    duet 3d HC : Can Bus failed
    197
    • bast
      bast last edited by bast
      I uses a duet 6hc (sbc mode raspi4) + 5x 1XD + tool distribution board + 4x toolboard for a change tool 4 tool with external stepper in X, 2xY, 2xZ
      this morning by plugging in the machine to test the canbus connection no longer works on all external boards
      yesterday it works perfectly (programming switch for toolchanger dock)
      what will be the procedure to determine the failure please
      m122
      RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-956BA-NA3TJ-6JTDA-3SD6P-9A96T
      Used output buffers: 2 of 40 (15 max)
      Static ram: 150904
      Dynamic ram: 60600 of which 0 recycled
      Never used RAM 142688, free system stack 202 words
      Tasks: SBC(ready,42.2%,314) HEAT(delaying,0.0%,405) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,908) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,6.4%,93) MAIN(running,31.0%,922) IDLE(ready,20.3%,29), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:01:10 ago, cause: power up
      Last software reset at 2021-10-19 12:26, reason: User, GCodes spinning, available RAM 142264, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      Step timer max interval 14997
      MCU temperature: min 32.3, current 36.6, max 36.6
      Supply voltage: min 24.0, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Driver 0: position 0, standstill, reads 4622, writes 11 timeouts 0, SG min/max 0/0
      Driver 1: position 0, standstill, reads 4619, writes 14 timeouts 0, SG min/max 0/0
      Driver 2: position 0, standstill, reads 4622, writes 11 timeouts 0, SG min/max 0/0
      Driver 3: position 0, standstill, reads 4622, writes 11 timeouts 0, SG min/max 0/0
      Driver 4: position 0, standstill, reads 4622, writes 11 timeouts 0, SG min/max 0/0
      Driver 5: position 0, standstill, reads 4622, writes 11 timeouts 0, SG min/max 0/0
      Date/time: 2021-10-19 13:46:04
      Slowest loop: 10808.64ms; fastest: 0.00ms
      === Storage ===
      Free file entries: 10
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger* is doing "M950 J4 C"23.io0.in"" in state(s) 0 0, running macro
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 396, received 6, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 48), ts 352/0/0
      Tx timeouts 0,0,351,37,5,0 last cancelled message type 30 dest 127
      === SBC interface ===
      State: 0, failed transfers: 1, checksum errors: 0
      Last transfer: 15ms ago
      RX/TX seq numbers: 1668/1669
      SPI underruns 0, overruns 0
      Disconnects: 0, timeouts: 0, IAP RAM available 0x2c83c
      Buffer RX/TX: 2068/2660-0
      === Duet Control Server ===
      Duet Control Server v3.3.0
      Trigger:
      Buffered code: M950 J4 C"23.io0.in" ;Gpin4 = Tool 3 Dock switch (on Toolboard 23);Gpin 4= T3 dock switch on 6hc
      Buffered code: M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      Buffered code: M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0
      Buffered code: M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
      Buffered code: M140 H0 ; map heated bed to heater 0
      Buffered code: M143 H0 S120 ; set temperature limit for heater 0 to 120C
      Buffered code: M308 S1 P"20.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermocouple via CS pin spi.cs1
      Buffered code: M950 H1 C"20.out0" T1 ; create nozzle heater output on out1 and map it to sensor 1
      Buffered code: M307 H1 B0 S1.00 ; disable bang-bang mode for heater  and set PWM limit
      Buffered code: M143 H1 S300 ; set temperature limit for heater 1 to 280C
      Buffered code: M308 S2 P"21.temp0" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin 121.temp0
      Buffered code: M950 H2 C"21.out0" T2 ; create nozzle heater output on 121.out0 and map it to sensor 2
      ==> 676 bytes
      Executing macro config.g, started by system
      > Next stack level
      Pending code: M905 P"2021-10-19" S"13:48:16"
      Code buffer space: 2012
      Configured SPI speed: 8000000Hz
      Full transfers per second: 8.44, max wait times: 18.7ms/0.0ms
      Codes per second: 0.27
      Maximum length of RX/TX data transfers: 3599/608
      config.g
      ; configuration file for Duet 3 (firmware version 3)
      M111 S0														;debugging off
      G21 														;Work in mm
      G90                                                        ; send absolute coordinates...
