    Part cooling and extruder fans won't turn on
    110
    • Messiahman
      Messiahman last edited by
      Hey all, as the title suggests I can't seem to get my fans to turn on even while printing. They are plugged into the PWM slots on the duet board, and utilize the same code that originally worked prior to my first board burning out. Is there any chance the fans themselves might be broken? Or is there anything wrong with my config.g code below:
      config.g
      T3P3Tony 2 Replies Last reply Reply Quote 0
      • T3P3Tony
        T3P3Tony administrators @Messiahman last edited by
        @messiahman config.g here to make it easier to review:
        ; generated by RepRapFirmware Configuration Tool v3.3.3 on Wed Oct 06 2021 12:37:23 GMT-0400 (Eastern Daylight Time)
        M550 P"The Print-inator"                           ; set printer name
        M918 P1 E4 F2000000                                ; configure direct-connect display
        M569 P0 S0                                         ; physical drive 0 goes backwards
        M569 P1 S0                                         ; physical drive 1 goes backwards
        M569 P2 S0                                         ; physical drive 2 goes backwards
        M569 P3 S1                                         ; physical drive 3 goes forwards
        M584 X0 Y1 Z2 E3                                   ; set drive mapping
        M92 X80.00 Y80.00 Z400.00 E136.79                  ; set steps per mm
        M566 X1200.00 Y1200.00 Z24.00 E300.00              ; set maximum instantaneous speed changes (mm/min)
        M203 X9000.00 Y9000.00 Z180.00 E6000.00            ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z100.00 E5000.00              ; set accelerations (mm/s^2)
        M906 X800 Y800 Z800 E1000 I50                      ; set motor currents (mA) and motor idle factor in per cent
        M208 X235 Y235 Z260 S0                             ; set axis maxima
        M574 X2 S1 P"xstop"                                ; configure active-high endstop for high end on X via pin xstop
        M574 Y2 S1 P"ystop"                                ; configure active-high endstop for high end on Y via pin ystop
        M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
        M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
        M558 P9 C"^zprobe.in" H3 F120 T6000                ; set Z probe type to bltouch and the dive height + speeds
        G31 P500 X4.35 Y0.5 Z2.5                           ; set Z probe trigger value, offset and trigger height
        M557 X5:185 Y15:215 S36                            ; define mesh grid
        M308 S0 P"bedtemp" Y"thermistor" T100000 B4092     ; configure sensor 0 as thermistor on pin bedtemp
        M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
        M143 H0 S150                                       ; set temperature limit for heater 0 to 150C
        M308 S1 P"e0temp" Y"thermistor" T100000 B4092      ; configure sensor 1 as thermistor on pin e0temp
        M143 H1 S275                                       ; set temperature limit for heater 1 to 275C
        M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
        M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
        M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
        M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
        M950 F2 C"fan2" Q500                               ; create fan 2 on pin fan2 and set its frequency
        M106 P2 S1 H1:0 T45                                ; set fan 2 value. Thermostatic control is turned on
        M501                                               ; load saved parameters from non-volatile memory
        www.duet3d.com
        • T3P3Tony
          @messiahman the config looks ok at first review. I assume if you send M106 P0 S1.0 you get noe movement from that fan? Its possible that whatever damaged your first board also damaged the fans
          www.duet3d.com
          Messiahman 1 Reply Last reply Reply Quote 0
          • Messiahman
            Messiahman @T3P3Tony last edited by
            @t3p3tony Ahhh thats what I figured, I killed it with the ol' 5v to Gnd when setting up a bltouch, i figured I wouldn't get out unscathed. What fans would you suggest I get as replacement?
            • T3P3Tony
              @messiahman if the old ones worked well then no reason to not get the same type. Before being 100% sure its the fans though you could try connecting the to the "always on fan" port to see if they are definitely dead
              www.duet3d.com
              Messiahman 2 Replies Last reply Reply Quote 0
              • Messiahman
                @t3p3tony That makes sense, I just figured they were stock for an Ender 3 Pro so I wasn't sure if it would be possible. Thank you for your time, I'll let you know if they work when I get back to my printer.
                • Messiahman
                  @t3p3tony Yeah no, I plugged them into the always on port and homed my printer and they still aren't moving, so I guess it's safe to assume they're gone?
                  • T3P3Tony
                    @messiahman just thought, on the Duet 2 there is a fuse just for the fans, it could be that. please check it.
                    www.duet3d.com
                    • Messiahman
                      @t3p3tony which would it be?
                      • T3P3Tony
                        www.duet3d.com
                        • Messiahman
                          @t3p3tony I had to open mine up to take a look at the inside because it was all black, so I probably do now need a new one, but this one doesn't appear to have had any wiring on the inside, so I'll go with there's a possibility it was the fuse being that it doesnt appear to have insides
                          • Messiahman
                            @t3p3tony Which isstrange because it was basically brand new, nothing got damaged this time around
                            • T3P3Tony
                              @messiahman that is very weird. where did you get the board?
                              www.duet3d.com
                              • Messiahman
                                @t3p3tony Filastruder
                                • T3P3Tony
                                  @messiahman do you happen to have a spare 1A or 2A mini blade fuse to try in that slot?
                                  www.duet3d.com
                                  • Messiahman
                                    @t3p3tony I do not, unfortunately. I did just order a pack of 1A fuses online, but that says it will ship on the 20th. I can ask around and see if any of my friends have though
                                    • Messiahman
                                      @t3p3tony One of my friends had a 2A and after plugging it in the fans work perfectly fine, thank you so much!
                                      • T3P3Tony
                                        @messiahman ok great news.
                                        www.duet3d.com
