My printer reset itself
Hello, My printer stops and resets itself,for no reason. Sometime even if I try to send M122 it resets itself. Or I do Home resets itself.
m122
RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode)
Board ID: PG2VQ-V396U-D65J0-40KM8-3Z03Z-HHJSK
Used output buffers: 4 of 40 (36 max)
Static ram: 102724
Dynamic ram: 114316 of which 24 recycled
Never used RAM 26640, free system stack 196 words
Tasks: NETWORK(ready,13.6%,240) SENSORS(delaying,0.0%,78) HEAT(delaying,0.0%,348) Move(notifyWait,0.1%,362) CanReceiv(notifyWait,0.0%,798) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,351) TMC(notifyWait,1.2%,115) MAIN(running,83.6%,426) IDLE(ready,0.8%,29) AIN(delaying,0.8%,264), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:00:51 ago, cause: reset button
Last software reset time unknown, reason: HardFault invState, GCodes spinning, available RAM 26640, slot 2
Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011e50 Task TMC Freestk 127 ok
Stack: 200190b0 20011bfc 20001064 e000e000 00000060 00089625 00000000 60000000 00000001 00000000 200117b0 0002cab3 00000004 00000003 200117b0 20011bf4 00000004 41008000 a5a5a5a5 0002cbdb a5a5a5a5 00087e75 a5a5a5a5 00000000 a5720005 0072ff05 8524000e
Error status: 0x00
Aux0 errors 0,0,0
MCU revision 3, ADC conversions started 51859, completed 51859, timed out 0, errs 0
Step timer max interval 955
MCU temperature: min 24.2, current 25.4, max 25.6
Supply voltage: min 24.1, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 25, reads 4681, writes 11, timeouts 0, DMA errors 0
Driver 1: position 0, standstill, SG min/max 4/4, read errors 0, write errors 1, ifcnt 25, reads 4681, writes 11, timeouts 0, DMA errors 0
Driver 2: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 25, reads 4681, writes 11, timeouts 0, DMA errors 0
Driver 3: position 0, standstill, SG min/max 4/4, read errors 0, write errors 1, ifcnt 25, reads 4680, writes 11, timeouts 0, DMA errors 0
Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 4683, writes 9, timeouts 0, DMA errors 0
Driver 5: position 0, standstill, SG min/max 18/18, read errors 0, write errors 1, ifcnt 25, reads 4681, writes 11, timeouts 0, DMA errors 0
Driver 6: position 0, standstill, SG min/max 18/18, read errors 0, write errors 1, ifcnt 25, reads 4681, writes 11, timeouts 0, DMA errors 0
Date/time: 2021-10-26 08:22:47
Cache data hit count 93920154
Slowest loop: 9.00ms; fastest: 0.12ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.7ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters = 0 -1, chamberHeaters = 2 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== CAN ===
Messages queued 476, received 649, lost 0, longest wait 2ms for reply type 6034, peak Tx sync delay 237, free buffers 17 (min 16), ts 260/259/0
Tx timeouts 0,0,0,0,0,0
=== Network ===
Slowest loop: 43.57ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.26
WiFi MAC address f0:08:d1:02:e8:f4
WiFi Vcc 3.37, reset reason Power up
WiFi flash size 2097152, free heap 24832
WiFi IP address 192.168.1.206
WiFi signal strength -49dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
- WiFi -
Hello ,Just happened again. Sended G29 Mesh bed level from PC and suddenly the printer stopped. Nobody touched the stop / reset button.
