PanelDue Firmware 3.4.0-pre4 released
Hey, here's a new pre-release. It brings a few bug fixes and fixes of translations.
Please drop a line if you stumble over a bug, have a new idea or tested the firmware successfully.
Enjoy the rest of the weekend!
Release Notes 3.4.0-pre4
This release requires RepRapFirmware 3.4 or later.
Version 2 (after August 2016) and Version 3 PanelDue are supported.
- add cross-platform headless builds based on cmake
- cleaned up dim/screensaver handling
- removed compiler warnings
- enabled Russian localization by default
- enabled Ukrainian localization by default
- improved list-locales tool for translation debugging
- fixed displaying of M291 S2 and S3 if followed by M292
- fixed displaying macro buttons in control tab
- fixed setting of serial baud rate after reboot
- cleaned up English
- cleaned up Czech translation
- cleaned up French translation
- cleaned up German translation
- fixed access to second sd card
- cleaned up Russian translation
- fixed persistent pressed button handling in some dialogs
- fixed updates via RRF
- fixed displaying of multiple heaters per tool
- improved readme
- fix brightness handling during pop-ups
- disabled spammy debug information
- show babystep button if printer is idle
- cleaned up Spanish translation
Downloads and flashing instructions:
Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.4.0-pre4
Flashing instructions can be found at https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
@mfs12 were all those changes made between pre 3 and pre4?
@jay_s_uk, no, this are all the changes since 3.3.0.
I changed the format, so in future you can just look at the last line of release notes and all following are then contained in the new release.
New release out now.
https://forum.duet3d.com/topic/25875/paneldue-firmware-3-4-0-rc1-released
mfs12
mfs12
