    Extruder for DC/Kossel XL recommendations
    • JuJuDelta
      JuJuDelta last edited by
      Hi All,
      I have a Kossel XL, SmartEffector etc and the Flex3Drive (early model) is wearing out.
      https://flex3drive.com/product/g5-flex-for-duet-smart-effector/
      Is it worth replacing with a newer one?
      If so, what material SLS, SLA or FDM?
      Or, can you recommend something else?
      Thanks,
      J.
      T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
      o_lampe 1 Reply Last reply Reply Quote 0
        @jujudelta how about a flying extruder with an Orbiter?
        My Kossel XL still uses a Bowden extruder. In the longer term I want to make a larger Smart Effector that can carry an Orbiter.
        oliof 1 Reply Last reply Reply Quote 0
        • o_lampe
          o_lampe @JuJuDelta last edited by o_lampe
          @jujudelta I've designed a smart-effector replacement with an offset for the heatsink. Now I can use a sherpa-mini extruder as direct drive extruder. The stepper doesn't foul the mag-rods, because of the offset
          Only downside is, that it now needs a different Z-probe. I chose an 18mm capacitive probe, but a mini-IR Z-probe or BL-Touch would be fine, too.
          • oliof
            oliof @dc42 last edited by
            @dc42 orbiter 2.0 (to be released Real Soon Now) will have a smaller footprint than 1.x -- maybe that'll fit the smart effector as is.
            <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
            • JuJuDelta
              Both those extruders look excellent.
              I really like how they open up easily to clean the hobbed gears.
              On my Flex3drive it's a complete strip down.
              I'm a great fan of the Smart Effector built in Z Probe, it works for me.
              When I loose patience (soon) with my current extruder I will look to implement either an Orbiter or Sherpa as a flying extruder.
              Thanks for your recommendations Guys!
              Plenty of ideas here:
              https://www.thingiverse.com/search?q=orbiter+extruder&type=things&sort=relevant
              • amjm22
                amjm22 last edited by
                I'm using an Orbiter 1.5 mounted to Duet 3D Smart Effector. It has a 58mm Bowden20211006_181228.jpg tube(very minimal) E3d .6 nozzle and all-metal hotend.
