Solved Auto power resume not working
Dear @dc42 ,
Greetings from Ex3DP.
We are using Duet2 Wi-Fi. We want to activate auto power resume option on the same. We have tried all the possibilities mentioned on
https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure and also tried executing suggestions provided on Duet forum under auto power resume discussion, but there is no success till today.We have attached images / screenshots of our work for your ready reference. Kindly provide your valuable inputs on the same.
Regards,
Ex3DP
@ex3dp Can you check the name of your "resurrect-prologue.g" file it looks to me as if there may be a space on each side of the "-", so it is actually "resurrect - prologue.g", it is hard to be sure though.
@gloomyandy Thank you so much for the suggestion. We will definitely check and modify if needed. But is there any technical issue in the code besides what you suggested to incorporate ?
@gloomyandy Hello. Your suggestion / solution helped us to resolve the issue. Thank you so much.. Appreciated.
T3P3Tony
T3P3Tony
