    DWC UPDATE PROBLEMS WITH NEW DUET 3 6HC
    Duet Web Control
    141
    • Gianluca
      Gianluca last edited by
      I have made the switch from a Duet 2 wi-fi to a Duet 3 6hc (v.1.01a) and have some problems with DWC updates.
      I started Duet 3 with the SBC setup, but for now I prefer to use the stand alone mode.
      The motherboard came with FW. 3.3 and DWC 3.3.
      I have updated the motherboard firmware to the latest 3.4 B5 but I am having difficulty updating the DWC to version 3.4 B5.
      The printer is configured and fully functional.
      As for the Duet 2 I updated all through DWC 3.3. Mainboard firmware and Paneldue firmware is upgraded without problems, but when I update the DWC and go from 3.3 to 3.4b5 the update is finalized regularly but as soon as I update the web page, it returns to the previous ver. 3.3.
      In addition, the plug-ins don't work.
      I also had the same DWC update problem in SBC mode.
      Thanks for the suggestions that will come.
      • T3P3Tony
        T3P3Tony administrators @Gianluca last edited by T3P3Tony
        @gianluca how are you updating DWC?
        I would get the DuetWebControl-SD.zip from here:
        https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.0beta5
        The use the "upload system Files" in DWC -> system to upload it and install it.
        If that does not work then you can put the contents of the zip in the "www" directory on the SD card using your PC.
        As @jay_s_uk says use the unstable branch to update in SBC mode.
        www.duet3d.com
        jay_s_uk 1 Reply Last reply Reply Quote 0
        • jay_s_uk
          jay_s_uk @T3P3Tony last edited by
          @t3p3tony its an SBC so he needs to switch to the unstable branch
          https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
          • T3P3Tony
            T3P3Tony administrators @jay_s_uk last edited by
            @jay_s_uk ahh yes good spot! I missed the SBC bit.
            www.duet3d.com
            • Gianluca
              Now I'm run stand alone mode, I have already tried to upgrade both from DWC, and also by copying the DWC folder downloaded from Gitub directly into the WWW folder of the SD.
              The update is done, I see the updated DWC, but when I reload the page in the browser it returns to the previous DWC 3.3 ...
              • jay_s_uk
                jay_s_uk @Gianluca last edited by
                @gianluca sounds like a cache issue. try clearing the cache or a different browser to confirm
                Gianluca 1 Reply Last reply Reply Quote 0
                • Gianluca
                  Gianluca @jay_s_uk last edited by
                  @jay_s_uk said in DWC UPDATE PROBLEMS WITH NEW DUET 3 6HC:
                  Yes, it could be a Firefox error... in addition, I also have an error on the execution of DWC the internal plugins, this evening I write exactly the error found ...
                  I also did various tests with SD of different sizes and with various formatting mode.
                  • Gianluca
                    I have successfully updated the DWC through Microsoft Edge. It worked stably. With Duet 2 and Mozilla Firefox there have never been any update problems. Anyway problem solved.
