    Ender 3 pro quality issues
    • Messiahman
      Messiahman last edited by Messiahman
      Hi all, as the title suggests I am having trouble with my ender 3 pro print quality, which i cannot determine if it is due to hardware or calibration. I am running a duet 2 wifi with a bantamount dual 5015 mount, stock extruder, bltouch, metal extruder, capricorn bowden tube, glass build plate and steel core timing belt for the x axis (which will soon be replaced with the stock once i get it from e3d). Below is my config file and a couple photos of my most recent benchy. I also plan on extending the build volume to 400x400x500 and wish to eventually print at high speeds and quality, though I first need to reach quality here.
      ; generated by RepRapFirmware Configuration Tool v3.3.3 on Wed Oct 06 2021 12:37:23 GMT-0400 (Eastern Daylight Time)
      M550 P"The Print-inator" ; set printer name
      M918 P1 E4 F2000000 ; configure direct-connect display
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M92 X80.00 Y80.00 Z400.00 E136.79 ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X2600.00 Y2600.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X235 Y235 Z260 S0 ; set axis maxima
      M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P9 C"^zprobe.in" H3 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X40.00 Y5.0 Z0.333 ; set Z probe trigger value, offset and trigger height
      M557 X40:220 Y25:220 S41 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M143 H0 S150 ; set temperature limit for heater 0 to 150C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S275 ; set temperature limit for heater 1 to 275C
      M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on
      FD494F1B-8426-4EF3-87E3-F2A7A0ABA582.jpeg 03B15971-89A8-4DE1-9AB6-73369DC7D58E.jpeg A6019A97-53F1-4962-B333-564C1159B107.jpeg 68C8E40E-6D64-4719-A544-AF9DA9F0A002.jpeg 076ED211-3144-421E-93D7-84658C67FAFB.jpeg C1FB0CBC-1D50-4ECB-AC1C-9ACD02D30EE9.jpeg03B15971-89A8-4DE1-9AB6-73369DC7D58E.jpeg
      Messiahman T3P3Tony 2 Replies Last reply Reply Quote 0
      • Messiahman
        Messiahman @Messiahman last edited by
        @messiahman I would like to add that I would prefer to keep the settings in the printer rather than in any slicer so I do not have to worry about switching between computers
        • T3P3Tony
          T3P3Tony administrators @Messiahman last edited by T3P3Tony
          @messiahman I would break the troubleshooting down into steps. prints like the benchy may be interesting to compare overall print times and some quality but for tuning you want individual models that test just 1 thing so you can tune those in 1 step at a time with fast prints that allow you to iterate over lots of different versions of one setting quickly.
          If you look on prusaprinters or other 3d file sharing sites you should see various tests for retractions, temperature towers, bridging etc etc.
          Generally I start with:
          1. Confirming that the extruder steps/mm is correct and that the other axis steps/mm speeds etc are appropriate. ensure your PID is tuned for the extruder.
          2. Checking for the best print temperatures for the filament (temp tower) and fan settings.
          3. iterate through jerk and acceleration values to get acceptable quality
          4. tune more advanced features like PA and Input shaping if appropriate.
          Thats a very rough outline. there are guides online on how to do this in detail. In addition the settings the printer shipped with should be a good start point for tuning.
          www.duet3d.com
          Messiahman 2 Replies Last reply Reply Quote 0
          • Messiahman
            Messiahman @T3P3Tony last edited by
            @t3p3tony This is after tuning it, which is why I wasn't sure if it was hardware or not
            • Messiahman
              @t3p3tony I also don't know the gcode for some of those for reprap, so I was hoping I could have a little bit of a walkthrough with someone who knows what they're talking about lol
              • T3P3Tony
                @messiahman so probably best to step through the issues you are seeing (using some test prints that target just one issue) and then if you can't find the setting you need to modify then we can of course point you in the right direction.
                here are some links to help you get started:
                M92: Allows programming of steps per mm for motor drives.
                M566: Sets the maximum allowable speed change (sometimes called 'jerk speed') of each motor when changing direction.
                M201: Sets the acceleration that axes can do in mm/second^2 for print moves.
                M203: Sets the maximum feedrates that axes can do in mm/min.
                https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                https://duet3d.dozuki.com/Wiki/Setting_motor_currents
                and for later on:
                https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
                https://duet3d.dozuki.com/Wiki/Pressure_advance
                This guide mentions a Maestro and its based on slightly older RRF but the tuning steps will be basically the same
                https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
                www.duet3d.com
