    Duet 3 Tool Board not resetting?
    toolboard reset duet3 6hc
    • hekiundefined
      heki
      Hi all,
      I've recently gotten a Duet 3 Tool Board and it seems like when I power it on using 18V power supply, the status LED blinks in red, indicating it is running but not connected to the motherboard. However, when I try to reset it by pressing button 0 and button 1 during power on, the red light keeps blinking without showing any signs that it is resetting. Is it the board being faulty?
      Thank you!
        dc42 administrators @heki
        @heki see https://duet3d.dozuki.com/Wiki/CAN_connection#Section_LED_behaviour_and_error_codes for what the flashing LED signifies.
        hekiundefined 1 Reply Last reply Reply Quote 0
        • hekiundefined
          heki @dc42
          @dc42 Thanks for the reply, I figured because the LED is continuously blinking, the "board is running but does not have CAN communication with the main board". But shouldn't it momentarily stop blinking when it's being reset?
            @heki said in Duet 3 Tool Board not resetting?:
            To reset the board to default settings, have to power up the board while holding both buttons down.
            When you power up a Duet system, the LED on the tool board should blink rapidly at first, then slow down to match the blinking on the main board.
