    Wifi Connection Failing
    Duet Web Control
    227
    • WCarper
      WCarper last edited by
      Hi - I have a fresh out of the box Duet WiFi that is not staying connected. I ran through setup and configured per online instructions with no problems, but I am finding that the wifi will stop working at random times and will usually fail on start up with network scan failed. The symptoms are exactly as described in this post so will not repeat them again. I would not bother posting since but vendor I bought the board is insisting that I post again before they will take the board back. (Rather lame I think!)
      https://forum.duet3d.com/topic/22157/wifi-reported-error-network-scan-failed
      SIam 1 Reply Last reply Reply Quote 0
      • SIam
        SIam @WCarper last edited by
        @wcarper Please post the result of the command M122 and M98 P"config.g" and the config.g file.
        Did you try to change the Channel of your WiFi ? This can sometimes help.
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        WCarper 1 Reply Last reply Reply Quote 0
        • WCarper
          WCarper @SIam last edited by
          @siam Changing Wifi channel did not help. Here are the results from DWC when the connection happened to work and from YAT when random failure occured
          M122 When Connected
          10/22/2021, 7:53:38 AM M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
          Board ID: 0JD0M-9P6B2-NJ4S8-6JKF0-3S06T-TA6QL
          Used output buffers: 3 of 24 (12 max)
          Static ram: 23876
          Dynamic ram: 76824 of which 12 recycled
          Never used RAM 13704, free system stack 184 words
          Tasks: NETWORK(ready,12.4%,244) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) DUEX(notifyWait,0.0%,24) MAIN(running,86.8%,443) IDLE(ready,0.7%,29), total 100.0%
          Owned mutexes: WiFi(NETWORK) HTTP(MAIN)
          Last reset 00:01:45 ago, cause: power up
          Last software reset at 2021-10-20 17:24, reason: User, GCodes spinning, available RAM 10496, slot 0
          Error status: 0x00
          Aux0 errors 0,0,0
          Step timer max interval 0
          MCU temperature: min 30.9, current 36.3, max 36.4
          Supply voltage: min 24.0, current 24.2, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max not available
          Driver 1: position 0, standstill, SG min/max not available
          Driver 2: position 0, standstill, SG min/max not available
          Driver 5: position 0, standstill, SG min/max not available
          Driver 6: position 0, standstill, SG min/max not available
          Driver 7: position 0, standstill, SG min/max not available
          Driver 8: position 0, standstill, SG min/max not available
          Driver 9: position 0, standstill, SG min/max not available
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2021-10-22 07:53:37
          Cache data hit count 3831143755
          Slowest loop: 5.82ms; fastest: 0.17ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.8ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = 0 -1 -1 -1, chamberHeaters = 3 -1 -1 -1
          Segments left: 0
          Movement lock held by null
          HTTP is ready with "M122 " in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Filament sensors ===
          Extruder 0 sensor: ok
          Extruder 1 sensor: ok
          === DueX ===
          Read count 1, 0.57 reads/min
          === Network ===
          Slowest loop: 15.83ms; fastest: 0.00ms
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.26
            WiFi MAC address 48:3f:da:a6:e2:d3
            WiFi Vcc 3.41, reset reason Power up
            WiFi flash size 2097152, free heap 25536
            WiFi IP address 192.168.1.119
            WiFi signal strength -46dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
          10/22/2021, 7:55:29 AM M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 245C
          When Connection Fails
          m122<CR>
          Used output buffers: 1 of 24 (24 max)
          Static ram: 23876
          Never used RAM 13704, free system stack 193 words
          Tasks: NETWORK(notifyWait,12.4%,337) HEAT(delaying,0.0%,336) Move(notifyWait,0.1%,364) DUEX(notifyWait,0.0%,24) MAIN(running,85.3%,467) IDLE(ready,2.2%,29), total 100.0%
          Owned mutexes: WiFi(NETWORK) USB(MAIN)
          Last reset 00:00:33 ago, cause: power up
          Last software reset at 2021-10-23 12:33, reason: User, GCodes spinning, available RAM 10496, slot 2
          Error status: 0x0c
          Aux0 errors 0,0,0
          MCU temperature: min 40.2, current 43.6, max 43.7
