    E3D high temp heated bed with IR sensor.
    IR Height Sensor
    • Surgikill
      Surgikill last edited by
      Hi all,
      I just upgraded my bed to the E3D high temp heated bed with the 4mm thick borosilicate glass. The heated bed has a black coating on it with some white stenciling. The bottom of my IR sensor is 1.3mm above my nozzle. When running the calibration for the trigger height, I ended up getting negative values in the .1mm range. I put blue tape on the top of the glass and now it triggers around 1.9mm. Has anybody used this bed and glass combo before? I was hoping that it would trigger normally and not crazy low. The bed is black so it should not be an issue, and I don't think I can really use paper between the bed and the glass when the bed gets up to 200-250C. Any ideas on what I can do here?
      o_lampe 1 Reply Last reply Reply Quote 0
      • o_lampe
        o_lampe @Surgikill last edited by
        @surgikill I'd be concerned about false readings on the white stencil. You can spray black oven-paint on the bed. It can stand much higher temps.
        *) not tested by me but others have done it. Try at your own risk
