    NEMA 17 24v power off Brake on D3 Mini
    Accessories and Add-ons
    • CNCModeller
      CNCModeller last edited by
      Hi All,
      I'm looking at one of these to brake my z axis when power is off. It'll often drop over time, and it's not great for power loss recovery either.
      Square stepper motor brake black color NEMA 17 NEMA 23 NEMA 34 stepper motor brake 24V max 4Nm
      https://a.aliexpress.com/_mNBfTZs
      I know the 1HCL boards have an output for an axis brake, but can I do something similar directly from the D3 Mini? I'm hoping I can use a spare output with a relay board to release the brake, but does RRF support that w.r.t releasing the brake to allow movement?
      Any thoughts would be much appreciated.
      Cheers
      Barry M
      Polar Printer Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      Wanhao D5S & K40 Laser, Duet2 TBD
      https://www.youtube.com/CNCModellerUK
      • T3P3Tony
        T3P3Tony administrators @CNCModeller last edited by
        @cncmodeller check out the recently added brake support:
        https://duet3d.dozuki.com/Wiki/M569.7
        Key point is the brake needs to be on the same board as the motor its associated with.
        www.duet3d.com
        T3P3Tony CNCModeller 2 Replies Last reply Reply Quote 0
        • T3P3Tony
          T3P3Tony administrators @T3P3Tony last edited by
          @CNCModeller also not its only support in RRF3.4 and later (i know you are running 3.4b5, this is for others who come across the thread)
          www.duet3d.com
          • CNCModeller
            CNCModeller @T3P3Tony last edited by
            @t3p3tony said in NEMA 17 24v power off Brake on D3 Mini:
            Cool Thanks @T3P3Tony . Will get it ordered.
            So what CAN address do I use of the D3 mini? Or do I just use P.1 / P0.1 if z motor is on the D3 mini driver 1?
            Re the example...
            M569.7 P40.0 C"out2" ; driver 0 on board 40 uses port out1 on board 40 to control the brake
            Wanhao D4S: Duet2
            • T3P3Tony
              T3P3Tony administrators @CNCModeller last edited by dc42
              @cncmodeller they would both be on the mainboard in this case so for example
              M569 P3 C"out2" ; driver 3 on mainboard uses port out 2 on mainboard.
              www.duet3d.com
              CNCModeller 1 Reply Last reply Reply Quote 0
              • CNCModeller
                👍 got it. Many thanks. 😀
                Wanhao D4S: Duet2