          Supply voltage: min 0.0, current 0.4, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
          Driver 0: position 0, ok, SG min/max not available
          Driver 1: position 0, ok, SG min/max not available
          Driver 2: position 0, ok, SG min/max not available
          Driver 3: position 0, ok, SG min/max not available
          Driver 4: position 0, ok, SG min/max not available
          Driver 5: position 0, ok, SG min/max not available
          Driver 6: position 0, ok, SG min/max not available
          Driver 7: position 0, ok, SG min/max not available
          Driver 8: position 0, ok, SG min/max not available
          Driver 9: position 0, ok, SG min/max not available
          Cache data hit count 1426401587
          Slowest loop: 4.97ms; fastest: 0.13ms
          === Storage ===
          SD card longest read time 3.2ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          HTTP is idle in state(s) 0
          USB is ready with "m122" in state(s) 0
          === DueX ===
          Read count 1, 1.77 reads/min
          === Network ===
          Slowest loop: 14.67ms; fastest: 0.00ms
          HTTP sessions: 0 of 8
          • WiFi -
            WiFi flash size 2097152, free heap 27040
            WiFi IP address 255.255.255.255
            WiFi signal strength 31dBm, mode 802.11n, reconnections 0, sleep mode modem
            ok
          M98 P"config.g"
          M98 P"config.g"
          FTP is disabled
          TELNET is disabled
          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 250C
          Warning: Heater 3 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
          ok
          SIam T3P3Tony Phaedrux 3 Replies Last reply Reply Quote 0
          • SIam
            @wcarper please follow this guide: https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors
            and please post your config.g
            • T3P3Tony
              T3P3Tony administrators @WCarper last edited by
              @wcarper you have good signal strength and in both M122 reports you posted the wifi module is reporting as successfully connected.
              When the connection fails do you get anything reported in the temrinal program when you are connected over USB?
              www.duet3d.com
              • WCarper
                While I appreciate the help, I guess I am not making this clear.
                1. These are not AJAX errors. The wifi just stops working. The error on DWC indicates that connection is lost and trying to reset. On the PANEL DUE - it indicates that network scan failed (just like the other post._
                2. If you look closely at the M122, when it fails it shows a bogus IP address of 255.255.255.255 but when connected it is an appropriate non routable address.
                3. This is not my first rodeo with Duet Wifi, I have built 3 different printers with this board and this is the ONLY one that has a problem.
                Config.g
                ; Configuration file for Duet WiFi (firmware version 3.3)
                ; generated by RepRapFirmware Configuration Tool v3.3.2 on Thu Sep 02 2021 15:40:23 GMT-0600 (Mountain Daylight Time)
                M550 P"W3R Cheribundi" ; set printer name
                M552 S1 ; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M569 P0 S0 ; physical drive 0 goes backwards and is mapped X
                M569 P1 S0 ; physical drive 1 goes backwards and is mapped YLeft
                M569 P2 S0 ; physical drive 2 goes backwards and is mapped to open
                M569 P3 S0 ; physical drive 3 goes backwards and is mapped to E0 (left)
                M569 P4 S1 ; physical drive 4 goes forwards and is mapped to E1 (right)
                M569 P5 S1 ; physical drive 5 goes forwards and is mapped to Y Right
                M569 P6 S1 ; physical drive 6 goes forwards and is mapped to Z1
                M569 P7 S1 ; physical drive 7 goes forwards and is mapped to Z2
                M569 P8 S0 ; physical drive 8 goes backwards and is mapped to Z3
                M584 X0 Y1:5 Z6:7:8 E3:4 ; set drive mapping
                M350 X16 Y16:16 Z16:16:16 E16:16 I1 ; configure microstepping with interpolation
                M92 X80.00 Y80.00:80 Z320.00:320.00:320.00 E415.00:415.00 ; set steps per mm
                M566 X900.00 Y900.00:900.00 Z60.00:60.00:60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00:6000.00 Z180.00:180.00:180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
                M201 X500.00 Y500.00:500.00 Z20.00:20.00:20.00 E250.00:250.00 ; set accelerations (mm/s^2)
