Extruder Driver 1 Won't turn a motor
I'm having some issues with my Duet Wifi. I've added a second extruder, and for whatever reason the second extruder driver motor won't turn. It is a brand new Bondtech LGX if that makes any difference. Maybe someone can take a look at my config and tell me what I'm missing?
G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M564 H0 ; Allow movement without homing M669 K1 ; CoreXY mode ; Axis and motor configuration M584 X0 Y1 Z5:6:7 C2 E3:4:8:9 ; Map Z to drivers 5, 6, 7. Define unused drivers 3,4,8 and 9 as extruders M569 P0 S0 ; Drive 0 goes forwards X stepper (Rear) M569 P1 S1 ; Drive 1 goes forwards Y stepper (Front) M569 P2 S1 ; Drive 2 goes backwards Coupler M569 P3 S0 ; Drive 3 goes forwards Extruder M569 P4 S1 ; Drive 4 goes backwards Extruder 2 M569 P5 S0 ; Drive 5 goes forwards Front Left Z M569 P6 S0 ; Drive 6 goes forwards Rear Left Z M569 P7 S0 ; Drive 7 goes forwards Right Z ;Stall Detection - Used for homing M915 C S5 F0 H200 ; Coupler M915 X Y S5 F0 H400 ; X / Y Axes ;Leadscrew locations M671 X-50.0:-51.44:301.23 Y31.4:284.9:156.9 S7.5 ;Front left, Rear Left, Right S7.5 is the max correction - measure your own offsets, to the bolt for the yoke of each leadscrew M350 C8 I0 M350 X16 Y16 Z16 E16 I1 ; set 16x microstepping for axes& extruder, with interpolation M574 X1 Y1 S3 ; Set X / Y endstop stall detection M906 X1400 Y1400 Z1000 C400 E1000:600 I60 ; Set motor currents (mA) M201 X3000 Y3000 Z100 C400 E1500:1500 ; Accelerations (mm/s^2) M203 X24000 Y24000 Z900 C5000 E3600:3600 ; Maximum speeds (mm/min) M566 X1000 Y1000 Z100 C2 E1500:1500 ; Maximum jerk speeds mm/minute M208 X-42:340 Y-20:320 Z-0.5:700 C0:260 ; set axis maxima and high homing switch positions (adjust to suit your machine) M92 X200 Y200 Z1600 C100 E402:400 ; steps/mm (E409 is Hemera standard), (E400 is standard for LGX) ; Fans M950 F0 C"fan0" ;_RRF3_ define fan0 M950 F1 C"fan1" ;_RRF3_ define fan1 M950 F2 C"fan2" ;_RRF3_ define fan2 M106 P0 H-1 ; disable thermostatic mode for fan 0 M106 P1 H-1 ; disable thermostatic mode for fan 1 M106 P2 H-1 M106 P0 S0 ; turn off fans M106 P1 S0 M106 P2 S0 ; Tool definitions M563 P0 S"Hotend1" D0 H1 ; Define tool 0 G10 P0 X44 Y-21.4 Z-6.03 ; Tool offsets for tool 0 ; Previous values: G10 P0 X44 Y-21.4 Z-5.63, moved up 0.4mm for PLA first layer G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures M563 P1 S"Hotend2" D2 H2 ; Define tool 1 G10 P1 X44 Y-21.4 Z-25.82 ; Tool offsets for tool 1 G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures ; Thermistors M308 S0 P"bedtemp" Y"thermistor" A"bed_heat" T100000 B3950 R4700 H0 L0 ;_RRF3_ Bed thermistor, connected to bedtemp on Duet2 M950 H0 C"bedheat" T0 ;_RRF3_ define Bed heater is on bedheat M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C ;If you have a Slice Engineering thermistor, comment out the next line M308 S1 P"e0temp" Y"thermistor" T100000 B4725 R4700 C7.06e-8 H0 L0 ;_RRF3_ duet3 e3d M950 H1 C"e0heat" T1 ;_RRF3_ define Hotend heater is on e0heat M143 H1 S300 ; set temperature limit for heater 1 to 300C M308 S2 P"e1temp" Y"thermistor" T100000 B4725 R4700 C7.06e-8 H0 L0 ;_RRF3_ duet3 e3d M950 H2 C"e1heat" T2 ;_RRF3_ define Hotend heater is on e1heat M143 H2 S300 ; set temperature limit for heater 1 to 300C M307 H0 R0.231 C1029.2 D42.03 S1.00 V24.1 ; Bed Heaters M307 H1 R2.909 C173.8 D5.37 S1.00 V24.1 ; Heater 1 model M307 H2 R2.909 C173.8 D5.37 S1.00 V24.1 ; Heater 2 model M570 S360 ; Hot end may be a little slow to heat up so allow it 180 seconds M143 S285 ; Z probe and compensation definition M558 P8 C"^zprobe.in" H10 F100 T3000 ; Z probe is an IR probe and is not used for homing any axes G31 X0 Y0 Z0 P500 ; Set the zprobe height and threshold (put your own values here) M501 ; run config-override.g T-1 ; select no hot end
@makestuffmakestuff said in Extruder Driver 1 Won't turn a motor:
You map first the axis and after that you configure the drivers move the M584 command to line 18
@siam said in Extruder Driver 1 Won't turn a motor:
Unfortunately that isn't the problem. I tried it just to be sure, but it didn't change anything.
Side note, if I swap the extruder cables for E0 and E1, I can get both of them to run, however the motor running on E1 seems weak. Potentially a driver issue? That would be weird though as this driver was used successfully for quite a long time as a Y axis motor driver due to motor cable length problems.
@makestuffmakestuff A few things to note.
When you map extruders using M584 like you have here...........
.....then whichever motor you have connected to E3 will become extruder 0, and whichever motor you have mapped to E4 will become extruder 1, etc.
So your first tool definition....
.........will use extruder D0 which is the one connected defined as E3.
Your second tool definition......
.....will use extruder number 2 as defined in your M584, this would be whatever is connected to E8.
So if you only have 2 extruders, then the second tool definition should be
M563 P1 S"Hotend2" D1 H2 (not D2)
One other little thing. You ought really define the micro stepping for both extruders in M350 using a colon separator so instead of....
...use .....
M350 X16 Y16 Z16 E16:16 I1
It probably defaults to 16 so it might not matter but it's generally best practice to explicitly define these things.
@deckingman said in Extruder Driver 1 Won't turn a motor:
M563 P1 S"Hotend2" D1 H2 (not D2)This was exactly the problem. I knew it was going to be something simple like that, I just stared at the problem long enough that I couldn't see it. Thanks for your help!
