    Any future updates for 1xd and 3hc expansion boards?
    Hardware wishlist
    • aprz
      aprz last edited by
      Will there be updates for the 1xd and 3hc boards? I’m in need of higher voltage than the max 48v for 1xd and 32v for 3hc.
      • T3P3Tony
        T3P3Tony administrators @aprz last edited by
        @aprz As it stands we are not planning on supporting higher than 48V on the 1XD. If your motors need >48V then you need to use a separate supply for the 1XD. If you have a brake on the motor then it may need 24V which would work for the 1XD as well.
        The 3HC is unlikely to have a change to >32V soon, but we are looking at maximum voltages for the boards that use the TMC2160 drivers to review the changes needed to go to 48V safely. Our closed loop board that uses a TMC2160 and is in beta uses a TMC 2160 and has a maximum input of 48V
        www.duet3d.com
