    What leadscrew?
    • zapta
      zapta last edited by
      RRF seems to assume that Z movement is done with lead-screws and prints messages like the one below. With the increasing popularity of Z-belts, may be useful to revisit the wording.
      Leadscrew adjustments made: 0.029 0.011 -0.001 0.008, points used 4, (mean, deviation) before (0.014, 0.006) after (0.000, 0.000)
      Current deviation: 0.006
      https://github.com/Duet3D/RepRapFirmware/blob/dev/src/Movement/Kinematics/ZLeadscrewKinematics.cpp#L307
      fcwilt 1 Reply Last reply Reply Quote 1
      • fcwilt
        fcwilt @zapta last edited by
        @zapta said in What leadscrew?:
        Is that happening?
        I know having used Z belts on a recent printer upgrade that is the way I would go in the future.
        zapta o_lampe 2 Replies Last reply Reply Quote 0
        • zapta
          zapta @fcwilt last edited by zapta
          @fcwilt said in What leadscrew?:
          Is that happening?
          I think so. I am judging from the Voron 2.4 which is becoming the flagship model of open source community designs. The main advantage I heard about is the lack of z banding, and it uses gearing to avoid the gantry dropping down when the printer is turned off.
          • o_lampe
            o_lampe @fcwilt last edited by
            @fcwilt On my hashPrinter I opted for Z-belt mechanism, just because they can be made in any length and it doesn't hurt ($$$) to cut the belt.
            Also having the chance to home Z to max at high speed is a plus.