      M83                                                        ; ...but relative extruder moves
      M550 P"********"                                        ; set printer name
      M669 K0 X1:0:0 Y0:1:0 Z0:0:1                                 ; select Cartesian mode
      G4 S1 												   ;Wait for expension boards to start
      M555 S1 												;firmware mode 1-RRf 2-marlin
      ;Network
      ;M552 S1													;enable network
      ;M586 P0 S1												;enable http
      ;M586 P1 S0												;disable ftp
      ;M586 P2 S0												;disable Telnet
      ; Drives XYZ
      M569 P40.0 S1 R0 T2.6:2.6:2.6:2.6                       	 ; physical drive 40.0 goes forwards X MOONST T2.6:2.6:2.6:2.6
      M569 P41.0 S0 R0 T2.6:2.6:2.6:2.6                       	  ; physical drive 41.0 goes forwards Y1 MOONS
      M569 P42.0 S0 R0 T2.6:2.6:2.6:2.6                        	 ; physical drive 42.0 goes forwards Y2 MOONS
      M569 P43.0 S0 R0 T2.6:2.6:5:5                            ; physical drive 43.0 goes forwards Z1 BRAKE MOTOR T2.6:2.6:5:5
      M569 P44.0 S0 R0 T2.6:2.6:5:5                           ; physical drive 44.0 goes forwards Z2 BRAKE MOTOR
      ;MOTOR BRAKE Z
      ;M950 J0 C"!43.io1.in"
      ;M950 P0 C"!43.out1"											;control Brake Z1 (port 43) (signal control from stepper alarm)
      ;M42 P0 S0													;Z1 BRAKE desactivate it (power 0-24v)
      ;M950 J0 C"!44.io1.in"
      ;M950 P1 C"!44.out1"											;control Brake Z2 (port 44) (signal control from stepper alarm)
      ;M42 P1 S0													;Z2 BRAKE desactivate it (power 0-24v)
      ; Extruder
      M569 P20.0 S1                                           ; TO0LBoard T0 physical drive 20.0 goes forwards E1 toolboard
      M569 P21.0 S1                                           ; TO0LBoard T1 physical drive 21.0 goes forwards E1 toolboard
      M569 P22.0 S1                                           ; TO0LBoard T2 physical drive 22.0 goes forwards E1 toolboard
      M569 P23.0 S1                                           ; TO0LBoard T3 physical drive 23.0 goes forwards E1 toolboard
      ;Coupler ChangeTools
      M569 P0.1 S1										    ;Coupler ChangeTools axe C (duet 6hc)
      M915 C S3 F0 H200										;Stall detection coupler (endstop axe C)
      ;Drive Configuration
      M584 X40.0 Y41.0:42.0 Z43.0:44.0 C0.1 E20.0:21.0:22.0:23.0         ; set drive mapping
      M350 E16:16:16:16 I1                         					; configure microstepping with interpolation M350 X16 Y16 Z16 E16:16 I1
      M350 C8 I0
      M92 X512 Y512 Z512 C100 E415:415:415:415  					   ; set steps per mm-
      M566 X200 Y200 Z20 C2 E120:120:120:120      				       ; set maximum instantaneous speed changes (mm/min)-
      M203 X20000 Y20000 Z500 C5000 E1200:1200:1200:1200 			   ; set maximum speeds (mm/min)-
      M201 X1000 Y1000 Z500 C400 E250:250:250:250   					   ; set accelerations (mm/s^2)-
      M906 C500 E800:800:800:800 I30              					 ; set motor currents (mA) and motor idle factor in per cent
      M84 S120                                                ; Set idle timeout
      M208 X0 Y0  C0 S1                       ; set axis minima/maxima Z0
      M208 X850 Y850 Z500 C260 S0									;
      M574 X1 S1 P"io0.in"                                   ; configure active-high endstop for low end on X via pin io0.in M574 X1 S1 P"!io0.in">capteur meca 3fils)
      M574 Y1 S1 P"io1.in"                                   ; configure active-high endstop for low end on Y via pin io1.in
      M574 Z2 S2                             				   ; configure active-high endstop for low end on Y via pin io1.in- M574 Z2 S2 zprobe-M574 Z1 S1 P"io2.in"
      ; Z-Probe switch ONRON
      M558 P5 C"^io2.in" H5 F500:120 T8000                 ; disable Z probe but set dive height, probe speed and travel speed1
      G31 P200 X-0.3 Y60.2 Z1
      M557 X250:550 Y250:550 P6:6							; define mesh grid
      ;DOCK switch for toolchange parking verification
      M950 J1 C"20.io0.in"									;Gpin1 = Tool 0 Dock switch (on Toolboard 20);Gpin 1= T0 dock switch on 6hc
      M950 J2 C"21.io0.in"									;Gpin2 = Tool 1 Dock switch (on Toolboard 21);Gpin 2= T1 dock switch on 6hc
      M950 J3 C"22.io0.in"									;Gpin3 = Tool 2 Dock switch (on Toolboard 22);Gpin 3= T2 dock switch on 6hc
      		;BED
      		;Extruder 0 (T0) CANbus 20
      		;Extruder 1 (T1) CANbus 21
      M307 H2 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S300                                           ; set temperature limit for heater 2 to 280C
      		;Extruder 2 (T2) CANbus 22
      M308 S3 P"22.temp0" Y"thermistor" T100000 B4138       ; configure sensor 2 as thermistor on pin 121.temp0
      M950 H3 C"22.out0" T3                                 ; create nozzle heater output on 121.out0 and map it to sensor 2
      M307 H3 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