                M906 X1500 Y1900:1900 Z1900:1500:1500 E1900:1900 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X300 Y300 Z300 S0 ; set axis maxima
                ;M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                M574 Z1 S1 P"duex.e3stop + duex.e4stop + duex.e5stop" ; configure stops with independent switches for each motor
                ;This command is for the endstops and must be in order as M584
                ;M558 P5 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
                ;G31 P500 X0 Y0 Z1.05 ; set Z probe trigger value, offset and trigger height
                ;M557 X15:285 Y15:285 S60 ; define mesh grid
                M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
                M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
                M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                M143 H2 S280 ; set temperature limit for heater 2 to 280C
                M308 S3 P"duex.e2temp" Y"thermistor" T100000 B4138 ; configure sensor 3 as thermistor on pin duex.e2temp
                M950 H3 C"duex.e2heat" T3 ; create chamber heater output on duex.e2heat and map it to sensor 3
                M307 H3 B1 S1.00 ; enable bang-bang mode for the chamber heater and set PWM limit
                M141 H3 ; map chamber to heater 3
                M143 H3 S75 ; set temperature limit for heater 3 to 75C
                M950 F1 C"fan1" Q500 ; create fan 0 on pin fan0 and set its frequency
                M106 P1 S1 H-1 ; set fan 0 value. Thermostatic control is turned off and set to run continuously
                M950 F2 C"fan2" Q500 ; create fan 0 on pin fan0 and set its frequency
                M106 P2 S1 H-1 ; set fan 0 value. Thermostatic control is turned off and set to run continuously
                ; Lights Map to Heater 3
                M950 F3 C"duex.e3heat"
                M106 P3 S0 H-1 C"Chamber Light"
                M106 P3 S0 ; Start Light off
                ;M106 P8 S1
                M563 P0 S"Left Extruder" D0 H1 ; define tool 0
                G10 P0 R0 S195 ; set initial tool 0 active and standby temperatures to 0C;
                M563 P1 S"Right Extruder" D1 H2 ; define tool 1
                G10 P1 X20 Y-1 Z0 ; set tool 1 axis offsets
                G10 P1 R0 S195 ; set initial tool 1 active and standby temperatures to 0C
                ;Filament Sensors
                M591 P1 C"e0stop" S1 D0 ; filament monitor connected to E0 endstop
                M591 P1 C"e1stop" S1 D1 ; filament monitor connected to E1 endstop
                ; Allow for Config Overide G Code
                M501
                • T3P3Tony
                  @wcarper said in Wifi Connection Failing:
                  Thanks for pointing that out I missed it.
                  Is the address it has when its working a fixed IP or one allocated by DHCP? If DHCP as a test can you give it a fixed address with M587 and see if the issue still occurs?
                  www.duet3d.com
                  • WCarper
                    I created a fixed address as suggested and for a couple of weeks it worked, but now failing again. According to Matterhackers where I bought the board they will not take it back for exchange for a working board until we have completed this tech support request. Can you acknowledge this is a defective board so that I can get one that works. I use this as part time business and every time this board fails it is affecting my revenue.
                      Phaedrux Moderator @WCarper last edited by
                      Also of note is that the signal strength is 31dB!! Not -31dB as you'd expect.
                      I'm not entirely sure it's a hardware issue, as it seemed to be working on a fixed address, however without much else to go on swapping the hardware would at least help eliminate that as an issue. Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out. Upon completion your seller will be able to exchange your board.
                      • WCarper
                        WCarper @Phaedrux last edited by
                        @phaedrux There are 2 other duets running in the shop in addition to this one and they operate without issue. The problem is isolated to this board.
                        • WCarper
                          WCarper @WCarper last edited by
                          @wcarper Just to close the loop - I received the warranty replacement board and it has completely resolved the issue. Also, I inadvertently left the SD card on the returned board so at least you will be able to see all the settings!
