Mesh bed leveling without M557
Dear users,
I noticed there is a possibility to create a mesh.g file and I'm wondering if i can use it to do the following. (I'm not totally sure how to use it so please enlighten me)
I have some hysteresis in my Z-probe. This means that if I run the G29 command and automatically probe all the predefined points, the value starts to shift to a point that the mesh is unusable. Normally before probing I measure the analog value of the probe and set a new threshold by adding a value to that measured value. Is there a way I can set a new threshold to trigger before every probe move in the mesh.g. I already have this code set up for regular bed leveling but I'm assuming I can't use the G30 command to do mesh bed leveling. Is this correct?
This is the code i already use:
probe.gif !exists(param.X) || !exists(param.Y) ;if parameter X and Y are given echo "Make sure parameter X and Y are given (C and S optional). Aborting probe move." ;notify user G1 X{param.X} Y{param.Y} Z{sensors.probes[0].diveHeight} F6000 ;move to given X and Y coordinates and predefined diveheight M400 ;wait for moves to finish M291 R"Waiting for extruder." P" " S1 M116 P0 S2 ;wait for extruder to reach temperature M568 P0 A0 ;turn the extruder heater off (interference changes sensor reading) G4 S1 ;wait 1 second M98 P"preprobe.g" ;call macro to determine triggervalue and see if it is okay to proceed probing M292 M291 R"Probing." P" " S1 if global.proceedProbe = true ;if its okay to proceed probing if exists(param.C) ;if parameter C is given if exists(param.S) ;if parameter S is given G30 X{param.X} Y{param.Y} P{param.C} S{param.S} Z-9999 ;probe move else ;otherwise G30 X{param.X} Y{param.Y} P{param.C} Z-9999 ;probe move elif exists(param.S) ;if parameter S is given G30 X{param.X} Y{param.Y} S{param.S} Z-9999 ;probe move else ;otherwise G30 X{param.X} Y{param.Y} Z-9999 ;probe move elif (global.proceedProbe = false) ;if it isnt okay to proceed probing echo "Aborting probe move" ;notify user M292 M568 P0 A1 ;set the extruder heater to standby
preprobe.g
if !exists(global.proceedProbe) ;if variable doesnt exist yet global proceedProbe = false ;initialize variable if exists(global.triggerVal) ;if a triggervalue has been defined if sensors.probes[0].value[0] <= 922 && sensors.probes[0].value[0] >= 200 ;if the sensorvalue is within acceptable range var measuredVal = {sensors.probes[0].value[0]} ;measure the sensor value G31 P{var.measuredVal + global.triggerVal} ;set the triggervalue to the measured value + the triggervalue ;echo "Measured sensor value is", {var.measuredVal}, ". Triggervalue has been set to", {sensors.probes[0].threshold}, "." ;notify user set global.proceedProbe = true ;set variable so probing can proceed else ;otherwise echo "Measured sensor voltage is out of range at ", {(var.measuredVal * 5)/1024}, "V." ;notify user set global.proceedProbe = false ;set variable so probing wont proceed else ;otherwise echo "The variable triggerVal has not been declared in the config.g file (default = 100)" ;notify user set global.proceedProbe = false ;set variable so probing wont proceed
So instead of using the G30 command to probe i use M98 P"probe.g".
@piet if you cant change the way your probe works to not have the analogue hysteresis then you could manually create the mesh by carrying out the "G30" probes you want to, using G30 S-1:
G30 S-1 ; Probe the bed at the current XY position. When the probe is triggered, do not adjust the Z coordinate, just report the machine height at which the probe was triggered.
You would need to format the outputs in the same manner as heightmap.csv, potentially you could do this with a macro that stepper through the points you want and echoed it to a file using the ">>" construct.
@t3p3tony Smart! I don't have a heightmap saved, do you by any chance have an example so i can see how it's formatted?
