Z homing issu whit endstop please help
@jay_s_uk Bltouch sorry for that
@bartekp no as you appear to be missing the servo configuration https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
What board are you using and where is the bltouch connected?
You should also have deployprobe.g and retractprobe.g in your sys folder -
@bartekp deployprobe.g and retractprobe.g duet 2 wifi
@bartekp then you should have this line in your config
M950 S0 C"exp.heater3"
if you add that, does the probe react to M401 and M402?
What's the contents of those deploy and retract files? -
@jay_s_uk sory i forgot i dont have this files I working on reach them please wait
@bartekp
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H5 F1200 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X30 Y60 Z8 ; set Z probe trigger value, offset and trigger height
M557 X15:315 Y15:315 S20 ; define mesh grid; deployprobe.g
; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v3.3.4 on Wed Oct 20 2021 14:25:18 GMT+0200 (czas środkowoeuropejski letni)
M280 P3 S10 I1 ; deploy BLTouch; retractprobe.g
; called to retract a physical Z probe
M280 P3 S90 I1 ; retract BLTouch -
@bartekp said in Z homing issu whit endstop please help:
Thats the wrong syntax.
You needM558 P9 C"^zprobe.in" H5 F100 T2000 M950 S0 C"exp.heater3" G31 P500 X30 Y60 Z8 ; set Z probe trigger value, offset and trigger height M557 X15:315 Y15:315 S20 ; define mesh grid
you also don't need the M307
@bartekp see my previous post. your config. is wrong
@bartekp send
M98 P"config.g"
and post the output -
@bartekp ok i didt changes what to do next or deal with this bltouch
@bartekp M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: Heater 3 not found
Error: Unknown sensor type name "pt100000"
Warning: Sensor number 1 has not been definedError: Temperature reading fault on heater 1: unknown sensor
@bartekp can you post your full config.g
@jay_s_uk ; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.3 on Mon Oct 04 2021 22:39:47 GMT+0200 (czas środkowoeuropejski letni); General preferences
M550 P"My Printer" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes forwards
M569 P3 S0 ; physical drive 3 goes forwards
M350 Z16 E16 I0 ; configure microstepping without interpolation
M350 X16 Y16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z2756.00 E675.00 ; set steps per mm
M566 X900.00 Y900.00 Z20.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
M203 X30000.00 Y30000.00 Z20.00 E6000.00 ; set maximum speeds (mm/min)
M201 X5000.00 Y5000.00 Z10.00 E500.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E550 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X500 Y500 Z600 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"zstop" ; configure active-high endstop for high end on Z via pin ^zstop; Z-Probe
M557 X15:315 Y15:315 S20 ; define mesh grid; Heaters
M308 S1 P"e0temp" Y"pt100000" R4700 ; configure sensor 1 as PT1000 on pin e0temp
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
T0 ; select first tool -
; Configuration file for Duet WiFi (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.3 on Mon Oct 04 2021 22:39:47 GMT+0200 (czas środkowoeuropejski letni) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Printer" ; set printer name M669 K1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 Z16 E16 I0 ; configure microstepping without interpolation M350 X16 Y16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z2756.00 E675.00 ; set steps per mm M566 X900.00 Y900.00 Z20.00 E600.00 ; set maximum instantaneous speed changes (mm/min) M203 X30000.00 Y30000.00 Z20.00 E6000.00 ; set maximum speeds (mm/min) M201 X5000.00 Y5000.00 Z10.00 E500.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E550 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X500 Y500 Z600 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure active-high endstop for high end on Z via pin ^zstop ; Z-Probe M950 S0 C"exp.heater3" M558 P9 C"^zprobe.in" H5 F100 T2000 G31 P500 X30 Y60 Z8 ; set Z probe trigger value, offset and trigger height M557 X15:315 Y15:315 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"pt1000" R4700 ; configure sensor 1 as PT1000 on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous T0 ; select first tool
I've made a couple of tweaks. could you load that please?
@jay_s_uk 20.10.2021, 15:08:02
Error: Temperature reading fault on heater 1: sensor open circuit
20.10.2021, 15:08:00 M98 P"config.g"
FTP is disabled
TELNET is disabled -
@bartekp what to do next
@bartekp does the probe display in that panel now?
