    Printer Keeps Resetting Mid-print
    • R3Dundefined
      R3D
      Duet 2 running 3.2.2 standalone. I don't have issues with smaller prints but when I am printing a larger part, the print fails halfway through with a software reset.
      M122 lists the reason as a HardFault bfarValid precise, none spinning. Full M122 ouput below.
      console (1).txt
      tried to find some similar issues on this and came to a few that ranged from a bad board to a bad SBC and some were firmware related. would like to know what I can do to figure out what is happening. Config.g is below too if that helps.
      config.g
      I appreciate any help in this. 🙂
      • T3P3Tonyundefined
        T3P3Tony administrators @R3D
        @r3d Are you using object labelling with more than 20 objects with individual labels in the gcode? This may be related to an issue with object labelling?
        If not can you upgrade to 3.3 stable and see if you get the same fault?
        www.duet3d.com
        R3Dundefined 1 Reply Last reply Reply Quote 0
        • R3Dundefined
          R3D @T3P3Tony
          @t3p3tony No I only have a single part on the build plate, albeit a large one. I will upgrade to 3.3 and see if that produces similar error messages.