here is an example
RepRapFirmware height map file v2 generated at 2021-04-28 22:58 xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum 5.00,290.00,10.00,190.00,-1.00,15.00,15.00,20,13 0.088, 0.103, 0.097, 0.082, 0.103, 0.097, 0.088, 0.060, 0.049, 0.049, 0.049, 0.082, 0.090, 0.103, 0.114, 0.123, 0.133, 0.140, 0.139, 0.135 0.043, 0.058, 0.035, 0.037, 0.058, 0.059, 0.042, 0.021, 0.040, 0.037, 0.044, 0.051, 0.045, 0.076, 0.089, 0.100, 0.109, 0.116, 0.116, 0.110 0.024, 0.040, 0.018, 0.019, 0.043, 0.037, 0.002, 0.001, -0.004, -0.002, 0.000, 0.026, 0.039, 0.052, 0.040, 0.075, 0.088, 0.089, 0.091, 0.087 0.013, 0.017, -0.002, 0.027, 0.023, 0.013, 0.013, -0.017, 0.005, 0.002, 0.005, 0.014, 0.023, 0.034, 0.031, 0.057, 0.070, 0.074, 0.073, 0.067 0.002, 0.008, -0.012, 0.017, 0.012, -0.017, 0.002, 0.001, -0.001, -0.007, -0.001, 0.003, -0.017, 0.024, 0.041, 0.047, 0.058, 0.061, 0.062, 0.055 -0.003, 0.004, 0.005, -0.022, 0.002, -0.006, -0.010, -0.014, -0.013, -0.014, -0.012, -0.008, 0.002, 0.013, 0.030, 0.036, 0.046, 0.049, 0.048, 0.042 -0.009, -0.003, 0.001, -0.003, -0.003, -0.013, -0.018, -0.022, -0.025, -0.024, -0.021, -0.018, -0.006, 0.003, 0.019, 0.027, 0.037, 0.039, 0.036, 0.030 -0.006, -0.001, -0.004, -0.004, -0.008, -0.017, -0.021, -0.026, -0.030, -0.031, -0.028, -0.022, -0.013, -0.001, 0.012, 0.020, 0.029, 0.033, 0.030, 0.023 -0.005, -0.006, -0.007, -0.004, -0.007, -0.018, -0.023, -0.027, -0.030, -0.033, -0.031, -0.025, -0.014, -0.004, 0.011, 0.020, 0.029, 0.031, 0.027, 0.022 0.001, 0.003, -0.000, 0.000, -0.005, -0.014, -0.020, -0.026, -0.031, -0.033, -0.032, -0.024, -0.018, -0.005, 0.004, 0.020, 0.027, 0.030, 0.027, 0.022 0.005, 0.007, 0.004, 0.004, 0.001, -0.007, -0.016, -0.021, -0.026, -0.026, -0.027, -0.021, -0.015, -0.002, 0.010, 0.020, 0.029, 0.033, 0.029, 0.026 0.022, 0.026, 0.019, 0.018, 0.014, 0.008, 0.001, -0.006, -0.013, -0.014, -0.016, -0.008, 0.001, 0.013, 0.026, 0.033, 0.039, 0.041, 0.039, 0.035 0.043, 0.044, 0.035, 0.035, 0.019, 0.020, 0.013, 0.007, 0.002, -0.015, 0.000, 0.003, 0.013, 0.022, 0.035, 0.042, 0.028, 0.052, 0.049, 0.046
For future reference, this works.
The probe file can be adjusted to allow for different types of probing.if !exists(param.X) || !exists(param.Y) ;if parameter X and Y are given echo "Make sure parameter X and Y are given (C and S optional). Aborting probe move." ;notify user G1 X{param.X} Y{param.Y} Z{sensors.probes[0].diveHeight} F6000 ;move to given X and Y coordinates and predefined diveheight M400 ;wait for moves to finish M98 P"waitForHeaters.g" H01 M568 P0 A0 ;turn the extruder heater off (interference changes sensor reading) G4 S1 ;wait 1 second M98 P"preprobe.g" ;call macro to determine triggervalue and see if it is okay to proceed probing ;M291 R"Probing." P" " S1 if global.proceedProbe = true ;if its okay to proceed probing if exists(param.C) ;if parameter C is given if exists(param.S) ;if parameter S is given G30 X{param.X} Y{param.Y} P{param.C} S{param.S} Z-9999 ;probe move else ;otherwise G30 X{param.X} Y{param.Y} P{param.C} Z-9999 ;probe move elif exists(param.S) ;if parameter S is given G30 X{param.X} Y{param.Y} S{param.S} Z-9999 ;probe move else ;otherwise G30 X{param.X} Y{param.Y} Z-9999 ;probe move elif (global.proceedProbe = false) ;if it isnt okay to proceed probing echo "Aborting probe move" ;notify user ;M292 M568 P0 A1 ;set the extruder heater to standby
if global.bedLeveled == 0 G32 M98 P"probe.g" X525 Y250 echo >"heightmap.csv" "Height map file generated at", state.time echo >>"heightmap.csv" "xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum" echo >>"heightmap.csv" global.xMin,",",global.xMax,",",global.yMin,",",global.yMax, ", -1 ,",global.xSpacing,",",global.ySpacing,",",global.xNum,",",global.yNum var y = global.yMin var i = 0 G90 while var.i < global.yNum var x = global.xMin var j = 0 while var.j < global.xNum M98 P"probe.g" X{var.x} Y{var.y} S-1 M400 if var.j == 0 set global.meshLine = sensors.probes[0].lastStopHeight - sensors.probes[0].triggerHeight else set global.meshLine = global.meshLine ^ "," ^ sensors.probes[0].lastStopHeight - sensors.probes[0].triggerHeight set var.x = var.x + global.xSpacing set var.j = var.j + 1 echo >>"heightmap.csv" global.meshLine set var.y = var.y + global.ySpacing set var.i = var.i + 1
