    PanelDue Firmware 3.4.0-pre3 released
    PanelDue
    1
    1
    155
    • mfs12
      mfs12 last edited by
      Hey, a new release is available. It contains mostly bug fixes.
      Release Notes 3.4.0-pre3
      This release requires RepRapFirmware 3.4 or later.
      Version 2 (after August 2016) and Version 3 PanelDue are supported.
      Features:
      • add cross-platform headless builds based on cmake
      • cleaned up dim/screensaver handling
      • removed compiler warnings
      • enabled Russian localization by default
      • enabled Ukrainian localization by default
      • improved list-locales tool for translation debugging
      Bug fixes:
      • fixed displaying of M291 S2 and S3 if followed by M292
      • fixed displaying macro buttons in control tab
      • fixed setting of serial baud rate after reboot
      • cleaned up English
      • cleaned up Czech translation
      • cleaned up French translation
      • cleaned up German translation
      • fixed access to second sd card
      • cleaned up Russian translation
      • fixed persistent pressed button handling in some dialogs
      • fixed updates via RRF
      Downloads and flashing instructions:
      Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.4.0-pre3
      Flashing instructions can be found at https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
      Visit me on github at https://github.com/mfs12/
