    RRF v3.3/Mini 5+ Wifi - Major problems with layer shifting
    Using Duet Controllers
    rrf3.3
    9
    38
    2.1k
    • Gixxerfastundefined
      Gixxerfast @dc42
      @dc42 said in RRF v3.3/Mini 5+ Wifi - Major problems with layer shifting:
      You can use M569 P# D2 to force spreadCycle mode
      Thanks DC, I was going to ask about this 🙂 I don't want to run in stealthchop anyway.
      Looking at the failed prints it seems like they shift in a diagonal fashion.
      I will up the motor currents, make sure that stealtchchop is disabled and also do the testprints as Tony suggested.
      I will have to do that tonight and I will report back the results.
      Thanks again all
      Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
      Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
      Ender 3 Pro with BTT SKR-2 + RRF
        Gixxerfast
        Im really starting to almost give up here.
        No matter what I do, I still have layer shifts with this print.
        I don't know what to do next. Almost printed a spool of ASA in failed test prints.
        What can I do next, any tips please?
        I don't want to revert to the old setup as that's a ton of work as I now have a can toolhead board and umbilical instead of cable chains.
        1. I have recrimped and checked the X motor connector as all layer shifts, shifts to the down(-y)/left(-x)
        2. Using driver 2 instead of driver 0.
        3. I have changed the thermistor setting
        4. Increased printing temperature
        5. Removed all macro calls (almost) from config.g
        6. No bed mesh, no auto-z
        7. Forcing into spreadcycle with a m569 P## D2 for all motors
        First layer is good, extrusion is good to OK depending on temp.
        Stepper motors are about 60C after print.
        With Klipper I was running 800/700mA on the A/B-motors and max 5000 mm/s2 acceleration without any problems:
        kinematics: corexy
        max_velocity: 300
        max_accel: 5000    			#Max 4000
        #max_accel_to_decel: 3000
        ##max_accel: 7000    			#Resonance test - remove after test
        ##max_accel_to_decel: 7000    #Resonance test - remove after test
        max_z_velocity: 20 			#Max 15 for 12V TMC Drivers, can increase for 24V
        max_z_accel: 350
        square_corner_velocity: 5.0
        Now I request only 3000 mm/s2 printing acceleration and 5000 transport acceleration. Is this too much for RRF/Duet and my motors, must I lower this?
        I printed the 30mm cubes in the corners with mesh and all macros and they printed without problems, but as soon as I try even a single part of the problem print above. I have layer shifts.
        The motor harness is a factory crimped harness from Fermio Labs which I've had since I built the printer.
        Btw, I use SuperSlicer 2.3.56
        2021-10-08 23:58:55	m906
        Motor current (mA) - X:1200, Y:1200, Z:1200, E:500, idle factor 70%
        2021-10-08 23:56:59	m122
        RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode)
        Board ID: H1668-Y296U-D65J0-40KMA-KR03Z-RK6ZH
        Used output buffers: 3 of 40 (13 max)
        Static ram: 102724
        Dynamic ram: 113872 of which 0 recycled
        Never used RAM 24252, free system stack 120 words
        Tasks: NETWORK(ready,40.0%,240) HEAT(delaying,0.1%,344) Move(notifyWait,2.9%,272) CanReceiv(notifyWait,0.1%,773) CanSender(notifyWait,0.1%,357) CanClock(delaying,0.0%,338) TMC(notifyWait,3.3%,72) MAIN(running,50.8%,408) IDLE(ready,0.5%,29) AIN(delaying,2.3%,264), total 100.0%
        Owned mutexes: WiFi(NETWORK)
        Last reset 02:37:40 ago, cause: software
        Last software reset at 2021-10-08 21:19, reason: User, GCodes spinning, available RAM 24684, slot 1
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
        Error status: 0x00
        MCU revision 3, ADC conversions started 9457205, completed 9457204, timed out 0, errs 0
        Step timer max interval 957
        MCU temperature: min 28.6, current 29.9, max 32.8
        Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 99/8, heap memory allocated/used/recyclable 2048/1308/1206, gc cycles 0
        Driver 0: position 81600, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 22, reads 7838, writes 9, timeouts 0, DMA errors 0
        Driver 1: position -16000, standstill, SG min/max 0/496, read errors 0, write errors 1, ifcnt 48, reads 7812, writes 35, timeouts 0, DMA errors 0
        Driver 2: position 3960, standstill, SG min/max 0/498, read errors 0, write errors 1, ifcnt 45, reads 7812, writes 35, timeouts 0, DMA errors 0
        Driver 3: position 0, standstill, SG min/max 0/94, read errors 0, write errors 1, ifcnt 41, reads 7819, writes 28, timeouts 0, DMA errors 0
        Driver 4: position 0, standstill, SG min/max 0/76, read errors 0, write errors 1, ifcnt 41, reads 7819, writes 28, timeouts 0, DMA errors 0
        Driver 5: position 0, standstill, SG min/max 0/72, read errors 0, write errors 1, ifcnt 41, reads 7819, writes 28, timeouts 0, DMA errors 0
        Driver 6: position 0, standstill, SG min/max 0/74, read errors 0, write errors 1, ifcnt 41, reads 7819, writes 28, timeouts 0, DMA errors 0
        Date/time: 2021-10-08 23:56:56
        Slowest loop: 224.55ms; fastest: 0.09ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 4.5ms, write time 1.9ms, max retries 0
        DMs created 83, maxWait 266573ms, bed compensation in use: none, comp offset 0.000
        === MainDDARing ===
        Scheduled moves 534220, completed moves 534220, hiccups 0, stepErrors 0, LaErrors 0, Underruns [5711, 58, 8], CDDA state -1
        === AuxDDARing ===
        Bed heaters = 0 -1, chamberHeaters = -1 -1
        Heater 0 is on, I-accum = 0.4
        Heater 1 is on, I-accum = 0.0
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty.
