    CR-3D Liquid Series
    My Duet controlled machine
    • CR3Dundefined
      CR3D
      The L-series from CR-3D is a modified version of the industrial series with two dispensers and a UV curing lamp.
      Of course, we rely on controller boards from Duet3D out of conviction and as a german reseller -> to the CR-3D Duet Shop
      Thanks to the proven IDEX system, prints can be made with different materials or different nozzle geometries. Another advantage of the independent print heads is the ability to produce several components in one operation on the currently 220 x 220mm printing plate. As with all CR-3D systems, the system can easily be adapted to larger installation spaces.
      A Duet2 Wifi EA and a DUEX 5 are installed in the current setup. As with the large CR-3D printer models, a Duet 3 6HC is installed for the series machine.
      It is a Cartesian IDEX kinematics with independent dual Z-axis with tilt function.
      Many products known from CR-3D are installed, such as the MagnetiCR Swap System for the printing plates or the SupCRprobe as a Z-Probe.
      You can find all information on our homepage ...
      https://www.cr3d.de/3d-drucker/liquid-serie/
      Regards
      Christian (CEO and Founder of CR-3D)
      Christian from CR-3D
      Homepage:
      www.cr-3d.de
      Facebook:
      https://www.facebook.com/cr3d.official
      Our Discord Server
      https://discord.gg/SxRaPNuRdA
      Thingiverse Profile:
      https://www.thingiverse.com/cr-3d_official/about
      T3P3Tonyundefined 1 Reply Last reply Reply Quote 2
      • T3P3Tonyundefined
        T3P3Tony administrators @CR3D
        @cr3d very nice. What resins do people tend to use in this manner, are the the same as the UV curable resins used in some of the vat polymerisation printers?
        www.duet3d.com
        CR3Dundefined 1 Reply Last reply Reply Quote 0
        • CR3Dundefined
          CR3D @T3P3Tony
          @t3p3tony
          no ... the first project was now with a german industrial adhesive manufacturer where we then processed their adhesives. The next step are very soft silicones ...
          Homepage:
          www.cr-3d.de
          Facebook:
          Our Discord Server
