    Tool board Accelerometer
    245
    • dhusolo
      dhusolo last edited by
      I have a Tool board v1.1 and I'm trying to get the accelerometer and input shaping configured.
      I used Nuramori's PDF to determine layout.
      My config.g I have it defined as
      M955 P20.0 I14 ; +Y -X
      This is what I got for X
      G1 X-10 G4 S2 M956 P20.0 S1000 A0 G4 P10 G1 X110 F20000
      This is what I got for Y
      G1 Y0 G4 S2 M956 P20.0 S1000 A0 G4 P10 G1 Y110 F20000
      I'm not sure what I should config input shaping as
        dc42 administrators @dhusolo last edited by dc42
        @dhusolo try using firmware 3.4.0beta5 and the input shaping plugin instead of the accelerometer plugin.
        dhusolo 1 Reply Last reply Reply Quote 0
        • dhusolo
          dhusolo @dc42 last edited by
          @dc42 Are you referring to this plugin?
          jay_s_uk 1 Reply Last reply Reply Quote 0
          • jay_s_uk
            jay_s_uk @dhusolo last edited by
            @dhusolo yes, that one
            • dhusolo
              dhusolo @jay_s_uk last edited by
              @jay_s_uk And do install it copy the files and overwrite what's on the SD card or upload the ZIP directly into DWC?
              • jay_s_uk
                @dhusolo upload the zip directly to the system tab in DWC
                • dhusolo
                  @jay_s_uk Perfect thanks. I'll give it a shot when I get home from work
                  • dhusolo
                    I just ran it again with the input shaper plugin. I'm not really sure how to use the data to config input shaping.
                      @dhusolo your machine appears to have a large but fairly narrow resonance at about 49Hz on that axis. I suggest you try a ZVD shaper centred on that frequency.
                      • dhusolo
                        @dc42 So M593 P"zvd" F49.0?
                        Should I disable Pressure Advance? Currently it's set at M572 D0 S0.040
                          @dhusolo you can leave PA enabled but you may need to adjust the amount for best results.
