    Ability to store and process data?
    219
    • heki
      heki last edited by
      I have a few questions on the capability of Duet Wifi 3 board!
      Right now, I'm trying to:
      1. control a 3D printer with it using a pre-computed set of X, Y, Z, E commands
      2. get data from accelerometers which are attached on the printer.
      Here, the two tasks will need to be synced at a fixed frequency and also will need to be simultaneous, which I know is possible with the Duet Wifi. My question is, is it also able to store data within a certain timeframe after a command has been sent, AND process the data (e.g., plot the data ) while send/read tasks are still in progress? If so, how much storing and processing can be done?
      Sorry if it's a basic question... I've been looking at the datasheet but I'm not sure how to find the information I'm looking for.
      Thank you so much!
      o_lampe chrishamm T3P3Tony 3 Replies Last reply Reply Quote 0
      • o_lampe
        o_lampe @heki last edited by
        @heki You can poll any available data from the object model and store it on SD-card. (not sure about accelerometer data)
        Processing or plotting will happen on the PanelDue or DWC.
        heki 1 Reply Last reply Reply Quote 0
        • chrishamm
          chrishamm administrators @heki last edited by
          @heki It sounds like you need real-time control, so you'd probably have to change the firmware to achieve that. RRF already supports data collection of accelerometers (see M955 and M956) but the received data is only written to CSV files and not (yet) exposed via the object model.
          Duet software engineer
          • T3P3Tony
            T3P3Tony administrators @heki last edited by
            @heki is this data collection phase supposed to occure during a set of tests moves or during every print?
            The quickest way to do this would be to connect the accelerometer to an SBC (Raspberry PI) connected to the Duet in SBC mode and then write a script on the pi that grabbed the accelerometer data, the position from the Duet, and then stored it. The control commands could also be sent from this script, or they could be generated in advance.
            www.duet3d.com
            • heki
              heki @T3P3Tony last edited by
              @t3p3tony Thank you so much for your reply. So actually we've considered using RPi but the thing is that our motion command data and accelerometer data will need be able to be aligned so that some input/output relationship can be computed (and yes, this data collection only occurs during a set of test moves, not for every print). Using RPi to do this, it may be a little bit hard because there is no absolute timestamps on the data/command to align.. or is there?
              The ideal case would be if the input collection and processing can be done on the board, at same sampling frequency, so that this aligning process is smooth. But if not, do you think there's another way to align this using RPI?
              • T3P3Tony
                @heki how precisely co-ordinated do you need the correlation?
                www.duet3d.com
                • heki
                  heki @chrishamm last edited by
                  @chrishamm Thank you so much for the reply. So to be precise, it needs the "sending command" and 'receiving data" tasks to be aligned, so that some input/output relationship of the printer dynamics can be computed (either in real time, or after some time delay). So do you mean it will be hard to do both "sending" and "receiving" in the board to compute, since the received data may not be exposed via object model, so it needs some conversion post-processing to do computation on the data afterwards?
                  o_lampe 1 Reply Last reply Reply Quote 0
                  • heki
                    @t3p3tony So the timeframe onto which the input/output should be aligned is in 1 ms units, but at this moment I've yet to test how sensitive the input/output relationship will be by changing the precision of alignment..
                    • heki
                      heki @o_lampe last edited by
                      @o_lampe I see, thank you so much.
                      • o_lampe
                        @heki said in Ability to store and process data?:
                        I wouldn't connect the accelerometer to the Duet, but let the RasPi read out the data directly. There are Arduino libraries for the accel-sensor, they can be rewritten in python, for sure.
                        BTW: the sample rate of the sensor is pretty low (some kHz?) . I'd rather use interrupts to control the poll-rate instead of fixed intervalls.
                        That optimizes the amount of processable data.
                        • T3P3Tony
                          T3P3Tony administrators @heki last edited by T3P3Tony
                          @heki so in rough outline the data flow is:
                          • read from input (SD card, USB, Network, UART etc)
                          • process (buffer, plan, step generation)
                          • step output to motors
                          The difference in SBC mode for commands coming from the SBC is the input stage can be intercepted and logged/used in some way. Other than that the Duet is doing the processing and step generation.
                          What exactly do you need to collect?
                          • Whole moves?
                          • individual steps?
                          • something in between?
                          You may be able to get what you need but running a move, capturing the accelerometer data as we do already and then processing it after the fact. then running another move. After all you know the move you commanded, and you know the accelerometer response.
                          www.duet3d.com