        === CAN ===
        Messages queued 549416, received 114039, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 438, free buffers 17 (min 3), ts 47301/47300/0
        Tx timeouts 0,0,0,0,0,0
        === Network ===
        Slowest loop: 205.31ms; fastest: 0.00ms
        HTTP sessions: 1 of 8
        - WiFi -
        Network state is active
        WiFi firmware version 1.26
        WiFi MAC address f0:08:d1:02:eb:c9
        WiFi Vcc 3.36, reset reason Power up
        WiFi flash size 2097152, free heap 23880
        WiFi IP address 192.168.1.70
        WiFi signal strength -50dBm, mode 802.11n, reconnections 0, sleep mode modem
        Clock register 00002002
        ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
        ; generated by RepRapFirmware Configuration Tool v3.3.2 on Mon Sep 13 2021 16:36:36 GMT+0200 (centraleuropeisk sommartid)
        ; Based on configuration by OC-Geek
        M111 S0                	; Debugging off
        G21                    	; Work in millimetres
        G90                     ; send absolute coordinates...
        M83                     ; ...but relative extruder moves
        M669 K1                 ; select CoreXY mode
        ; Limit axis
        M564 S1 H1             	; Forbid axis movements when not homed
        ; H1	Forbid movement of axes that have not been homed
        ; S1	Limit movement within axis boundaries
        ; Wait a moment for the CAN expansion boards to start
        G4 S2
        ; Fysetc 12864 display Color
        M918 P2 R6 C30 E4 F200000  	; Configure direct-connect display
        ; P2  	128x64 display using ST7567 display driver chip
        ; R6  	Display resistor ratio, in range 1 to 7. Only used with ST7567-based displays.
        ;		The default value of 6 is suitable for the Fysetc Mini 12864 display.
        ; C30	Display contrast, in range 0 to 100
        ; E4	The number of pulses generated by the rotary encoder per detent. Typical values are 2 and 4
        ; F...	SPI clock frequency in Hz, default 2000000 (i.e. 2MHz)
        M150 X2 R0 U255 B0 P200 S3   ; Set LED colours
        ; X2 		LED type: X0 (default) = DotStar, X1 = NeoPixel, X2 = Panel 12864
        ; R,U,B		Set the LED colour (note Fystec uses GRB space instead ... (Red and Green switched over)
        ; S3 		Number of individual LEDs to set to these colours
        ; NETWORK
        ; Need to set up WIFI
        ; M587 S"SSID" P"PWD"
        ; This needs to be as a first step via USB like when fw ver is checked
        ; It is permanently stored in the card after that
        ; https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet
        M550 P"voron2"          ; set printer name
        M552 S1                                          ; enable network
        M586 P0 S1                                       ; enable HTTP (for DWC)
        M586 P1 S1                                       ; enable FTP (for remote backups)
        M586 P2 S0                                       ; disable Telnet
        ; DRIVERS
        ; --- Z Drive map ---
        ;    B_______A
        ;    | 1 | 2 |
        ;    | 0 | 3 |
        ;      front
        ; (looking at the printer from the top)
        ; Driver directions
        ; M569: Set motor driver direction, enable polarity and step pulse timing
        ; This command has LOT of parameters ... e.g. stealthChop2 ...