      M143 H3 S300                                           ; set temperature limit for heater 2 to 280C
      		;Extruder 3 (T3) CANbus 23
      M308 S4 P"23.temp0" Y"pt1000"        ; configure sensor 2 as thermistor on pin 121.temp0
      M950 H4 C"23.out0" T4                                 ; create nozzle heater output on 121.out0 and map it to sensor 2
      M307 H4 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
      M143 H4 S280                                           ; set temperature limit for heater 2 to 280C
      		;T0 fan
      M950 F0 C"20.out1" Q500                                 ; T0-part cooling fan
      M106 P0 C"T1 partcooling fan" S0 B0.1 H-1                                     ; Default off.bootstart for 0.1s (B0.1);thermostatic control off
      M950 F1 C"20.out2" Q500                                 ; T0-Hotend cooling fan
      M106 P1 C"T1 hotend fan" S1 H1 T40                                       ; Default ON. Thermostatic control above 40°C
      		;T1 fan
      M950 F2 C"21.out1" Q500                                 ; T1-part cooling fan
      M106 P2 C"T1 partcooling fan" S0 B0.1 H-1                                     ; Default off.bootstart for 0.1s (B0.1);thermostatic control off
      M950 F3 C"21.out2" Q500                                 ; T1-Hotend cooling fan
      M106 P3 C"T1 hotend fan" S1 H1 T40                                       ; Default ON. Thermostatic control above 40°C
      		;T2 fan
      M950 F4 C"22.out1" Q500                                 ; T2-part cooling fan
      106 P4 S0 B0.1 H-1                                     ; Default off.bootstart for 0.1s (B0.1);thermostatic control off
      M950 F5 C"22.out2" Q500                                 ; T2-Hotend cooling fan
      M106 P5 S1 H1 T40                                       ; Default ON. Thermostatic control above 40°C
      		;T3 fan
      M950 F6 C"23.out1" Q500                                 ; T3-part cooling fan
      M106 P6 S0 B0.1 H-1                                     ; Default off.bootstart for 0.1s (B0.1);thermostatic control off
      M950 F7 C"23.out2" Q500                                 ; T3-Hotend cooling fan
      M106 P7 S1 H1 T40                                       ; Default ON. Thermostatic control above 40°C
      ;Z-Offset: 	If nozzle is too close to bed _reduce_ offset (negative number becomes more negative)
      ;			If nozzle is too far away, _increase_ offset (negative number becomes less negative)
      		;T0
      M563 P0 D0 H1 F0 S"T0"                                      ; define tool 0
      G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
      G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
      		;T1
      M563 P1 D1 H2 F2 S"T1"                                      ; define tool 1
      G10 P1 X0 Y0 Z0                                        ; set tool 1 axis offsets
      G10 P1 R0 S0                                           ; set initial tool 1 active and standby temperatures to 0C
      		;T2
      M563 P2 D2 H3 F0 S"T2"                                      ; define tool 1
      G10 P2 X0 Y0 Z0                                        ; set tool 1 axis offsets
      G10 P2 R0 S0                                           ; set initial tool 1 active and standby temperatures to 0C
      		;T3
      M563 P3 D3 H4 F0 S"T3"                                      ; define tool 1
      G10 P3 X0 Y0 Z0                                        ; set tool 1 axis offsets
      G10 P3 R0 S0                                           ; set initial tool 1 active and standby temperatures to 0C
      ;TOOLS OFFSET
      ; estimed offset for :
      	; Copperhead-tool >>> Z-74.6
      G10 P0 X-9 Y39 Z-100									;TO Z-60.4
      G10 P1 X-9 Y39 Z-100									;T1
      G10 P2 X-9 Y39 Z-100									;T2
      G10 P3 X-9 Y39 Z-100									;T3
      ; deselect Tools
      T-1
      ; BTT filament sensor
      ;M591 D0 P0 C"^io_6.in" L6.2 R90:110 E6 S1
      ; Pressure Advance
      ;M572 D0 S0.5											;Pressure Advance T0_direct drive bondtech +volcano
      ;M572 D1 S0.5											;Pressure Advance T1_direct drive bondtech +volcano
      ;M572 D2 S0.5											;Pressure Advance T2_direct drive bondtech +volcano
      ;M572 D3 S0.5											;Pressure Advance T3_direct drive bondtech +volcano
      M575 P1 S1 B57600                                      ; enable support for PanelDue
      M501                                                   ; load saved parameters from non-volatile memory
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"     ; set voltage thresholds and actions to run on power loss
      thanks
      T3P3Tony dc42 2 Replies Last reply Reply Quote 0
      • T3P3Tony
        T3P3Tony administrators @bast last edited by
        @bast said in duet 3d HC : Can Bus failed:
        if you send M122 Bn to all the boards do you get an error for each one?