m122
Used output buffers: 1 of 40 (18 max)
Static ram: 102724
Dynamic ram: 114476 of which 12 recycled
Never used RAM 26492, free system stack 196 words
Tasks: NETWORK(ready,13.8%,258) SENSORS(delaying,0.0%,78) HEAT(delaying,0.0%,348) Move(notifyWait,0.1%,362) CanReceiv(notifyWait,0.0%,798) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,347) TMC(notifyWait,1.2%,115) MAIN(running,83.6%,416) IDLE(ready,0.5%,29) AIN(delaying,0.8%,264), total 100.0%
Owned mutexes:
Last reset 00:01:28 ago, cause: reset button
Last software reset at 2021-10-26 08:38, reason: User, GCodes spinning, available RAM 23420, slot 0
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
Aux0 errors 0,0,0
MCU revision 3, ADC conversions started 88284, completed 88284, timed out 0, errs 0
Step timer max interval 758
MCU temperature: min 22.2, current 22.5, max 23.1
Supply voltage: min 24.2, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 27, reads 7988, writes 11, timeouts 0, DMA errors 0
Driver 1: position 0, standstill, SG min/max 4/4, read errors 0, write errors 1, ifcnt 27, reads 7988, writes 11, timeouts 0, DMA errors 0
Driver 2: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 27, reads 7988, writes 11, timeouts 0, DMA errors 0
Driver 3: position 0, standstill, SG min/max 4/4, read errors 0, write errors 1, ifcnt 27, reads 7988, writes 11, timeouts 0, DMA errors 0
Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 7990, writes 9, timeouts 0, DMA errors 0
Driver 5: position 0, standstill, SG min/max 4/4, read errors 0, write errors 1, ifcnt 27, reads 7988, writes 11, timeouts 0, DMA errors 0
Driver 6: position 0, standstill, SG min/max 4/4, read errors 0, write errors 1, ifcnt 27, reads 7988, writes 11, timeouts 0, DMA errors 0
Date/time: 2021-10-28 07:57:44
Cache data hit count 158937548
Slowest loop: 9.08ms; fastest: 0.13ms
=== Storage ===
Free file entries: 9
SD card longest read time 3.4ms, write time 4.6ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
=== CAN ===
Messages queued 803, received 1087, lost 0, longest wait 2ms for reply type 6034, peak Tx sync delay 216, free buffers 17 (min 16), ts 442/441/0
=== Network ===
Slowest loop: 48.40ms; fastest: 0.00ms
WiFi flash size 2097152, free heap 24944
WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem
- WiFi -
@flopo76 New reset, It resets itself even without the LCD attached.
m122
RepRapFirmware for Duet 3 Mini 5+ version 3.4.0beta5 (2021-10-12 13:53:24) running on Duet 3 Mini5plus WiFi (standalone mode)
Used output buffers: 1 of 40 (13 max)
Static ram: 103844
Dynamic ram: 117644 of which 24 recycled
Never used RAM 20200, free system stack 200 words
Tasks: NETWORK(ready,14.9%,229) HEAT(notifyWait,0.0%,355) Move(notifyWait,0.0%,362) CanReceiv(notifyWait,0.0%,771) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,338) TMC(notifyWait,1.2%,105) MAIN(running,83.0%,419) IDLE(ready,0.1%,30) AIN(delaying,0.8%,264), total 100.0%
Owned mutexes:
Last reset 00:08:21 ago, cause: reset button
Error status: 0x00
Aux0 errors 0,0,18
MCU revision 3, ADC conversions started 501426, completed 501426, timed out 0, errs 0
Step timer max interval 753
MCU temperature: min 24.9, current 25.1, max 26.2
Supply voltage: min 24.2, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: pos 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 72, reads 45550, writes 11, timeouts 0, DMA errors 0
Driver 1: pos 0, standstill, SG min/max 4/4, read errors 0, write errors 1, ifcnt 72, reads 45550, writes 11, timeouts 0, DMA errors 0
Driver 2: pos 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 72, reads 45550, writes 11, timeouts 0, DMA errors 0
Driver 3: pos 0, standstill, SG min/max 4/4, read errors 0, write errors 1, ifcnt 72, reads 45550, writes 11, timeouts 0, DMA errors 0
Driver 4: pos 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 49, reads 45553, writes 9, timeouts 0, DMA errors 0
Driver 5: pos 0, standstill, SG min/max 4/4, read errors 0, write errors 1, ifcnt 69, reads 45550, writes 11, timeouts 0, DMA errors 0
Driver 6: pos 0, standstill, SG min/max 4/4, read errors 0, write errors 1, ifcnt 69, reads 45550, writes 11, timeouts 0, DMA errors 0
Date/time: 2021-10-28 09:41:14
Cache data hit count 919585577
Slowest loop: 8.09ms; fastest: 0.13ms
=== Storage ===
SD card longest read time 3.3ms, write time 3.9ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Aux is assembling a command in state(s) 0
Code queue is empty
=== CAN ===
Messages queued 4521, received 6043, lost 0, longest wait 2ms for reply type 6034, peak Tx sync delay 163, free buffers 17 (min 16), ts 2507/2506/0
=== Network ===
Slowest loop: 85.19ms; fastest: 0.00ms
WiFi flash size 2097152, free heap 21872
WiFi signal strength -48dBm, mode 802.11n, reconnections 0, sleep mode modem
- WiFi -
@flopo76 ok couple of checks:
- how is the board mounted?