        ; Pnnn 		Motor driver number
        ; Snnn		Direction of movement 0 = backwards, 1 = forwards (default 1)
        M569 P121.0 S1 D2                                ; E - physical drive 121.0 goes forwards
        M569 P0.2 S1 D2                                  ; Should be 0, testing with 2 A -> Y - physical drive 0.0 goes forwards
        M569 P0.1 S1 D2                                  ; B -> X - physical drive 0.1 goes forwards
        M569 P0.3 S1 D2                                  ; Z0 - physical drive 0.3 goes forwards
        M569 P0.4 S0 D2                                  ; Z1 - physical drive 0.4 goes backwards
        M569 P0.5 S1 D2                                  ; Z2 - physical drive 0.5 goes forwards
        M569 P0.6 S0 D2                                  ; Z3 - physical drive 0.6 goes backwards
        M584 X0.2 Y0.1 Z0.3:0.4:0.5:0.6 E121.0           ; set drive mapping
        M350 X16 Y16 Z16 E16 I1                          ; configure microstepping with interpolation
        M92 X160.00 Y160.00 Z400.00 E400.00              ; set steps per mm
        ; Accelerations and speed are set in separate macro
        M98 P"/macros/set_normal_speed.g"
        ; Stepper driver currents
        ; set motor currents (mA) and motor idle factor in per cent
        ; Drive currents
        M906 X1200 Y1200 Z1200 E500 I70 ; XYZ and E current
        M84 S120                        ; Idle timeout
        ; Xn,Yn endstop: 0 = none, 1 = low end, 2 = high end
        ; Snnn 	1 = switch-type (eg microswitch) endstop input
        ;		2 = Z probe (when used to home an axis other than Z)
        ;		3 = single motor load detection
        ;		4 = multiple motor load detection (see Notes)
        ; P"pin_name"
        M574 X2 S1 P"^121.io0.in"                       ; configure active-high endstop for high end on X via pin ^121.io0.in
        M574 Y2 S1 P"^0.io1.in"                         ; configure active-high endstop for high end on Y via pin ^io1.in
        M574 Z0 p"nil"                                  ; No Z endstop
                                                        ; Extruder never stops :-)
        ; Axis travel limits                            ; Mind this is travel NOT print area
        M208 X0:300 Y0:305 Z-5:265                       ; Set axis minima - negative X is to have 0,0 on bed corner
                                                        ; WARNING on Z not to hit the roof - this is set here
        ; Belt Locations
        M671 X-65:-65:365:365 Y0:395:395:0 S20      ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right)
        											; Position of the bed leadscrews.. 4 Coordinates
        											; Snn Maximum correction to apply to each leadscrew in mm (optional, default 1.0)
        											; S20 - 20 mm spacing
        M557 X30:270 Y30:270 S40					; Define bed mesh grid (inductive probe, positions include the Y offset!)
        ; Bed heater
        M308 S0 P"temp0" Y"thermistor" T100000 B3950     ; configure sensor 0 as thermistor on pin temp0
        M950 H0 C"out0" Q10 T0                               ; create bed heater output on out0 and map it to sensor 0
        M307 H0 B0 R0.607 C340.7 D1.16 S1.00 V24.1
        ;M307 H0 B1 S1.00                                 ; Enable bang-bang mode for the bed heater and set PWM limit
        M140 H0                                          ; map heated bed to heater 0
        M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
        ; Hotend heater
        M308 S1 P"121.temp0" Y"thermistor" T100000 B4267 ; configure sensor 1 as thermistor on pin 121.temp0
        M950 H1 C"121.out0" T1                           ; create nozzle heater output on 121.out0 and map it to sensor 1
        M307 H1 B0 R3.391 C160.1:134.1 D4.20 S1.00 V23.8
        ;M307 H1 B0 S1.00                                 ; disable bang-bang mode for heater  and set PWM limit
        M143 H1 S280                                     ; set temperature limit for heater 1 to 280C
        ; SENSORS MISC
        ; Define MCU sensors which will be available in DWC Extra View
        M308 S3 A"MCU" Y"mcu-temp" 				; Officially NOT supported on Mini 3 5+ however seem to work
        M308 S4 A"Duet Drivers" Y"drivers" 		; This is not really working as it is just a threshold crossing
        ; CHAMBER SENSOR
        M308 S10 A"Chamber" P"0.temp2" Y"thermistor" T100000 B3950
        ; Z PROBES K0 (Klicky mag probe) and K1 (Microswitch Z0)
        ; M558: Set Z probe type
        	; P5/P8 	select a switch by default (normally closed) for bed probing between the In and Gnd pins of the Z-probe connector
        	; C			specifies the input pin and the optional modulation pin. This parameter is mandatory
        	; Tnnn 		Travel speed to and between probe points (mm/min)
        	; Fnnn 		Feed rate (i.e. probing speed, mm/min) e.g. 60 is one mm per second
        	; Hnnn 		Dive height (mm)
        	; Annn 		Maximum number of times to probe each point, default 1
        	; Snnn 		Tolerance when probing multiple times, default 0.03mm
        	; Rnnn 		Z probe recovery time before the probing move is started , default zero (seconds)
        	; B0		B1 Turn off all heaters while probing, default (B0) leaves heaters on.
