    External stepper setup and config
    912
    • Exerqtorundefined
      Exerqtor
      I'm currently derping around trying to configure a Fysetc TMC2100 v1.3 stepper driver that i've connected with a external stepper driver board, but i'm a little confused when it comes to how i should run "CFG3". Or to be more precise, what does really having the current as "int"(guessing that stands for internal?) mean as supposed to "ext"(external?). I've already adjusted the VREF on the stick and everything is hooked up and ready to go other than that pesky "CFG3". Link to the product wiki (btw i'm using the stepstick to run my extruder, so i guess 1/16 spreadCycle is the best way to go?)
      And while at it this should cover everything needed for this stepper driver when it comes to config.g right (since it's external) ?
      ; Drive for extruder
      M569 P5 S0						; E (physical drive 5) goes backwards
      ; Motor mapping and steps per mm
      M584 X4 Y3 Z0:1:2 E5					; set drive mapping
      M92 E430.11						; set Extruder steps per mm (BMG)
      ; Drive currents
      M906 I30						; set ide current percentage
      M84 S30							; Set idle timeout
      Or is it something i'm missing?
      Duet 2 Wifi v1.03 running on RRF 3.4.0 b6 bundle, Fysetc TMC2100 stepper, Stepperonline 17HS08-100S4 stepper running on 12V, stepstick VREF adjusted to 1.41V.
      Exerqtorundefined 1 Reply Last reply Reply Quote 0
      • Exerqtorundefined Exerqtor marked this topic as a question
      • Exerqtorundefined
        Exerqtor @Exerqtor
        So no apparently i'm missing something here. I now run CFG1, CFG2 and CFG3 to VIO (1/16 spreadCycle with internal current regulation) and the above mentioned config. But this ends with both the motor and driver getting hot AF. And the fan on the powersupply ramping up because it's under constant load. But if i try to run the stepper (cold extrusions allowed ofc) nothing happens.
        So, help is indeed needed😥
        • Exerqtorundefined
          Exerqtor @Exerqtor
          Should i configure the microstepping etc. with M350 despite it being determined by CFG1/CFG2 on the stepstick itself?
          Really at a full loss here, i've gone over the wiring countless times now and it's all good so it has to be something with the config..
            I'm not very failiar with the external driver setup myself, but have you seen this example in the wiki for 2130?
            https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers#Section_TMC2130_Example
            • Exerqtorundefined
              Exerqtor @Phaedrux
              @phaedrux
              Yeah I've looked at it, but it don't really bring any clarity. As far as it goes for the CFG1,2 & 3 stuff i 'm pretty sure i have that setup the right way now (unless i've totally missunderstood something).
              So i'm convinced it must be firmware configuration related, i've tried to see if it's something in the datasheet from Trinamic that might point me in the right direction but i can't see anything of interest there either.
                Can you post your current full config?
                https://duet3d.dozuki.com/Wiki/Duet_Expansion_Breakout_Board#Section_RepRapFirmware_1_21_onwards_2_x_3_x
                • Exerqtorundefined
                  Exerqtor @Phaedrux
                  @phaedrux
                  M111 S0                 						; debugging off
                  G21									; work in millimetres
                  G90									; send absolute coordinates...