- when did this start happening? How long had you used the board before it started?
- does it still happen with the same frequency with the LCD removed?
@t3p3tony Printer builded 3 month a go,Voron 2.4,board mounted stand alone,problem started 4/5 days a go. LCD removed today and already make two reset one during the mesh bed level,and one during the print. Updated today to the last printer
@flopo76 thanks, is it mounted on a plastic or metal base?
@t3p3tony Metal base, alluminium
@t3p3tony
. Now i used paneldue 5i
@flopo76 thanks that wiring looks good. just to confirm the board is on standoffs?
@flopo76 i think he ask if you have some spacers (distance bushes) under the mounting points of the Duet board...
@cosmowave yes,i have mountig bracket din for duet 3 mini5+. In Nylon Carbon filament
@flopo76 are you by any chance printing multiple objects, with more than 20 on the build plate?
@dc42 said in My printer reset itself:
Max object printed in one print was 6......
@flopo76 Just stoped again and reset in midle off the prin sesion......
M122
Static ram: 103844
Dynamic ram: 117700 of which 12 recycled
Never used RAM 20156, free system stack 198 words
Tasks: NETWORK(ready,16.0%,229) HEAT(notifyWait,0.0%,355) Move(notifyWait,0.0%,362) CanReceiv(notifyWait,0.0%,771) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,338) TMC(delaying,1.2%,105) MAIN(running,81.9%,419) IDLE(ready,0.0%,30) AIN(delaying,0.8%,264), total 100.0%
Last reset 00:26:46 ago, cause: power up
Last software reset at 2021-10-28 17:13, reason: User, GCodes spinning, available RAM 19844, slot 0
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00487000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
Aux0 errors 0,0,13
MCU revision 3, ADC conversions started 1606356, completed 1606356, timed out 0, errs 0
Step timer max interval 957
MCU temperature: min 22.9, current 25.8, max 26.5
Supply voltage: min 24.1, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: pos 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 14914, writes 11, timeouts 0, DMA errors 0
Driver 1: pos 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 14914, writes 11, timeouts 0, DMA errors 0
Driver 2: pos 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 14914, writes 11, timeouts 0, DMA errors 0
Driver 3: pos 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 14913, writes 11, timeouts 0, DMA errors 0
Driver 4: pos 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 14916, writes 9, timeouts 0, DMA errors 0
Driver 5: pos 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 14914, writes 11, timeouts 0, DMA errors 0
Driver 6: pos 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 14914, writes 11, timeouts 0, DMA errors 0
Date/time: 2021-10-28 18:34:48
Cache data hit count 2951564105
Slowest loop: 9.64ms; fastest: 0.13ms
=== Storage ===
SD card longest read time 3.8ms, write time 3.9ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Code queue is empty
=== CAN ===
Messages queued 14467, received 32117, lost 0, longest wait 2ms for reply type 6034, peak Tx sync delay 6, free buffers 17 (min 16), ts 8032/8031/0
=== Network ===
Slowest loop: 84.18ms; fastest: 0.00ms
WiFi Vcc 3.36, reset reason Power up
WiFi flash size 2097152, free heap 24696
WiFi signal strength -52dBm, mode 802.11n, reconnections 0, sleep mode modem
- WiFi -
@flopo76 Have you had any more resets since? Have you tried beta6?
@phaedrux I solved it by moving the Duet away from the power supply. It was an EMI problem, I think ....
undefined T3P3Tony marked this topic as a question
undefined T3P3Tony has marked this topic as solved