        	; I0		Invert (I1) or do not invert (I0, default) the Z probe reading
        ; G31: Set Current Probe status
        	; K0		Z Probe Number
        	; Pnnn 		Trigger value
        	; Xnn Ynn 	Probe offset (from Noozle)
        	; Znnn 		Trigger Z height - Set the said Z when the probe triggers !!
        ; MAG PROBE (GND, IO)
        ; This is the mag probe with microswitch in Afterburner
        M558 K0 P8 C"^121.io2.in" T18000 F180 H10 A10 S0.0025
        G31 K0 P500 X0 Y20 Z7.612
        ; Z-SWITCH
        ; This is the microswitch which is pressed by the Noozle
        M558 K1 P8 C"^io5.in" T18000 F180 H3 A10 S0.0025 R0
        ; Omron micro switch
        G31 K1 P500 X0 Y0 Z1.20
        ; Part cooling fan
        M950 F0 C"121.out1"                              ; create fan 0 on pin 121.out1 and set its frequency
        M106 P0 S0 H-1                                   ; set fan 0 value. Thermostatic control is turned off
        ; Hotend fan
        M950 F1 C"121.out2"                              ; create fan 1 on pin 121.out2 and set its frequency
        M106 P1 S1 H1 T45                                ; set fan 1 value. Thermostatic control is turned on
        ; Controller fan 1
        M950 F2 C"out6"                                  ; create fan 2 on pin out5 and set its frequency
        M106 P2 S1.0 H3:4 T30 C"Controller fan 1"             ; controlled by Sensor 3 - MCU
        ; Controller fan 2
        M950 F3 C"out5"                                  ; create fan 3 on pin out6 and set its frequency
        M106 P3 S1 H0 T45                                ; set fan 3 value. Thermostatic control is turned on
        M563 P0 D0 H1                                    ; define tool 0
        G10 P0 X0 Y0 Z0                                  ; set tool 0 axis offsets
        G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
        ; Input shaper
        ;M593 F49
        ; Pressure advance
        ;M572 D0 S0.04
        ; defines global variables
        M98 P"/macros/define_global_vars.g"
        ; Load override parameters
        M501
        ; Sets normal speeds and acceleration for printing operation
        M566 X600 Y600 Z60 E8000        ; Set maximum instantaneous speed changes (mm/min) aka Jerk
        M203 X18000 Y18000 Z3000 E15000 ; Set maximum speeds (mm/min)
        M201 X5000 Y5000 Z250 E2000     ; Set maximum accelerations (mm/s^2)
        M204 P3000 T5000                ; Set printing acceleration and travel accelerations
        ; Macro for defining Global variables at start
        if !exists(global.bed_temp)
        	global bed_temp = heat.heaters[0].active
        if !exists(global.hotend_temp)
        	global hotend_temp = heat.heaters[1].active
        if !exists(global.magprobe_status)
        	global magprobe_status = "none"
        if !exists(global.job_completion)
        	global job_completion = 0
        ; output current values
        echo "global.bed_temp defined. Value : " , global.bed_temp
        echo "global.hotend_temp defined. Value : " , global.hotend_temp
        echo "global.magprobe_status defined. Value : " , global.magprobe_status
        echo "global.job_completion defined. Value : " , global.job_completion
        ; config-override.g file generated in response to M500 at 2021-09-26 01:04
        ; Heater model parameters
        M307 H0 R0.607 C340.700:340.700 D1.16 S1.00 V24.1 B0 I0
        M307 H1 R3.391 C160.075:134.066 D4.20 S1.00 V23.8 B0 I0
        ; Workplace coordinates
        G10 L2 P1 X0.00 Y0.00 Z0.00
        G10 L2 P2 X0.00 Y0.00 Z0.00
        G10 L2 P3 X0.00 Y0.00 Z0.00
        G10 L2 P4 X0.00 Y0.00 Z0.00
        G10 L2 P5 X0.00 Y0.00 Z0.00
        G10 L2 P6 X0.00 Y0.00 Z0.00
        G10 L2 P7 X0.00 Y0.00 Z0.00
        G10 L2 P8 X0.00 Y0.00 Z0.00
        G10 L2 P9 X0.00 Y0.00 Z0.00
        config (2).g
        set_normal_speed.g
        config-override.g
          Gixxerfast
          Btw, this is marked as solved but I can't see any solutions in there. (it's a long thread so I could have missed it)
          https://forum.duet3d.com/topic/22436/missing-steps-cant-print-spreadcycle-stealthchop-tuning-help
          Seems like I am in the same boat...