        www.duet3d.com
          dc42 administrators @bast last edited by
          @bast what are the status LEDs on the main board and on the tool bards doing? Flashing in sync, or something else?
          bast 1 Reply Last reply Reply Quote 0
          • bast
            bast last edited by
            yes all failed
            19/10/2021, 14:09:16	m122 b20
            Error: M122: Response timeout: CAN addr 20, req type 6024, RID=51
            19/10/2021, 14:09:11	Warning: Controller has been reset
            19/10/2021, 14:09:11	Connection to Duet established
            19/10/2021, 14:09:08	Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
            19/10/2021, 14:09:04	Error: M308: Response timeout: CAN addr 21, req type 6031, RID=43
            19/10/2021, 14:09:01	Error: M143: Heater 1 does not exist
            19/10/2021, 14:09:01	Error: M307: Heater 1 not found
            19/10/2021, 14:09:01	Error: M950: Response timeout: CAN addr 20, req type 6026, RID=41
            19/10/2021, 14:08:59	Error: M308: Response timeout: CAN addr 20, req type 6031, RID=39
            19/10/2021, 14:08:56	Error: M950: Response timeout: CAN addr 23, req type 6036, RID=38
            19/10/2021, 14:08:55	Error: M950: Response timeout: CAN addr 22, req type 6036, RID=37
            19/10/2021, 14:08:54	Error: M950: Response timeout: CAN addr 21, req type 6036, RID=36
            19/10/2021, 14:08:54	Error: M950: Response timeout: CAN addr 20, req type 6036, RID=35
            19/10/2021, 14:08:51	Error: M906: Response timeout: CAN addr 20, req type 6043, RID=31
            Response timeout: CAN addr 21, req type 6043, RID=32
            Response timeout: CAN addr 22, req type 6043, RID=33
            Response timeout: CAN addr 23, req type 6043, RID=34
            19/10/2021, 14:08:51	Error: Response timeout: CAN addr 20, req type 6042, RID=22
            Response timeout: CAN addr 21, req type 6042, RID=23
            Response timeout: CAN addr 22, req type 6042, RID=24
            Response timeout: CAN addr 23, req type 6042, RID=25
            Response timeout: CAN addr 40, req type 6042
            19/10/2021, 14:08:36	Error: M350: Response timeout: CAN addr 20, req type 6042, RID=18
            Response timeout: CAN addr 21, req type 6042, RID=19
            Response timeout: CAN addr 22, req type 6042, RID=20
            Response timeout: CAN addr 23, req type 6042, RID=21
            19/10/2021, 14:03:34	Error: Response timeout: CAN addr 20, req type 6042, RID=9
            Response timeout: CAN addr 21, req type 6042, RID=10
            Response timeout: CAN addr 22, req type 6042, RID=11
            Response timeout: CAN addr 23, req type 6042, RID=12
            Response timeout: CAN addr 40, req type 6042,
            • bast
              bast @dc42 last edited by
              all led flashes quickly
              this config worked yesteday
              i do some other test
              when i plug just toolboard ,it s ok
              • T3P3Tony
                @bast try each of the 1XDs in turn to see if one of them is causing the problem.
                www.duet3d.com
                  @bast if the status LED on the 6HC is flashing at 1Hz, and the tool boards LEDs are flashing continuously and rapidly, then it indicates that CAN communication isn't working.
                  The most likely reason is a bad CAN cable between the Duet 3 and the tool distribution board, or between the tool distribution board and the first tool board.
                  Another possibility is that something is shorting the CAN bus out. You could try connecting just one tool board to the CAN bus at a time, to see if a tool board is shorting the bus. Remember to fit the jumpers on the tool distribution board to bypass any missing tool boards.
                  • bast
                    bast last edited by
                    I tested all the boards independently
                    I have toolboard 0 (adress20) which creates a conflict for me in the general can bus
                    I am reconfiguring a toolboard to replace it
                    thank you
