    Solved Duet 1lc no mesh leveling
    1lc mesh bed levelling
    • jub
      jub last edited by
      I've purchased the Duet3 distribution board and 1lc to go with my 6HC for the RatRig vcore3.
      I just saw the following:
      Duet 3 with CAN expansion firmware configuration limitations
      RepRapFirmware (as at version 3.2.2) for Duet 3 with CAN-connected tool or expansion boards currently has the fo...
      Due to CAN latency the motors connected to expansion boards may slightly overshoot the position at which the endstop or Z probe was triggered. This would not usually matter for an endstop switch, but it does mean that repeated probing with a Z probe (e.g. for mesh bed compensation) is not advisable. This will be fixed in a future release
      How will I use these boards, if I can't use them for mesh bed levelling?
      Please advice. Maybe I'm missing something or am misinterpreting the statement.
        dc42 administrators @jub last edited by
        @jub what this means is that the Z motors should be driven from the 6HC and not from an expansion board. That's all.
        • rjenkinsgb
          rjenkinsgb last edited by
          As long as the toolboard is running an extruder and not the Z motor, it should have no effect?
          I have a CoreXY setup using a 6HC and toolboards; on mine, I've fitted the Z probe on the head carriage itself rather than any specific tool, and wired directly back to the main board.
          If you want to be 100% certain of zero latency, just wire the probe direct rather than via the toolboard.
          Robert J.
          Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
          dc42 T3P3Tony 2 Replies Last reply Reply Quote 0
            dc42 administrators @rjenkinsgb last edited by
            @rjenkinsgb said in Duet 1lc no mesh leveling:
            Correct. I have clarified the text at https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations. My own E3D tool changer has two extruders driven from tool boards.
            • T3P3Tony
              T3P3Tony administrators @rjenkinsgb last edited by
              yes this is how the e3d toolchanger does it right now.
              www.duet3d.com
              • jub
                jub last edited by
                Thanks everyone for the swift replies!
                Exactly the answers I needed.