          • fcwiltundefined
            fcwilt @Gixxerfast
            @gixxerfast
            I got four printers running RRF v3.3 and two of them are using Mini 5+ boards.
            Layer shift is not a problem.
            So its not a fundamental RRF or Duet problem.
            Which leaves us with something about your hardware, your configuration or some of each.
            If you post your files using the </> tag it makes it easy for anyone to take a look, as opposed to having to download and open in some editor.
            Gixxerfastundefined 1 Reply Last reply Reply Quote 0
              Gixxerfast @fcwilt
              @fcwilt Hi, yes I don't think there's a general problem with the mini5+
              BUT, reading from and talking with quite a few, there's seem to be a problem with 0.9 steppers and the mini5+(TMC2209) / rrf.
              Do you run 0.9 degrees stepper motors+
              • fcwiltundefined
                fcwilt @Gixxerfast
                @gixxerfast said in RRF v3.3/Mini 5+ Wifi - Major problems with layer shifting:
                No except for one extruder.
                Does it appear to be a hardware or firmware compatibility problem with the Mini 5+ and 0.9 steppers?
                  Gixxerfast @fcwilt
                  @fcwilt I should actually amend my comment. It could be old topics. So I really don't know and shouldn't make such statements.
                  It's getting late 🙂 I might have to edit this a bit tomorrow 🙂
                  Cheers
                  mrehorstdmdundefined 1 Reply Last reply Reply Quote 1
                  • T3P3Tonyundefined
                    T3P3Tony administrators @Gixxerfast
                    @gixxerfast I get your frustration! especially with those long prints. What we need to work out is what is the root cause of the layer shifts, is it:
                    a) the print head knocking on the print so there is in issue with Z motion of some sort or
                    b) the XY motion.
                    Initially I went down the rabbit hole of Z motion due to the mentions of mesh bed levelling being in question, you mentioned the nozzle grinding on the prints, and at least one image looked like squashed layers. I now am not sure about that because of:
                    As you have already pointed out that indicates something with the XY motion, not Z. You have also checked the connector, are confident about the wiring and tried a different driver which eliminates quite a few possibilities also the fact you only see it on the more complex prints makes some causes less likely.
                    From the look of your new pictures the layer shifts are cumulative, always in the one direction?
                    I know you have already swapped X from D0 to D2 without resolving the problem. Can you try the following:
                    Swap the X and Y drivers and motor cables and see if the issue stays the same place or changes to layer shifts in the opposite direction
                    M584 X0.1 Y0.0 Z0.3:0.4:0.5:0.6 E121.0
                    I have used the driver 0 for the swap here but you can use driver 2 as you currently have it configured if you prefer. The idea is that you change Y and X, not just X.
                    When/if the layer shifts are happening please do the following:
                    1. Send M906 and M913 with no parameters and confirm that the currents are as expected and at 100%.
                    2. Send M569 P1 and M569 P0 (or P2 if you are using driver 2) and posts the results here.
                    3. Send M122 and post the results here.
                    www.duet3d.com
                    Gixxerfastundefined 2 Replies Last reply Reply Quote 0
                      Gixxerfast @T3P3Tony
                      @t3p3tony said in RRF v3.3/Mini 5+ Wifi - Major problems with layer shifting:
                      Send M122
                      Hi, thanks for the reply even on a saturday 🙂
                      I'm in the middle of testing again, but I haven't switched the cables as you suggested just yet as it requires a bit of printer disassembly (quite a bit). I will do it later.
                      However, I'm starting to wonder if I have beed barking up the wrong tree. With a corexy, if it shifts to -x/-y couldn't that suggest that it's the A-motor (y-motor right one) that is skipping steps when trying to do a non-diagonal move?
                      Is this something to worry about, btw?
                      • T3P3Tonyundefined
                        @gixxerfast I will have to get @dc42 's opinion on the failedOp 0x01 error.
                        www.duet3d.com
                        • mrehorstdmdundefined
                          mrehorstdmd @Gixxerfast
                          @gixxerfast Z axis jerk (1 mm/sec) and acceleration (250 mm/sec^2) seem awfully low to me. Maybe the nozzle is dragging on the print when the layer changes or when you use lift on retract...
                            @t3p3tony
                            Latest shift after z 5mm. Going to check y-motor, crimps and switch driver for that.
