    Something like Klipper "TUNING_TOWER"
    • peirof
      peirof last edited by
      Of the new printer I have ordered, you can order with Duet or Btt Octopus.
      Those that come with a board with Klipper installed, so I have read they have a function called "TUNING_TOWER", which seems to be inserted at the beginning of the gcode to print and changes the values of pressure in advance and I think it changes retraction with the layers
      In this way it can be identified, once the piece is printed at what height the best finish is achieved, better values for retraction and pressure in advance
      Is there any way to emulate this with Duet?
      Thx
      zapta 1 Reply Last reply Reply Quote 0
      • zapta
        zapta @peirof last edited by zapta
        @peirof , does this help? Scroll down to "Simplest Method Possible" in that page.
        https://duet3d.dozuki.com/Wiki/Pressure_advance
        Edit: duet allows to change configuration at any time during the print so you can use this technique to create a tuning tower for any config parameter you like.
        peirof 1 Reply Last reply Reply Quote 1
        • peirof
          peirof @zapta last edited by
          @zapta sure, thanks....
