    Solved [ PanelDue Firmware 3.4.0-pre4] M291 issue
    PanelDue
    187
    • oozeBot
      oozeBot last edited by
      We observed an issue with M291 that we hadn't seen until updating the firmware to 3.4-pre4 on firmware 3.4b5. It's strange, but repeatable..
      If you create a macro with the following code, the message will not display on the PanelDue until after the user clicks OK/Cancel in DWC. The PanelDue just reads "Busy". After clicking OK/Cancel in DWC, the prompt is displayed on the PanelDue.
      if boards[0].vIn.current > 23
        M291 S3 R"Test" P"Testing"
      This is vital to our power toggle routine as you now can't turn of a machine from the PanelDue. If you need more info, let us know. I am hoping this is easy to reproduce.
      Thanks
      • mfs12
        mfs12 last edited by
        Hey @oozeBot, I took your script and changed the if condition so it evaluates always true and with that change i couldn't reproduce the issue.
        Does it always happen? Are there any further pre-conditions to setup?
        Visit me on github at https://github.com/mfs12/
        oozeBot 1 Reply Last reply Reply Quote 0
        • Topic has been marked as a question  mfs12 mfs12
        • oozeBot
          oozeBot @mfs12 last edited by
          @mfs12 I think we've figured this out - with this build, there is at least a 5 second delay in displaying the M291 messages on the PanelDue. During this time, the PanelDue just reads 'Busy'. I can't say it's all M291 messages, but it definitely is happening with the above snippet..
          I also forgot to mention this is a 6HC with attached SBC.
          So what I initially reported was wrong, but there does seem to be an issue as that delay is long enough where it feels as if it's not working.
          • mfs12
            @oozeBot, can you share your configuration and a detailed step by step procedure. I need also to know how you reach the state busy? So prerequisites are important as well.
            • oozeBot
              oozeBot @mfs12 last edited by oozeBot
              @mfs12 I had a chance to revisit this and think I better understand what is happening. This delay does not happen after a fresh reboot. It is only happening after running "M999 A1". This command is used to soft-reset the PanelDue, which is needed as part of our Power Toggle routine, but no longer seems to work in this latest build.
              @wilriker had recently added this around 3.2.
              It's this "M999 A1" command that is killing our macro. And once recovered, the PanelDue seems sluggish until reset.
              As I mentioned, soft-resetting the PanelDue is very important to us. Please let us know how we can assist further in helping make it functional again. Thanks!
              • mfs12
                mfs12 last edited by mfs12
                @oozeBot, please describe your process in detail step by step so i can try to reproduce it. Thanks a lot.
                Here's a template how a clean bug report could look like.
                Description
                Please add a brief description of your bug here.
                Versions
                Please add a list of products and software versions involved.
                Process
                Please add a step by step description on how to reproduce the bug.
                Experienced Result
                Please describe experienced result.
                Expected Result
                Please describe the expected result.
                • oozeBot
                  So the machine I have been testing on has an issue that can't yet be explained. I just tested 4 other machines - all running 3.4b5 - and none of them have issues. For some reason, this machine will not accept M999 (or M999 A1) in a macro - it just goes into a busy state and stays that way. However, M999 works just fine from the console..
                  So this does not appear to be a PanelDue issue. Thanks and sorry for the false alarm.
                  • Topic has been marked as solved  oozeBot oozeBot
                  • oozeBot
                    This issue has been solved.. thankfully. It was caused by an old version of DuetPiManagementPlugin that was installed. Once removed, M999 is now processing inside macros.
                    T3P3Tony 1 Reply Last reply Reply Quote 2
                    • T3P3Tony
                      T3P3Tony administrators @oozeBot last edited by
                      @oozebot thanks for reporting the fix!
                      www.duet3d.com