                            Need to get myself an easier testprint.
                            Cable switching is after that. (The y-motor cable is shorter than the x-motor cable)
                            021-10-09 14:24:38	M98 P"0:/macros/test/motorcheck.g"
                            Motor current % of normal - X:100, Y:100, Z:100, E:100
                            Drive 1 runs forwards, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 920
                            Drive 2 runs forwards, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 56
                            Used output buffers: 3 of 40 (30 max)
                            Static ram: 102724
                            Dynamic ram: 115376 of which 0 recycled
                            Never used RAM 22748, free system stack 120 words
                            Tasks: NETWORK(ready,17.0%,226) HEAT(delaying,0.0%,344) Move(notifyWait,2.5%,272) CanReceiv(notifyWait,0.0%,773) CanSender(notifyWait,0.1%,357) CanClock(delaying,0.0%,338) TMC(notifyWait,1.4%,72) MAIN(running,77.6%,400) IDLE(ready,0.4%,29) AIN(delaying,0.9%,264), total 100.0%
                            Owned mutexes: HTTP(MAIN)
                            Last reset 01:53:49 ago, cause: software
                            Last software reset at 2021-10-09 12:30, reason: User, GCodes spinning, available RAM 24252, slot 0
                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00487000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                            Error status: 0x00
                            MCU revision 3, ADC conversions started 6827511, completed 6827511, timed out 0, errs 0
                            Step timer max interval 751
                            MCU temperature: min 31.1, current 31.5, max 31.5
                            Heap OK, handles allocated/used 99/31, heap memory allocated/used/recyclable 2048/680/220, gc cycles 2
                            Driver 0: position 43187, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 19, reads 18270, writes 0, timeouts 0, DMA errors 0
                            Driver 1: position 3882, standstill, SG min/max 0/138, read errors 0, write errors 0, ifcnt 59, reads 18270, writes 0, timeouts 0, DMA errors 0
                            Driver 2: position 1972, ok, SG min/max 0/140, read errors 0, write errors 0, ifcnt 59, reads 18271, writes 0, timeouts 0, DMA errors 0
                            Driver 3: position 0, standstill, SG min/max 0/6, read errors 0, write errors 0, ifcnt 53, reads 18270, writes 0, timeouts 0, DMA errors 0
                            Driver 4: position 0, standstill, SG min/max 0/6, read errors 0, write errors 0, ifcnt 53, reads 18270, writes 0, timeouts 0, DMA errors 0
                            Driver 5: position 0, standstill, SG min/max 0/16, read errors 0, write errors 0, ifcnt 53, reads 18270, writes 0, timeouts 0, DMA errors 0
                            Driver 6: position 0, standstill, SG min/max 0/4, read errors 0, write errors 0, ifcnt 53, reads 18270, writes 0, timeouts 0, DMA errors 0
                            Date/time: 2021-10-09 14:24:35
                            Slowest loop: 7.46ms; fastest: 0.07ms
                            === Storage ===
                            Free file entries: 8
                            SD card longest read time 4.2ms, write time 0.0ms, max retries 0
                            === MainDDARing ===
                            Scheduled moves 380245, completed moves 380205, hiccups 0, stepErrors 0, LaErrors 0, Underruns [403, 4, 0], CDDA state 3
                            === AuxDDARing ===
                            Segments left: 1
                            HTTP is ready with "M122" in state(s) 0 0, running macro
                            File is doing "G1 X135.826 Y123.358 E0.02813" in state(s) 0
                            === CAN ===
                            Messages queued 22392, received 2415, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 278, free buffers 17 (min 3), ts 1006/1006/0
                            === Network ===
                            Slowest loop: 201.41ms; fastest: 0.06ms
                            Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                            - WiFi -
                            Failed messages: pending 0, notready 0, noresp 8
                            WiFi flash size 2097152, free heap 25616
                            Socket states: 2 0 0 0 0 0 0 0
                              Gixxerfast @mrehorstdmd
                              @mrehorstdmd
                              Hmm, it's all stolen from allegedly working setups:-)
                              M203 X12000 Y12000 Z3000 E15000 ; Set maximum speeds (mm/min)
                              M201 X4000 Y4000 Z250 E2000     ; Set maximum accelerations (mm/s^2)
                              M204 P3000 T4000                ; Set printing acceleration and travel accelerations
                              I'll recheck those. I have a belted z and four z-motors so fast z-movements shouldn't be a problem. DO you have a suggestion?
                              I could up the z-acc to my old Klipper-value which was 350 mm/s2. I have no idea what a good jerk value would be.
                                @t3p3tony
                                Well, shifted A cables to B-motor and vice versa. And reconfigured th emotor assignment as described.
