    How to run PID for BED
    • Paskal
      Paskal last edited by
      Hi please how to run PID tuning for BED ?
      M303 T0 S205 runnig hotend, but not bed.
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.4 on Tue Oct 12 2021 18:38:52 GMT+0200 (Středoevropský letní čas)
      M550 P"Hypercube" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S1 ; physical drive 1 goes forwards
      M569 P4 S0 ; physical drive 4 goes backwards
      M584 X0 Y1 Z2:4 E3 ; set drive mapping
      M92 X80.00 Y80.00 Z1600.00 E415.00 ; set steps per mm
      M566 X600.00 Y600.00 Z120.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E3000.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z200.00 E2500.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X350 Y340 Z260 S0 ; set axis maxima
      M671 X-10:370 Y160:160 S0.5
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
      G31 P600 X0 Y0 Z2.7 ; set Z probe trigger value, offset and trigger height
      M557 X15:350 Y15:340 S80 ; define mesh grid
      M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermistor on pin e0temp
      M106 P0 S1 H1 T40 ; set fan 0 value. Thermostatic control is turned on
      M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
      M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
      M563 P0 D0 H1 F0:1 ; define tool 0
      SIam 1 Reply Last reply Reply Quote 0
      • SIam
        SIam @Paskal last edited by
        @paskal said in How to run PID for BED:
        use M303 H0 S80
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        Paskal 1 Reply Last reply Reply Quote 0
        • Paskal
          Paskal @SIam last edited by
          @siam said in How to run PID for BED:
          M303 H0 S80
          Ok 😄 ... thx
