    Automatic builds
    Firmware wishlist
    254
    • gregsaun
      gregsaun last edited by
      Hi All,
      For the Bear Duet project we will have a single repository for on our GitHub with release that contains all the necessary files and configurations for installing Duet RRF and PanelDue to our Duet Mini 5+ board. I am doing a GitHub action script to automate the release creation (gather files from Duet GitHub release, make our own splash screen, create a draft release and upload all necessary files to the draft release).
      I have noticed that filenames are changing between the releases and this makes the automation script more difficult and it might be more prone to errors. This makes me thing that the RRF and PanelDue firmware release are made manually and I am wondering if automating this process would be possible in the future. This would reduce risks of human error, reduce time needed to make the release and make it more consistent over time.
      I would be very happy to help with this however, I might not be the best person as I am new to Duet RRF and have not tried to build it myself yet.
      github.com/gregsaun - Papa Bear
      oliof 1 Reply Last reply Reply Quote 1
      • oliof
        oliof @gregsaun last edited by
        @gregsaun that woulf be great if combined with a move to cmake ...
        <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
        gregsaun 1 Reply Last reply Reply Quote 1
        • gregsaun
          gregsaun @oliof last edited by gregsaun
          @oliof Ah yes that would be great too. This can probably be handled as two separate tasks but I agree it would make sense. Moving to cmake is probably a lot of work.
          oliof 1 Reply Last reply Reply Quote 0
          • oliof
            oliof @gregsaun last edited by oliof
            @gregsaun there is an incomplete PR by @mfs12 that only targets Duet2the mini 3, covering all the other target devices would be "just work", but of course it's up to @dc42 to make that call (-;
            • mfs12
              mfs12 last edited by mfs12
              Hey @gregsaun, @oliof,
              Paneldue is already ported to cmake. Check the github repo https://github.com/Duet3D/PanelDueFirmware
              It runs perfectly within Arch Linux so integration with automated build based on docker or similar should be feasible.
              I also started this work for RepRapFirmware. It brings basic support for the mini5+. It needs most of the configuration for other boards to be ported. Otherwise i think it's a good basis to start off.
              Check https://github.com/mfs12/RepRapFirmware/tree/integrate-cmake-build-system
              Visit me on github at https://github.com/mfs12/
              gregsaun 1 Reply Last reply Reply Quote 2
              • gregsaun
                gregsaun @mfs12 last edited by
                @mfs12 That is awesome to head, thanks for that work. So yes for PanelDue we can use GitHub actions, it is using docker and you can specify the OS as well if you like.
                mfs12 1 Reply Last reply Reply Quote 0
                • mfs12
                  mfs12 @gregsaun last edited by mfs12
                  @gregsaun can you share the github action files. So far i am not familiar with github actions but would like to have this integrated as well.
                  gregsaun 1 Reply Last reply Reply Quote 0
                  • gregsaun
                    @mfs12 It is not published yet but here is the create release GitHub action script I am currently using to create the release:
                    create_release.yml.txt
                    I have an external script to create the zip files and for now the splash screen creation isn't done yet. You need to rename the file as .yml
                    • mfs12
                      @gregsaun, thanks i will have a look into it.
                      • mfs12
                        BTW to build Paneldue any Linux should be fine no need to use specifically Arch Linux.
                        • gregsaun
                          @mfs12 Don't hesitate if you need help 🙂
                          • gregsaun
                            For info, this is how my draft release looks like on GitHub after the automatic creation
