    M150 with Adafruit RGBW ring issue?
    183
    • A Former User
      Good morning. I've just mounted my Adafruit RGBW 24 LEDS ring with my Duet2WiFi and I'm starting to experiment the command M150 but I'm experiencing some issue and I don't know if it's my fault or not...
      My will is to "divide "the 24 LEDs in 3 groups of 8 LEDs each and give them 3 different colors.
      I've seen the documentation for the M150 and I thought I'd have to set the F value to 1, right?
      But If i send the comand:
      M150 X4 R0 B255 U0 S1
      It correctly set the first LED to blue, the I send
      M150 X4 R255 B0 U0 S2
      It turns both the LEDs 1 and 2 to red.
      If I send
      M150 X4 R0 B255 U0 S1 F1
      to set the first LED to blue and then wait for the new command for the following LEDs nothing happens...
      Am I missing something or is it impossible to give each LED (or LEDs grouping) a different color from each others?
      Thanks
      Stephen6309 gloomyandy 2 Replies Last reply Reply Quote 0
      • Stephen6309
        Stephen6309 @Guest last edited by Stephen6309
        @thedragonlord I use this for my 1426, first four for heater 1(T0), second four for Heater 0(bed)
        ; dameon.g
        ; Adafruit #1426 8 led neopixel
        G4 P500 ; 500ms delay
        if heat.heaters[1].current > 40 ; temp
        M150 R255 P10 S4 F1 ; set second 4 red, and done
        elif heat.heaters[1].current <= 40
        M150 U255 P10 S4 F1 ; set second 4 green and done
        if heat.heaters[0].current > 40 ; temp
        M150 R255 P10 S4 F0 ; set first 4 red
        elif heat.heaters[0].current <= 40
        M150 U255 P10 S4 F0 ; set first 4 green
        F0 starts at the beginning of the strip, F1 continues on.
        A Former User 1 Reply Last reply Reply Quote 0
        • A Former User
          A Former User @Stephen6309 last edited by
          @stephen6309 said in M150 with Adafruit RGBW ring issue?:
          ; dameon.g
          it doesn't work, if I type S1 no LED is turned on....and I have to set the X parm to 4
          Stephen6309 1 Reply Last reply Reply Quote 0
          • Stephen6309
            @thedragonlord Have you tried X3? I'm using the default of X1. I'm using a Duet3 6HC/PI4 and a Mini 5+.
            • A Former User
              A Former User @Stephen6309 last edited by A Former User
              X3 doesn't work at all, but with I've relaized it works with no X parameter setted, but F1 still doesn't work...
              • Stephen6309
                @thedragonlord Don't know what to try next. I used a macro to test what I ended up using with my deamon.g file.
                • A Former User
                  maybe with the Duet2WiFi F1 simply doesn't work...I don't know....
                  • Stephen6309
                    @thedragonlord Don't know about the Duet 2, since the Duet 3 boards have a connector just for the NEOPixel LEDs.
                    My are connected to a Mean Well 5vdc on one side of the strip, the other end for the input & GND to the connector.
                    • gloomyandy
                      gloomyandy @Guest last edited by
                      @thedragonlord You need to send at least one command without the F1 to actually set all of the accumulated leds so...
                      M150 X4 R255 S4 F1
                      M150 X4 U255 S4 F1
                      M150 X4 B255 S4
                      Should set the first 4 to red, the next 4 to green and the next 4 to blue. If you send another command it will start again at the first LED in the string.
                      • A Former User
                        A Former User @gloomyandy last edited by
                        @gloomyandy said in M150 with Adafruit RGBW ring issue?:
                        M150 X4 B255 S4
                        uh ok, it works like this, thanks
                        gloomyandy 1 Reply Last reply Reply Quote 0
                        • gloomyandy
                          @thedragonlord The way that neopixels work is that you pretty much set them all at once. Basically each set of commands goes to the first pixel and if another set arrives within a short timeout then the previous set of commands are passed on to the next pixel and this continues for each pixel until there is a longer gap in the commands. So to make this work RRF needs to buffer up all of the commands until you have the complete sequence, yo do this by giving the commands with an F1 parameter, then on the final command (with the default F0) RRF sends all of the commands one after the other and all of the pixels in effect get set in one go. So using my previous set of commands the pixel command buffer will look like
                          RRRRGGGGBBBB where R = (255, 0, 0, 0), B = (0, 255, 0, 0) G=(0, 0, 255, 0) and the values in brackets are the red, green, blue, white values for each pixel. All of these will sent out one after the other when that final G150 with no F command is processed.
