[SOLVED] Help connecting an accelerometer
I am trying to connect a LIS3DH accelerometer to a Mini5+ printer.
Firmware version is
Wiring diagram is
When I type the command per the instructions I get
Before I start debugging the wiring and try to look at signals, is this the right process to set it up? Should I had additional accelerometer related configurations (currently I have nothing in config.g). And if it should work, any suggest what to check next?
Ok, I connected a 330 ohms resistor in series to the SDO output and the M955 command completes without errors. Next I will try to actually use the accelerometer but it seems that the immediate problem is solved.
gloomyandy
@zapta said in [SOLVED] Help connecting an accelerometer:
Have you placed the resistor right after the board connector or the accelerometer connector?
Thanks -
@thedragonlord , I connected the resistor on the accelerometer side.
I also tried 7 ~1.5m loose wires and it worked well without the resistor.