                  M83									; set extruder to relative mode
                  M575 P1 B57600 S1							; enable and configure PanelDue
                  ; General setup
                  M669 K1	X-1:-1:0 Y1:-1:0 Z0:0:1						; select CoreXY mode and set kinematics matrix
                  M550 P"Voron Trident"							; set printer name
                  M552 S1									; enable network
                  M586 P0 S1								; enable HTTP (for DWC)
                  M586 P1 S1								; enable FTP (for remote backups)
                  M586 P2 S0								; disable Telnet
                  ; --- Z drive map ---
                  ;    _______
                  ;   |   0   |
                  ;   | 2 | 1 |
                  ;     front
                  ; Drives for Z
                  M569 P0 S0								; Z1 (physical drive 0) goes backwards
                  M569 P1 S0								; Z2 (physical drive 1) goes backwards
                  M569 P2 S0								; Z3 (physical drive 2) goes backwards
                  ; Drives for XY
                  M569 P3 S0								; X (physical drive 3) goes backwards
                  M569 P4 S0								; Y (physical drive 4) goes backwards
                  M569 P5 S0 R1								; E (physical drive 5) goes backwards with enable polarity active high
                  M350 X16 Y16 Z16:16 E16 I1						; configure microstepping with interpolation
                  M92 X80.00 Y80.00 Z400.00:400.00:400.00					; set XYZ steps per mm (1.8deg motors)
                  ; Drive currents
                  M906 X1400 Y1400 Z1200:1200:1200					; set XYZ motor currents (mA)
                  M84 S30									; set idle timeout
                  ; Accelerations and speed
                  M98 P"/macros/System/Speed/speed_printing.g"				; set normal speed & accel
                  M208 X0 Y0 Z0 S1							; set axis minima
                  M208 X350 Y358 Z300 S0							; set axis maxima
                  M574 X2 S1 P"xstop"							; configure active-low endstop for low end on X via pin xstop
                  M574 Y2 S1 P"ystop"							; configure active-low endstop for low end on Y via pin ystop
                  M574 Z0 P"nil"								; no endstop
                  ; Z microswitch (nozzle probe)
                  M558 K1 P8 C"zstop" I1 H2 F400:100 T18000 A10 S0.01 R0.1		; set Z probe type to switch and the dive height + speeds
                  G31 K1 P500 X0 Y0 Z0.00							; set Z probe trigger value, offset and trigger height (higher Z value = nozzle closer to bed)
                  ; Z-probe (klicky probe)
                  M558 K0 P8 C"^zprobe.in" H8 F400:100 T10000 A5 S0.01 R0.1		; set Z probe type to switch and the dive height + speeds
                  G31 K0 P500 X0 Y21 Z6.42						; set Z probe trigger value, offset and trigger height (higher Z value = nozzle closer to bed)
                  ; Bed leveling
                  M671 X175:388:-38 Y416.6:1.5:1.5 S10					; leadscrew locations (Rear, Right, Left)
                  M557 X25:315 Y25:325 P5:5						; define mesh grid ( positions include the Z offset!)
                  ; Bed heater
                  M308 S0 P"bedtemp" Y"thermistor" T104400 B4138 A"Bed" 			; configure sensor 0 as thermistor on pin bedtemp
                  M950 H0 C"bedheat" T0							; create bed heater output on bedheat and map it to sensor 0
                  M307 H0 B0 S1.00							; disable bang-bang mode for the bed heater and set PWM limit
                  M140 H0									; map heated bed to heater 0
                  M143 H0 S110								; set temperature limit for heater 0 to 110C
                  M143 H0 A2 C0 S110							; make sure bed heater stays below 110°C
                  M143 H0 A1 C0 S125							; make sure bed heater shuts down at 125°C
                  ; Hodend heater
                  M308 S1 P"spi.cs1" Y"rtd-max31865" A"Hotend"				; configure sensor 1 as thermocouple via CS pin spi.cs1
                  M950 H1 C"e0heat" T1							; create nozzle heater output on e0heat and map it to sensor 1
                  M307 H1 B0 S1.00							; disable bang-bang mode for heater  and set PWM limit
                  ; Chamber temperature sensor
                  M308 S4 P"e1temp" Y"thermistor" T9600 B3950 A"Chamber"			; configure sensor 4 as thermistor on pin e1temp
                  M950 F0 C"fan0" Q100							; create fan 0 on pin fan0 and set its frequency
                  M106 P0 S0 H-1 C"Part Cooling"						; set fan 0 value. Thermostatic control is turned off
                  M950 F1 C"fan1" Q100							; create fan 1 on pin fan1 and set its frequency
                  M106 P1 S1 H1 T45							; Mosquito Hotend fan @ 100%, turns on if temperature sensor 1 reaches 45 degrees
                  M950 F2 C"fan2" Q100							; create fan 2 on pin fan2 and set its frequency