                                But no, same thing. It shifted in the same direction.
                                So I made a descision to change motors to 1.8 degr OMC motors. It seems like I just can't get it to work with the LDO 0.9 degr steppers.
                                Anyway, I'm posting the output so that anyone that wants can maybe find out what's not working.
                                Here's the output from before the shifted print
                                BEFORE
                                2021-10-09 18:51:44	M98 P"0:/macros/test/motorcheck.g"
                                Register 0x06 value 0x21000048
                                Register 0x06 value 0x21000040
                                Register 0x06 value 0x2100004c
                                Register 0x06 value 0x21000044
                                Motor current (mA) - X:1200, Y:1200, Z:1200, E:400, idle factor 70%
                                Drive 0 runs forwards, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 936
                                Drive 2 runs forwards, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 392
                                Used output buffers: 3 of 40 (12 max)
                                Static ram: 102724
                                Dynamic ram: 113440 of which 0 recycled
                                Never used RAM 24684, free system stack 200 words
                                Tasks: NETWORK(ready,10.2%,238) HEAT(delaying,0.0%,380) Move(notifyWait,0.1%,362) CanReceiv(notifyWait,0.0%,798) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,352) TMC(delaying,1.1%,115) MAIN(running,85.9%,426) IDLE(ready,1.8%,29) AIN(delaying,0.8%,264), total 100.0%
                                Owned mutexes: WiFi(NETWORK) HTTP(MAIN)
                                Last reset 00:00:17 ago, cause: software
                                Last software reset at 2021-10-09 18:51, reason: User, GCodes spinning, available RAM 24252, slot 0
                                Error status: 0x00
                                MCU revision 3, ADC conversions started 17941, completed 17941, timed out 0, errs 0
                                Step timer max interval 752
                                MCU temperature: min 28.6, current 29.5, max 29.8
                                Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                Heap OK, handles allocated/used 99/5, heap memory allocated/used/recyclable 2048/232/162, gc cycles 0
                                Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 116, reads 1577, writes 12, timeouts 0, DMA errors 0
                                Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 49, reads 1579, writes 9, timeouts 0, DMA errors 0
                                Driver 2: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 116, reads 1576, writes 12, timeouts 0, DMA errors 0
                                Driver 3: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 110, reads 1576, writes 12, timeouts 0, DMA errors 0
                                Driver 4: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 112, reads 1576, writes 12, timeouts 0, DMA errors 0
                                Driver 5: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 110, reads 1576, writes 12, timeouts 0, DMA errors 0
                                Driver 6: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 110, reads 1576, writes 12, timeouts 0, DMA errors 0
                                Date/time: 2021-10-09 18:51:40
                                Cache data hit count 32653113
                                Slowest loop: 4.75ms; fastest: 0.12ms
                                === Storage ===
                                Free file entries: 9
                                SD card longest read time 3.5ms, write time 0.0ms, max retries 0
                                === MainDDARing ===
                                === AuxDDARing ===
                                Segments left: 0
                                === CAN ===
                                Messages queued 169, received 202, lost 0, longest wait 2ms for reply type 6031, peak Tx sync delay 240, free buffers 17 (min 16), ts 89/88/0
                                === Network ===
                                Slowest loop: 20.47ms; fastest: 0.00ms
                                - WiFi -
                                WiFi flash size 2097152, free heap 25880
                                WiFi signal strength -57dBm, mode 802.11n, reconnections 0, sleep mode modem
                                After:
                                After:
                                2021-10-09 20:23:58	M98 P"0:/macros/test/motorcheck.g"
                                Register 0x06 value 0x21000248
                                Register 0x06 value 0x21000240
                                2021-10-09 20:23:59	Motor current (mA) - X:1200, Y:1200, Z:1200, E:400, idle factor 70%
                                Drive 0 runs forwards, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 56
                                Drive 2 runs forwards, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 824
                                Static ram: 102724
                                Never used RAM 22748, free system stack 114 words
                                Tasks: NETWORK(ready,15.9%,226) HEAT(delaying,0.0%,344) Move(notifyWait,1.4%,272) CanReceiv(notifyWait,0.0%,773) CanSender(notifyWait,0.1%,357) CanClock(delaying,0.0%,338) TMC(notifyWait,1.3%,72) MAIN(running,80.1%,415) IDLE(ready,0.2%,29) AIN(delaying,0.9%,264), total 100.0%
                                Last reset 01:32:33 ago, cause: software
                                Error status: 0x00
                                MCU revision 3, ADC conversions started 5551983, completed 5551983, timed out 0, errs 0
