    Just a little sanity check.
    233
    • PCR
      PCR last edited by
      Just for my own sanity.
      I bought a duet 3 Mini 5+ and want to use 4 external steppers with the 1XD Board. Should ne no Problem?
        @pcr yes that should work, although I'm not aware of anyone else using that combination.
        In theory it should be possible to run 2 external steppers from the stepper daughter board connector on the Duet 3 Mini, however in most cases you would need to level shift the signals to 5V to drive external drivers. We may eventually make a daughter board to do this.
        PCR 2 Replies Last reply Reply Quote 0
        • PCR
          PCR @dc42 last edited by
          @dc42 will give some Feedback 😉
          Would be Nice to have a "only CAN" Board. Or a 6HC with external Stepper drivers Output.
          Will be using the Hardware on a 3500mm*2000mm CNC with nema 34 with more than 6A and closed loop. 😉
          • PCR
            @dc42 Just FYI IT works Like a Charm!!!!!
            Duet 5 Mini + + 4x 1XD Boards with closed loop steppers.
            PCR 1 Reply Last reply Reply Quote 1
            • PCR
              PCR @PCR last edited by
              https://youtu.be/8oclp8xvztU
              And
              https://youtu.be/YFMlYbNTgBw
              T3P3Tony dc42 2 Replies Last reply Reply Quote 1
              • T3P3Tony
                T3P3Tony administrators @PCR last edited by
                @pcr looking great!
                www.duet3d.com
                  dc42 administrators @PCR last edited by
                  @pcr said in Just a little sanity check.:
                  We are developing a 6XD board (6HC with external driver outputs instead of internal drivers) is being developed.
                    And
                    Looks good!
                    FYI the Duet 3 Mini includes a connector for a 2-driver expansion board. We included a 5V pin on that connector, so that instead of a 2xTMC2209 daughter board, it would be possible to fit a 2x external driver daughter board.
