    Solved Duet3 6MB U Axis Homing
    64
    • neo0204
      neo0204 last edited by
      Hi
      I am trying to run a U-axis Cartisian configuration. It was working fine when I was using Sensorless homing but when I changed the homing with a 5V inductive end-stop it stopped working. The U-Axis does not move for homing.
      I am using a similar 5V inductive end-stop switch for the X Y and Z-axis and they work fine with them.
      Config.h
      ; Configuration file for Duet 3 (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.2 on Mon Sep 27 2021 10:57:47 GMT+0100 (British Summer Time)
      G90                                      ; send absolute coordinates...
      M83                                      ; ...but relative extruder moves
      M550 P"H1.2"                             ; set printer name
      M552 P10.0.20.162 S1                     ; enable network and set IP address
      M553 P255.255.255.0                      ; set netmask
      M554 P10.0.20.1                          ; set gateway
      M586 P0 S1                               ; enable HTTP
      M586 P1 S0                               ; disable FTP
      M586 P2 S1                               ; enable Telnet
      M569 P0.0 S0                             ; physical drive 0.0 goes forwards
      M569 P0.1 S0                             ; physical drive 0.1 goes forwards
      M569 P0.2 S0                             ; physical drive 0.2 goes forwards
      M569 P0.3 S0                            ; physical drive 0.3 goes forwards
      M584 X0.0 Y0.1 Z0.2 U0.3                 ; set drive mapping
      M350 X16 Y16 Z16 U16 I1                  ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z80.00 U80.00         ; set steps per mm
      M566 X1000.00 Y1000.00 Z1000.00 U1000.00     ; set maximum instantaneous speed changes (mm/min)
      M203 X26000.00 Y26000.00 Z26000.00 U26000.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z500.00 U500.00     ; set accelerations (mm/s^2)
      M906 X2000 Y2000 Z800 U800 I30             ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                  ; Set idle timeout
      M208 X0 Y0 Z0 U0 S1                         ; set axis minima
      M208 X400 Y400 Z150 U150 S0                   ; set axis maxima
      M574 X1 S1 P"!io0.in"                    ; configure active-high endstop for low end on X via pin !io0.in
      M574 Y1 S1 P"!io1.in"                    ; configure active-high endstop for low end on Y via pin !io1.in
      M574 Z1 S1 P"!io2.in"                    ; configure active-high endstop for low end on Z via pin !io3.in
      M574 U2 S1 P"!io3.in"
      M558 P0 H5 F120 T6000                    ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                 ; define mesh grid
      Homeu.g
      G91
      G1 H1 U155.0 F2000 ; move quickly to X axis endstop and stop there (first pass)
      G90 ; absolute positioning
      Please advise on what I am doing wrong in the config.
      • T3P3Tony
        T3P3Tony administrators @neo0204 last edited by
        @neo0204 your config looks good after a quick look. Can you see what is reported with M119 when the endstop is not triggered, and then again when it is.
        www.duet3d.com
        neo0204 1 Reply Last reply Reply Quote 0
        • neo0204
          neo0204 @T3P3Tony last edited by
          I think the challenge is here, it senses the end-stop is always at Home.
          I have tried connecting the end-stop to other IO pins but the results were similar.
          • T3P3Tony
            @neo0204 try swapping the endstop with the X stop - the stop is probably faulty if it is identical to the others you use and its always showing as stopped
            www.duet3d.com
            neo0204 1 Reply Last reply Reply Quote 1
            • neo0204
              @t3p3tony This is what I did as the first hardware debug, Swap the X-axis and U-axis end-stop, and X homed but U has a similar response.
              • T3P3Tony
                @neo0204 The issue stayed with the U axis - so its not the sensor, but when you try other inputs on the Duet (like io4.in) the problem is not resolved?
                www.duet3d.com
                T3P3Tony neo0204 2 Replies Last reply Reply Quote 0
                • T3P3Tony
                  T3P3Tony administrators @T3P3Tony last edited by
                  @neo0204 also do you get any errors when you run your config.g using M98 P"0:/sys/config.g"
                  www.duet3d.com
                  • neo0204
                    The challenge is not resolved even when connecting to other IO ports.
                    M98 P"0:/sys/config.g" commands shows below response.
                    • T3P3Tony
                      @neo0204 which other port did you try?
                      www.duet3d.com
                      • neo0204
                        @t3p3tony Thank you for helping debug this.
                        It is working now, the issue was with the end-stop extender wire.
                        Apologies for the inconvenience.
                        • T3P3Tony
                          @neo0204 glad you got it fixed 👍
                          www.duet3d.com