                          Hope that makes some sort of sense!
                          A Former User 1 Reply Last reply Reply Quote 1
                          • A Former User
                            I'm triyng to use the M150 in a while loop like this:
                            ; Check for T0 to start warming
                            if {global.isTool0Warming==false && tools[0].state=="active"}
                            	set global.isToolsStatusChanged=true
                            	set global.isTool0Warming=true
                            	set global.totalTemperature=global.totalTemperature+tools[0].active[0]
                            ; Check for T0 to start cooling
                            if {global.isTool0Warming==true && tools[0].state!="active"}
                            	set global.isTool0Warming=false
                            	set global.totalTemperature=global.totalTemperature-tools[0].active[0]
                            ; Recalculate temperature step for each LED
                            if {global.isToolsStatusChanged==true}
                            	set global.isToolsStatusChanged=false
                            	set global.temperatureStep=global.totalTemperature/24
                            var index=1
                            var colore=0
                            if {global.temperatureStep>0}
                            	while {var.index<24}
                            		if {heat.heaters[1].current>=global.temperatureStep*var.index}
                            			set var.colore=255
                            		else
                            			set var.colore=0
                            		;echo "Step, colore =", var.index, var.colore
                            		M150 R0 B0 U{var.colore} S{var.index} F1
                            		set var.index=var.index+1
                            	if {heat.heaters[1].current>=global.temperatureStep*24}
                            		;echo "Step raggiunto =", var.index
                            		set var.colore=255
                            	else
                            		set var.colore=0
                            	M150 R0 B0 U{var.colore} S24 F0
                            but it looks like the first M150 inside the loop "freezes" everithing and no LED is setted on....what am I doning wrong?
                            • gloomyandy
                              @thedragonlord What are you trying to do with that s{var.index} parameter on the M150, with that code you will be setting first 1 then 2 then 3... up to 24 leds to the selected colour and adding them into the buffer. So by the end of the loop you will have 1+2+3+4+5+6+7...+22+23+24 led commands in the buffer. Given that you only have 24 of them, that does not seem like a very good idea. The S parameter basically specifies the number of LEDS to set to the given colour, not an index into some sort of buffer. As I said above when you use the F1 parameter you are basically accumulating the commands in the command buffer,
                              • A Former User
                                A Former User @gloomyandy last edited by A Former User
                                Uh, I thought I understood but just for try I tried to set 5 LEDs in green and one LED in red, so I've sended:
                                M150 U255 R0 B0 S1 P10 F1
                                M150 U0 R255 B0 S1 P10
                                and here's what I got:
                                Only 5 LEDs turned on and the colors "randomly" assigned...
                                What am I doing wrong again?
                                EDIT
                                Maybe I understood, I always have to set the whole set of LEDS to make them work correctlu, right?
                                • gloomyandy
                                  @thedragonlord Where are you setting the LED type? I thought you had RGBW leds, if so at some point you need to tell RRF that is what you have with the X parameter to M150.
                                  • A Former User
                                    I've discovered that if I set the LEDS whan the heater is heating, regardless the numbers, the colors etc. they don't ever be set on. When the heater reaches the temperature the LEDS works normally...
                                    • gloomyandy
                                      @thedragonlord How are you testing that? If you have a simple reproducible case then you should probably describe it so that dc42 can look into it.
                                      • A Former User
                                        I discovered that if you heat the tools "manually" from the Tools buttons in DWC all gcodes stay queued until the tools reach the setted temperature... I haven't tried if heating from a print acts the same...
                                        jay_s_uk 1 Reply Last reply Reply Quote 0
                                        • jay_s_uk
                                          jay_s_uk @Guest last edited by
                                          @thedragonlord you probably have M116 or similar in your tool change files
