    Duet 2 Wifi not reading line of code
    183
    • PRIOR123
      PRIOR123 last edited by
      Hi All,
      Im trying to sort out my homing commands and am using the below. However the printer doesnt seem to be reading the BOLD
      G1 H2 Z-5 F6000 ; lift Z relative to current position
      G1 H1 X505 F1800 ; move quickly to X axis endstop and stop there (first pass)
      **G1 H2 X-5 F6000 ; go back a few mm
      G1 H1 X505 F360 ; move slowly to X axis endstop once more (second pass)**
      G1 H2 Z5 F6000 ; lower Z again
      G90 ; absolute positioning
      i know it will likely be my coding however im not sure whats wrong. Any help is much appreciated
      PRIOR123 T3P3Tony 2 Replies Last reply Reply Quote 0
      • PRIOR123
        PRIOR123 @PRIOR123 last edited by
        I guess it would be useful to understand what H and F codes mean to if anyone is able to explain
        • deckingman
          deckingman @PRIOR123 last edited by
          @prior123 said in Duet 2 Wifi not reading line of code:
          See here - https://duet3d.dozuki.com/Wiki/G1
          PRIOR123 1 Reply Last reply Reply Quote 0
          • T3P3Tony
            T3P3Tony administrators @PRIOR123 last edited by
            @prior123 do you mean its homing properly, just not doing the back off and re try slower part?
            www.duet3d.com
            • PRIOR123
              PRIOR123 @T3P3Tony last edited by
              @t3p3tony - Yeah eactly, however i just tried to update the firmware to 3.3 and it went wrong.
              I have just connect it to YAT to try ad get it on the WIFI again and is giving me this
              Error: M587: Failed to add SSID to remembered list: another SPI transfer is pending
              Not sure you would know what id need to do?
              • PRIOR123
                PRIOR123 @deckingman last edited by
                @deckingman Thank you
                • PRIOR123
                  im unable to disconnect or reconnect due to this. Is there a way i can reset the firmware?
                  • T3P3Tony
                    @prior123 try resetting the board.
                    What part of the upgrade to 3.3 went wrong.?
                    In YAT what is the response to M115?
                    www.duet3d.com
                    • PRIOR123
                      @t3p3tony How do i reset the board?
                      • PRIOR123
                        @prior123 it seemed like it had frozen on the DWC when installing (i expect i disconnected before i shoudve)
                        M115 says this
                        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet
                        FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later
                        FIRMWARE_DATE: 2021-06-15 21:45:03
                        • T3P3Tony
                          @prior123 ok and does DWC work now?
                          www.duet3d.com
                          • PRIOR123
                            @t3p3tony no, i cant get onto it at all
                            • T3P3Tony
                              @prior123 if you send M552 what response do you get?
                              www.duet3d.com
                              • T3P3Tony
                                @prior123 also M122
                                www.duet3d.com
                                • PRIOR123
                                  @t3p3tony
                                  WiFi module is being started
                                  • PRIOR123
                                    @t3p3tony
                                    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
                                    Board ID: 0JD0M-9P6M2-NWNS4-7JKD8-3SD6S-KU1BM
                                    Used output buffers: 1 of 24 (2 max)
                                    Static ram: 23876
                                    Dynamic ram: 75400 of which 0 recycled
                                    Never used RAM 15140, free system stack 170 words
                                    Tasks: NETWORK(ready,7.7%,517) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,340) MAIN(running,92.1%,445) IDLE(ready,0.0%,29), total 100.0%
                                    Owned mutexes: USB(MAIN)
                                    Last reset 00:47:08 ago, cause: power up
                                    Last software reset details not available
                                    Error status: 0x00
                                    Aux0 errors 0,0,0
                                    Step timer max interval 0
                                    MCU temperature: min 20.9, current 23.1, max 25.3
                                    Supply voltage: min 0.4, current 0.5, max 24.0, under voltage events: 1, over voltage events: 0, power good: no
                                    Driver 0: position 0, standstill, SG min/max not available
                                    Driver 1: position 0, standstill, SG min/max not available
                                    Driver 2: position 0, standstill, SG min/max not available
                                    Driver 5: position 0
                                    Driver 6: position 0
                                    Driver 7: position 0
                                    Driver 8: position 0
                                    Driver 9: position 0
                                    Driver 10: position 0
                                    Driver 11: position 0
                                    Slowest loop: 101.38ms; fastest: 0.14ms
                                    === Storage ===
                                    Free file entries: 10
                                    SD card longest read time 2.9ms, write time 0.0ms, max retries 0
                                    === MainDDARing ===
                                    === AuxDDARing ===
                                    Heater 1 is on, I-accum = 0.0
                                    Segments left: 0
                                    Movement lock held by null
                                    HTTP is idle in state(s) 0
                                    Telnet is idle in state(s) 0
                                    File is idle in state(s) 0
                                    USB is ready with "M122" in state(s) 0
                                    Aux is idle in state(s) 0
                                    Trigger is idle in state(s) 0
                                    Queue is idle in state(s) 0
                                    LCD is idle in state(s) 0
                                    Daemon is idle in state(s) 0
                                    Code queue is empty.
                                    === Network ===
                                    Slowest loop: 0.32ms; fastest: 0.00ms
                                    HTTP sessions: 0 of 8
                                    • WiFi -
                                      Network state is starting2
                                      WiFi module is disabled
                                      ok
                                    • droftarts
                                      droftarts administrators last edited by
                                      @prior123 Reflash the WiFi firmware from a USB terminal connection with M997 S1. It occasionally fails when updating all firmware files.
                                      • PRIOR123
                                        PRIOR123 @droftarts last edited by
                                        @droftarts said in Duet 2 Wifi not reading line of code:
                                        M997 S1
                                        its says this :s
                                        Error: M997: File 0:/firmware/DuetWiFiServer.bin not found
                                        • droftarts
                                          droftarts administrators @PRIOR123 last edited by droftarts
                                          @prior123 I guess you updated from 3.2, so firmware folder is not created yet. Try
                                          M997 S1 P”0:/sys/DuetWiFiServer.bin”
                                          M997 S1
                                          its says this :s
                                          • PRIOR123
                                            It posted this
                                            Error: M997: expected string expression
                                            Thank you and im sorry this is being such a pain. I need to be more patient haha
                                            • droftarts
                                              @prior123 sorry, should be straight quotes not curly! Damn phone… Try:
                                              M997 S1 P"0:/sys/DuetWiFiServer.bin"
                                              • PRIOR123
                                                @droftarts Success Thank you!!!