                                Step timer max interval 954
                                MCU temperature: min 28.6, current 32.2, max 32.4
                                Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/1616/1178, gc cycles 1
                                Driver 0: position 47774, ok, SG min/max 0/478, read errors 0, write errors 0, ifcnt 130, reads 44394, writes 14, timeouts 0, DMA errors 0
                                Driver 1: position 3742, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 49, reads 44409, writes 0, timeouts 0, DMA errors 0
                                Driver 2: position 1985, ok, SG min/max 0/490, read errors 0, write errors 0, ifcnt 130, reads 44395, writes 14, timeouts 0, DMA errors 0
                                Driver 3: position 0, standstill, SG min/max 0/62, read errors 0, write errors 0, ifcnt 125, reads 44393, writes 15, timeouts 0, DMA errors 0
                                Driver 4: position 0, standstill, SG min/max 0/52, read errors 0, write errors 0, ifcnt 127, reads 44394, writes 15, timeouts 0, DMA errors 0
                                Driver 5: position 0, standstill, SG min/max 0/54, read errors 0, write errors 0, ifcnt 125, reads 44394, writes 15, timeouts 0, DMA errors 0
                                Driver 6: position 0, standstill, SG min/max 0/66, read errors 0, write errors 0, ifcnt 127, reads 44392, writes 17, timeouts 0, DMA errors 0
                                Date/time: 2021-10-09 20:23:56
                                Slowest loop: 211.33ms; fastest: 0.07ms
                                === Storage ===
                                SD card longest read time 4.5ms, write time 0.0ms, max retries 0
                                DMs created 83, maxWait 262933ms, bed compensation in use: none, comp offset 0.000
                                === MainDDARing ===
                                Scheduled moves 378342, completed moves 378302, hiccups 0, stepErrors 0, LaErrors 0, Underruns [3832, 33, 1], CDDA state 3
                                === AuxDDARing ===
                                Segments left: 1
                                File is doing "G1 X159.839 Y151.486 E0.00557" in state(s) 0
                                === CAN ===
                                Messages queued 386228, received 66906, lost 0, longest wait 1ms for reply type 6013, peak Tx sync delay 291, free buffers 17 (min 3), ts 27680/27680/0
                                === Network ===
                                Slowest loop: 201.61ms; fastest: 0.06ms
                                - WiFi -
                                Failed messages: pending 0, notready 0, noresp 1
                                WiFi flash size 2097152, free heap 22224
                                WiFi signal strength -55dBm, mode 802.11n, reconnections 0, sleep mode modem
                                  Gixxerfast
                                  EDIT: I almost forgot. I'm an ungrateful git. Big thanks to everyone that has helped trying to pinpoint the problem.
                                  Finally! Swapped out the Voron branded 0.9 LDO 42STH40-2004MAC with the OMC 17HS19-2004S1 1.8 degr motors and YES it comes out as it should. Btw, all grub screws and pullies were rock solid. The belts ran super smooth and was even and the gantry wasn't racked but super square
                                  I removed all drive mod config (D2 etc..) and just ran it vanilla.
                                  Much more silent as well 🙂
                                  Conclusion (I hope), must be after 20 something failed prints that either this setup just doesn't work with these 0.9 degr stepper motors unless you configure it some way unknown to me or I have faulty motors. Then again I came from a fast working setup where I regulary printed with 5000+ acceleration with these.
                                  I just don't know. I just hope this is history for me now 🙂
                                  aprzundefined 1 Reply Last reply Reply Quote 1
                                  • JADoglioundefined
                                    JADoglio
                                    I had this problem a few months ago. To fix it I had to replace the Y stepper motor. It was apparently missing steps many steps then starting up again. I suppose it could have been a connector but I used the same connector on the new motor and had no issues after that.
                                    • aprzundefined
                                      aprz @Gixxerfast
                                      @gixxerfast I wonder if replacing the PSU with a higher Voltage (36v-48v) would help? I have this problem on my corexy and can only print at 60mm/s which is slow compared to what other printers can do. I'm also using 0.9 degree motors. I'm thinking of doing what you did and changing the motors to 1.8 deg motors. this post was helpful.
                                        Gixxerfast @aprz
                                        @aprz I don't know if you can even do that. Guess it depends on which board you have.
                                        However I can't say if it would help but I think it's a hard way to go to fix something that might be fixed with other motors.
                                        I should have changed a long time ago but I was convinced it was an "upgrade" even though I see now that those motors do not belong on a 2.4 IMHO. The OMC BOM motors are quite affordable.
                                        I hope you can make it work better.
                                        60 mm/sec on a Voron, or really any good corexy, is painfully slow 😉
                                        Cheers
                                        • ignacmcundefined ignacmc referenced this topic
