    PENDANT ONLY SEND THE M112
    • madedi123
      madedi123 last edited by
      Hello
      My problem is that my pendant (the same as david's, with an arduino micro) only sends the M112 command, but does not perform any movement via the encoder. My hardware is a DUET3 6HC with SBC and without Panel DUE, Configuration CNC. The arduino sketch was uploaded with firmware 1.8.1 thank you for your help
      • T3P3Tony
        T3P3Tony administrators @madedi123 last edited by
        @madedi123 have you seen this thread:
        https://forum.duet3d.com/topic/24873/cnc-pendant-disconnecting-duet/10?_=1635943175415
        how do you know its sending M112?
        I am not sure if this has been tested with an SBC mode machine (although it should work as its doing the same as a PanelDue basically).
        www.duet3d.com
        • madedi123
          i can read it on dwc console, but nothing when i turn the encoder?
          • madedi123
            do you know if i have to configure something in davids ino file from github ?