                  M106 P2 H2:3 L0.15 X1 B0.3 T40:70					; Set fan 2 value, Electronics cooling, starts to turn on when the MCU temperature (H100) reaches 45C and reaches full speed when the MCU temperature reaches 65C or if any TMC2660 drivers (H101 & H102) report that they are over-temperature. Thermostatic control is turned on
                  M563 P0 S"Mosquito" D0 H1 F0						; define tool 0
                  G10 P0 X0 Y0 Z0								; set tool 0 axis offsets
                  G10 P0 R0 S0								; set initial tool 0 active and standby temperatures to 0C
                  ; Custom settings
                  M308 S2 Y"mcu-temp" A"MCU"						; configure sensor 100 as mcu temperature
                  M308 S3 Y"drivers" A"DRIVERS"						; configure sensor 101 as drivers temperature
                  M950 P2 C"e1heat"							; create output port 2 attached to e1heat connector for LED lights
                  M591 D0 P1 C"e0stop" S0							; filament monitor for extruder0, simple sensor (high signal when filament present), connected to e0stop and it's disabled
                  M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"			; set voltage thresholds and actions to run on power loss
                  M912 P0 S-2.9								; MCU temp calibration parameters
                  M572 D0 S0.0								; Disable Pressure Advance
                  M98 P"/macros/System/Current/xy_current_high.g"				; set normal xy currents
                  M98 P"/macros/System/Current/z_current_high.g"				; set normal z currents
                  M98 P"/macros/System/fw_retraction.g"					; set firmware retraction settings
                  M501									; load config-override.g
                  T0									; select tool 0
                    @exerqtor said in External stepper setup and config:
                    M569 P5 S0 R1
                    I think you'll need to specify more for the M569 for external driver. The timing etc.
                    https://duet3d.dozuki.com/Wiki/M569
                    • Exerqtorundefined
                      Exerqtor @Phaedrux
                      @phaedrux
                      I tried doing that too (adding the same line as in that example since i couldn't find or didn't understand where to find the timings correct for the TMC2100. ), but it didn't change anything. I've also tried changing out the enable state, but that don't solve anything either.😥
                      What worries me the most is that the stepper gets so darn hot, like it's to the level where it smells like hot electronics and is unpleasant to touch (once i've powered down the printer) the stepper motor also gets hot.
                        I'm surprised by the heat as well. What did you set the vref to? I wonder if it's been damaged...
                        • Exerqtorundefined
                          Exerqtor @Phaedrux
                          @phaedrux
                          Vref is set too 1.41V should be the right amount for the stepper, and within spec for the stepper driver 🤔
                            If you reduce it does the driver get less hot?
                            • Exerqtorundefined
                              Exerqtor @Phaedrux
                              @phaedrux
                              Haven't done it yet, been preoccupied with trying to find out why it won't respond / make the stepper move thinking it could be the same issue causing both issues 😬
                              • Exerqtorundefined
                                Exerqtor
                                Ok so now i've had the chance to have another lool at things, and the steppstick only gets hot if the stepper is connected.
                                So just so the hivemind agree with me, this is wired correctly right? I've ohmed between the connector to verify that the a windings on the stepper indeed are the two center pins on the connector btw.
                                EDIT:
                                Read thru the stepstick product wiki again and apparently they name the motor windings back asswords compared to eachother on the stepper and stepstick 🤢
                                Or i just straight up missundeestood it the whole time😶 lets re-pin and see if that yields any better results, if the stepstick ain't allready fubar at this point 😒
                                • Exerqtorundefined
                                  Exerqtor @Exerqtor
                                  So yeah now rewired to this alt text
                                  And with this config:
                                  M569 P5 S0 R1 T2.5:2.5:5:0
                                  It says "CFG6_ENN - Enable input (high to disable) and power down configuration" in Trinamics datasheet for the TMC2100, so that means "M569 R1" is the right choice i guess (Rnnn - Driver enable polarity: 0 = active low, 1 = active high) ?
