    Solved Bug in firmware / DWC
    • Tinchus
      Tinchus last edited by
      Hello. I have been trying to set up a double chamber heater, having 2 heaters and wanting them to wrok independently so I ve indiviidual control on them for security purposes.
      So I have 2 resisitors conected to 2 solid state relays, each one of them conectd to out7 and out8 pins. So this is my setup:
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 A"chamber" ; configuro sensor 0 en pin temp0
      M950 H0 C"out7" T0 ; create chamber heater output on out0 and map it to sensor 0
      M307 H0 R0.31 C284.700:284.700 D30 S1.00 V0 B0 ; enable PID mode for the chamber heater and set PWM limit
      M308 S3 P"spi.cs0"Y"thermocouple-max31856" K"K" A"chamber_resistorR"
      M308 S4 P"spi.cs1"Y"thermocouple-max31856" K"K" A"chamber_resistorL"
      M950 H3 C"out8" T0 ;
      M307 H3 R0.31 C284.700:284.700 D30 S1.00 V0 B0 ; PID heater chamber 2
      M141 H0
      M141 P1 H3
      M143 H0 P0 S240
      M143 H0 T3 S350 A2
      M143 H3 T4 S350 A2
      M143 H3 P1 S240
      My intention with this code was to have 2 heater chambers, control them individually, so I have a thermocuple on each one of them and so I can avoid overheating them. And I can see the temperature of the camber on the screen and the temperature of the resistors too. Looked ok
      But I tried to start printing today and I found this issue: so far I was using the DWC, on the screen I choosed the desired temperature. Due to restrictions or maybe my lack of knowledge on reprapfirmware, my config created on the screen 2 chambers, so on the screen I have to set up the chamber temperature on both of them. No a problem for me. And this is working ok. I set up the temperature on them and both resistors turn on.
      Now I moved into printing. I set up my start gcode using M141 P0 S80 and M141 P1 S80 in order to turn on both chamber heaters.
      To my surprise this gcode is not working : M141 P0 S80 turns on 1 heater, but them M141 P1 S80 turns on the other heater but turns off the first one. And so on: every time I execute a gocode to turn on 1 heater the other one is turned off.
      This is not happening when I turn on the heaters using the DWC, so I guess there is a bug here?
      fcwilt 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt @Tinchus last edited by
        @tinchus
        Did you try M141 P0 S80 P1 S80?
        Tinchus 1 Reply Last reply Reply Quote 0
        • Tinchus
          Tinchus @fcwilt last edited by
          @fcwilt said in Bug in firmware / DWC:
          M141 P0 S80 P1 S80
          It does the same. It turns on for just 1 second P0 then turns it off and turns on P1 wich stay on.
          T3P3Tony 1 Reply Last reply Reply Quote 1
          • T3P3Tony
            T3P3Tony administrators @Tinchus last edited by
            @tinchus please can we keep this to a single thread:
            https://forum.duet3d.com/topic/25355/sensor-not-showing-on-dwc/16
            www.duet3d.com
