    Homing issue need help
    Using Duet Controllers
    • bartekp
      bartekp last edited by
      HI all ,
      My printer, when I start HOME ALL AXIS, move simultaneously Z then Y and X but Y goes in the opposite direction to the Endstop switch and you don't know what I will change, it always goes in the same direction.
      I change the Y direction in the Marlin Configurator and the commands for endstop do not change nothing
      In addition, I noticed that when I start HOME Y axis, it starts with the first Z axis. I'm already exhausted with this, I can't set it up. Printer tronxy x5 SA endstp on each axis normally open
      Please help
      @siam
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.3 on Fri Oct 01 2021 17:20:53 GMT+0200 (czas środkowoeuropejski letni)
      M550 P"My Printer" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M350 Z16 E16 I0 ; configure microstepping without interpolation
      M350 X16 Y16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z2756.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z150.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X5000.00 Y5000.00 Z50.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X500 Y500 Z600 S0 ; set axis maxima
      M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
      M558 P1 C"zprobe.in" H5 F120 T12000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X70:500 Y70:500 S20 ; define mesh grid
      M308 S1 P"e0temp" Y"pt1000" R4700 ; configure sensor 1 as PT1000 on pin e0temp
      M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
      T0 ; select first tool
      ; homex.g
      ; called to home the X axis
      G91 ; relative positioning
      G1 H2 Z5 F12000 ; lift Z relative to current position
      G1 H1 X-505 F1800 ; move quickly to X axis endstop and stop there (first pass)
      G1 X5 F12000 ; go back a few mm
      G1 H1 X-505 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H2 Z-5 F12000 ; lower Z again
      G90 ; absolute positioning
      ; homey.g
      ; called to home the Y axis
      G1 H1 Y-505 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 Y5 F12000 ; go back a few mm
      G1 H1 Y-505 F360 ; move slowly to Y axis endstop once more (second pass)
      ; homez.g
      ; called to home the Z axis
      G1 H1 Z605 F1800 ; move Z up until the endstop is triggered
      G92 Z600 ; set Z position to axis maximum (you may want to adjust this)
      ;G91 ; relative positioning
      ;G1 Z5 F200 ; lift Z relative to current position
      ;G90 ; absolute positioning
      ; homeall.g
      ; called to home all axes
      G1 H1 X-505 Y-505 F1800 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-505 ; home X axis
      G1 H1 Y-505 ; home Y axis
      G1 X5 Y5 F12000 ; go back a few mm
      G1 H1 Y-505 ; then move slowly to Y axis endstop
      G1 H1 Z605 F360 ; move Z up stopping at the endstop
      • T3P3Tony
        T3P3Tony administrators @bartekp last edited by T3P3Tony
        @bartekp no need for multiple threads on the same issue
        https://forum.duet3d.com/topic/25363/homming-issues-strange-behaviors/6
        www.duet3d.com
