    Toolboard v1.1 Fan Question
    • dhusolo
      dhusolo last edited by
      Duet 3 RRF3.3
      SBC Rpi4
      Toolboard v1.1
      I have dual 24v 4010 blowers for layer cooling. Because there's only 2 12/24v fan outputs I have to splice the fans together. I have an inductive sensor as a probe so my Io0.out is open. I was wondering if it's possible to connect the hotend fan's positive wire to VIN and use Io0.out to control it thermostatically?
      jay_s_uk T3P3Tony 2 Replies Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @dhusolo last edited by
        @dhusolo no, as theres no mosfet to control it. What do you need 3 fans for?
        • T3P3Tony
          T3P3Tony administrators @dhusolo last edited by T3P3Tony
          @dhusolo as @jay_s_uk says thats not possible those IOs work at 5V and can only source/sink a few mA.
          There should be no issue running both part cooling fans from out 1 or out 2 at 24V in parallel (obviously with the jumper set for VIN and 24V supplied to the toolboard)
          www.duet3d.com
