    incomplete gcodes upload
    88
    • Tinchus
      Tinchus last edited by
      Hello. I have had some cases where the print stops and it is reported as finished.
      But I downloaded the last gcode showed that error and I found the gcode it is incomplete. It is just not compelte. Somehow the uploaded file was cut and part of it was just lost.
      Since this has happened to me 3 or 4 times I guess there is something wrong somewhere.
      Is there any other similar reports? What can be causing this incomplete upload?
      • T3P3Tony
        T3P3Tony administrators @Tinchus last edited by
        @tinchus in the latest firmware there is a CRC check run on uploaded gcodes. Because you are using SBC mode I am going to ask @chrishamm if there is any specific things he would like you to test.
        I assume you have downloaded one of the incomplete files and confirmed that it is truncated?
        www.duet3d.com
        T3P3Tony Tinchus 2 Replies Last reply Reply Quote 0
        • T3P3Tony
          T3P3Tony administrators @T3P3Tony last edited by
          @Tinchus When you get a partial upload, please use:
          journalctl -u duetwebserver
          in a console window on the pi. This shows the DWS log which may contain further details about why the G-code was only partially written
          www.duet3d.com
          Tinchus 1 Reply Last reply Reply Quote 0
          • Tinchus
            Tinchus @T3P3Tony last edited by
            @t3p3tony Yes, I downloaded it just to check and I saw it was not complete, so basically the print finish report was ok, the problem is the truncated gcode file
            • Tinchus
              @t3p3tony
              Ok, I have done that command and created this log file. File attachedlog_duetwebserver.txt
              The content of that log file is way outside my knowledge to see if there is something wrong. I saw some warnings about a service not started?
              • T3P3Tony
                @tinchus what time did you do the upload that ended up being incomplete?
                www.duet3d.com
                • Tinchus
                  @t3p3tony In the DWC time says it was uploaded at 2:59 PM on 24th (yesterday)
                  • T3P3Tony
                    @tinchus thanks.
                    It looks like a reset/emergency stop was called at 14:59:
                    Oct 24 14:59:13 PU-HT-1 DuetWebServer[634]: Microsoft.AspNetCore.Routing.EndpointMiddleware[0] Executing endpoint 'DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer)'
                    Oct 24 14:59:13 PU-HT-1 DuetWebServer[634]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3] Route matched with {action = "DoCode", controller = "Machine"}. Executing controller action with signature System.Threading.Tasks.Task`1[Microsoft.AspNetCore.Mvc.IActionResult] DoCode() on controller DuetWebServer.Controllers.MachineController (DuetWebServer).
                    Oct 24 14:59:13 PU-HT-1 DuetWebServer[634]: DuetWebServer.Controllers.MachineController[0] [DoCode] Executing code 'M112 M999'
                    That cancelled the file upload - was that automatic or commanded from DWC?
                    www.duet3d.com
                    • Tinchus
                      @t3p3tony I did the upload, Im sure I didnt reset the machine while uploading.
                      For the uoload I used the buttom "UPLOAD AND START"
                      T3P3Tony chrishamm 2 Replies Last reply Reply Quote 0
                      • T3P3Tony
                        @tinchus thanks for confirming that.
                        www.duet3d.com
                        • chrishamm
                          chrishamm administrators @Tinchus last edited by
                          @tinchus I could discover this in your log:
                          Microsoft.AspNetCore.Server.Kestrel.Core.BadHttpRequestException: Unexpected end of request content.
                          So it seems like something cancelled the upload request before it could finish. Can you try to upload something from a different device or using a different browser? If not, please try to upload something in incognito mode.
                          Duet software engineer
                          • Tinchus
                            Tinchus @chrishamm last edited by
                            @chrishamm the real problem here is that if something cancelled the upload... I was never told about being cancelled. I got the normal green message pop up saying upload successful
                            • Tinchus
                              @chrishamm Any suggestion on how to test? Im using firefox, so I can use the private mode. Also, this problem is not happening all the time, I have not been able to reproduce the error today
