fragile and easy to break. So the clone manufacturers tend to make the heat break thicker which prevents it from doing it's job and too much heat gets transferred from the hot zone to the cold zone.
              Edit. Or you could try my other suggestion and fit a higher flow rate fan to shift more air over the heat sink. Having just thought about that, it could also be that the clone has a thicket "tube" section to the heat sink which will retain more heat so maybe you need the genuine heat sink as well as a genuine heat break…......
              • Dougal1957undefined
                Dougal1957
                @deckingman:
                @AaronGreen:
                And possibly the nozzle geometry which is tightly controlled in an original E3D One
                Doug
                ps this seems like to good to be true but I have 2 in the post to me https://www.reprap.me/v6-heat-break-titanium.html £6.21 for a titanium V6 Heatbreak seems like a bargain to me hopefully it is just a mistake on the price and the parts will be genuine we will see when they arrive.
                  deckingman
                  @Dougal1957:
                  Doug
                  Doug,
                  That does seem like a bargain and RepRap.me are official resellers for E3D https://e3d-online.com/resellers
                    Dougal1957
                    @deckingman:
                    @Dougal1957:
                    Doug
                    Doug,
                    That's exactly why I was willing to take the risk.
                      MoS-tekknix
                      If this price is real and that are really Titanium - HB's i would say: Buy at much as you can.
                      If you went over to Filastruder you will pay around 50€ for one.
                        Dougal1957
                        yep well I expect mine to land either tomorrow or Monday and it should be fairly easy to tell if there Genuine Titanium or not and I don't think the Chinese would try to clone them TBF 2 have cost me around $20 shipped.
                          MoS-tekknix
                          But interessting that they sell the "non- Titanium" Heatbreaks for more money 😉
                          I'll have ordered also a few of them.
                            Dougal1957
                            I know didn't want to drop to much on then straight away but they are also the guys that designed the Diamond hotend so I think they are fairly reputable so I don't have to many worries about them at the mo
                              MoS-tekknix
                              ack, let us see what we'll get
                              • jacksatundefined
                                jacksat
                                Just want to mention the following ,but not 100% sure.
                                Isn't it so that original E3D V6 heatsinks have M7 threads in them ,and most clones are M6 ?
                                From the pics in the link i can see the have M7 on the heatsink side and M6 on the heaterblock side
                                so they would fit the original E3D's but not the clone heatsinks.
                                So befor you order maybe you want to check if the innerthread of your heatsinks are M7 or M6(heaterblock side is no problem they are all M6)
                                  deckingman
                                  If true, that's a good point. Genuine E3D V6 are certainly M7 in the heat sink and one would assume that clones would at least attempt to use the same dimensions but maybe not. As you say - worth checking.
                                    MoS-tekknix
                                    Your somehow right. My "Clone" Heatsinks have this Problem too. The Original ones does use M7 and they work like a charm. Now with Capricorn-Tube i'm happy.
                                      Dougal1957
                                      Mine are original V6's so I am not worried but it will be a telling point if they dont fit then they are clone heatbreaks without a doubt will report as soon as they arrive
                                        MoS-tekknix
                                        So, i've assembled my Setup today again.
                                        The same Setup (some Parameters i need to change) was working with "normal" E3D-Heat-Blocks and 12v/40W Cartridges and Standard-Nozzles in a Chimera Dual Setup without any problems.
                                        i've ordered 2 Volcano-Kits and set them (incl. the new Cartridge-Thermistors) in my setup.
                                        Here the main - Problem starts up, it was not working, only if i use 5mm/s as Retraction-Speed and i've to slow down the Print to not more as 5-10mm/s which is horrible slow.
                                        Today i've received an oringinal E3Dv6 Heatsink, an original E3D 12V Fan, 2 original E3Dv6-Heatbreaks and Capricorn - Tube.
                                        I've disassembled everything and have the E3DV6-Volcano-Combination together exactly as the Assembly-Guides will show. Tighten latest with 285°C and tried to use it.
                                        The Print looks exactly the same. The Extruder will skip (or drive back and forth due to to much pressure) cause the Filament will not constantly feeded. If i use again 10mm/s max it works without any problems.
                                        That's driving me nuts.
                                          MoS-tekknix
                                          One additional Side-Node.
                                          Regardless of the Nozzle - Size (tested 0.4mm, 06mm, 0.8mm so far) i need to lower the Extrusion Mulitplier to around 0.54 in Simplify3d if i want to set the extrusion width to the same size as the nozzle-size.
                                          With my Standard-E3Dv6-Blocks and nozzles i need around 0.93
                                          For me this indicates that there is a lot of plastic beeing able to be molten but why i can only print at 25mm/s without landing into underextrusion issues? That's is really annoying.
                                          Some advice is really, really appreciated!
                                            The extrusion width will depend on other factors too, in particular the height of the nozzle above the bed. Don't try to print with the extrusion width equal to the nozzle width, it's not practical because of filament swell as it leaves the nozzle. Most slicers default to extrusion width about 25% greater than nozzle size, e.g. 0.5mm using a 0.4mm nozzle.