                                  I can hear the stepper do a faint highpitched whine when i try to run my filamanet load macro, and it stops when the macro is done.
                                  Don't know if that's a good sign or not. But i'm also a little bit unsure if i should have defined the microstepping for the extruder in config or not as well? So the MCU know how to send the pulses?
                                  Must be someone here that know whats the correct way of configuring this? Because it's srsly not clear in any documentation i've managed to find as of now 😥
                                  • o_lampeundefined
                                    o_lampe @Exerqtor
                                    @exerqtor
                                    From my understanding it should be M569 R0
                                    You can't set M350 microsteps but need to calculate the M92 value accordingly. ( eg. 430.11 x 16 )
                                    • Exerqtorundefined
                                      Exerqtor @o_lampe
                                      @o_lampe
                                      Yup that's totally correct! 😅
                                      __
                                      So i finally got it working, and the issue is so embarrasing i don't even know if i want to say it 😶
                                      Turns out i had managed to bork up the DIR,STP & EN pins totally on the breakout board, haven't got any excuse for how i even managed doing that wrong. The mind boggles 😬
                                      Now it's a matter of finding the heatsink belonging to the stepstick and slap it on before i calibrate esteps and do a test print 🙄
                                      Exerqtorundefined 1 Reply Last reply Reply Quote 1
                                      • Exerqtorundefined Exerqtor has marked this topic as solved
                                      • Exerqtorundefined
                                        Exerqtor @Exerqtor
                                        @exerqtor
                                        Still having some "slight" issues with the stepper running hot, turns out it's a relatively commonly know thing the TMC2100's run VERY HOT. And it's even to det point where they suggest not going over 0.9V vref on a 1A stepper because of it and also having to run a heatsink with a fan to cool the bastard.
                                        I actually think it's getting so hot now with 1.41V and no active cooling that it's shutting down due to the built in protection that shuts it down at 150C and wakes it back up at 120C. So there's that, it's at least turning the stepper so that's a step in the right direction (badumtss🙄 ).
                                        Gonna slap together a 4010 fan mount for the breakout board in CAD now and print it. Then adjust the vref to 0.9V and see if that solves it 🤕
                                        EDIT:
                                        Let's hope this works, despite looking stupid as hell:
                                        EDIT 2:
                                        So that stupid looking fan cooling together with lowering vref to 0.90V solved the steppstick overheating (woho🥳).
                                        BUT the stepper motor still gets hot even tho it should have been disabled (if my config is right) , not so hot that it's melting the printed parts (CPE) it's attached to but over 60C if i should guess. So i'm a little sceptical if it's getting disabled by the duet 🤔
                                        • o_lampeundefined
                                          o_lampe @Exerqtor
                                          Glad to hear it's running (basically). Now you can use a more recent driver like TMC2209 or even TMC5160
                                          I have the same effect on my BTT-M5 adaption
                                          At first I confused the E#_EN pins from the expansion port with the enable pins for the driver, (but they seem to be chip select pins for SPI comms)
                                          Then I tried the ENN-pin on the expansion port, but no matter how I configure it, it is always LOW = enabled...
                                          • Exerqtorundefined
                                            Exerqtor @o_lampe
                                            @o_lampe said in External stepper setup and config:
                                            Thanks, me to despite not being totally haooy with the result yet.
                                            Yeah I started looking into mayve trying out some other driver yesterday. But i haven't come to any conclusions yet, like it's for the extruder so i want it to be reliable etc.
                                            Whats the "best supported" stepper to use with a duet/rrf 3? It would be hella sweet to have some or all the setting abilities as with the onboard drivers 😅
                                            I'm trying to think out some way i can get the driver to turn off now, i've just unplugged the enable pin totally now an use the built in "auto current reduction" of the 2100. But if i had some way of automagically applying VCC-IO to the enable pin when i want the driver disabled it would work good i think. And just leave it open when i'm printing and let the driver do the idle/enable handling itself.
