    Duet 3 mini 5 and Octoprint- Over sbc wiring?
    • toddel
      toddel last edited by
      Hi guys.
      Is a Connection via ribbon cable from duet mini to Raspberry possible or only over usb?
      I have a mini5 in sbc mode, if i use it in standalone, is a Connection over that cable possible?
      oliof jay_s_uk dc42 3 Replies Last reply Reply Quote 0
      • oliof
        oliof @toddel last edited by
        @toddel the SBC port only speaks SPI, which isn't supported by OctoPrint AFAIK. You might be able to use the PanelDue serial port to connect directly to UART pins on the Raspberry Pi.
        That said, with RepRapFirmware, running OctoPrint doesn't necessarily get you the advantages you get with Marlin. But I guess you're aware of that.
        <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
        • jay_s_uk
          jay_s_uk @toddel last edited by
          @toddel have a look at this for using the SPI with octoprint https://github.com/ofligit/dsfprinter
            dc42 administrators @toddel last edited by
            @toddel DSF on the Pi has an API suitable for programs such as Octoprint to send the data through. Octoprint would need to be modified to use it. There is a version of Repetier Server that already supports this interface.
