    Acceleration and jerk tuning
    • Messiahman
      Messiahman last edited by
      Hi all,
      No matter what I do I can't seem to eliminate ringing at all from my printer. I have tried all sorts of changes to acceleration but no matter what I do, the ringing looks the exact same. Any advice?
      engikeneer 1 Reply Last reply Reply Quote 0
      • Alex.cr
        Alex.cr last edited by
        Alright so lots of questions:
        What type of printer are you using?
        What are your print speeds?
        What type of values have you tried?
        Have you made sure all belts are tight (but not too tight)?
        Are you using both M201 and M204?
        How bad is the ringing? You may not be able to remove it completely
        Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
        • engikeneer
          engikeneer @Messiahman last edited by
          @messiahman some pictures of your printer and of some prints with ringing might also help, on top of @Alex-cr's questions
          i3 clone with a bunch of mods
