    Avoid resetting height map
    • petriheino
      petriheino last edited by
      Is there a way to avoid resetting the tool offset/activated mesh correction after doing G30/G29 during a print?
      If clicking pause, then home accidentally (G28) then the print will crash because tool offset is being reset after continuing print.
      This is of course caused by setting G92 Z200 in homez.g / homeall.g.
      Because G29 is run in start.g.
      But could a simple conditional gcode be the fix here?
      o_lampe dc42 2 Replies Last reply Reply Quote 0
      • o_lampe
        o_lampe @petriheino last edited by
        @petriheino
        You could verify if the state of the printer is "paused" in your homeall.g. Then abort the homing procedure completely.
          dc42 administrators @petriheino last edited by
          @petriheino if you are running firmware 3.3 than you may find that this is fixed in 3.4beta.
          Why are you using G92 Z200 at all?
