    InputShaping-Plugin-0.2.0-pre8 released
    Plugins for DWC and DSF
    1
    1
    1.0k
    • mfs12undefined
      mfs12
      This release contains only comsetic changes.
      release notes for inputshaping plugin 0.2.0-pre8
      This work is based on the original acceleration plugin. Input shaping plugin tries to take
      the input shaping calibration to a next level.
      The current state is still EXPERIMENTAL!!!
      Although it's experimental it brings already some handy features which is why i
      am doing this release. Therefore please comment, give feedback, report bugs and share your
      ideas.
      requirements
      • Duet Web Control 3.4.0-b6
      • RepRap Firmware 3.4.0-b6
      features
      • restructure plugin to use vue components
      • added test configuration component
      • added recorder component
      • added chart component
      • use object model to determine status of test
      • added add/delete of algorithm configurations
      • added add/delete/select of records
      • added add/delete/select of sessions
      • display test parameters in chart component
      • allow records with differing samples rates of up to 1%
      • cleaned up debugging output
      • added localization
      • home device only if not homed
      • improved ui layout
      • added component to manage multiple sessions
      • added more parameter validation for test and algorithm
      • disable tab record tab when no algorithms defined
      • disable tab chart when no records available
      • improved error reporting
      • localized date-timestamps
      • added integrals for each axis
      • skip algorithm test which already have test record (speed improvement, easier understanding)
      • improved editing note in configuration tab
      • cleaned input fields (ids or not editable but only names)
      • added recommendation support
      • make deletion of accelerometer files configurable
      • added tool offset to suggest start/stop position
      • display overflows in analysis' table
      bugs
      • fixed initial filtering of records by axis
      • fixed session cleanup when session is deleted
      • fixed data handling when swapping sessions
      • fixed can address handling (needs more testing)
      • fixed record integrity when referenced algorithm is changed
      • fixed CAN address handling when address is null
      • fixed one-time homing for some machines
      • fixed labeling of chart axes
      • fixed chart's freq/time status handling
      known issues
      • parameter validation doesn't cover every situation
      downloads
      • https://github.com/mfs12/DuetWebControl/releases/tag/inputshaping-plugin-0.2.0-pre8
      howto
      prerequisites
      • select a tool
      • home printer
      • bring axes into initial positions, especially important for not tested axes
      initialize session
      • switch to tab "initialize"
      • create a new session or
      • select an available session
      configure session
      • switch to tab "configure"
      • configure your session session
      • configure test parameters
      • add as many input shaping algorithm configurations as you like
        • more than one per algorithm are allowed
        • this is good to compare different input shaping configuration of the same algorithm
      • CAUTION: once a record in a session exists test parameters can't be changed anymore.
      record profiles
      • switch to tab "record profiles"
      • press "run" button and wait until recording is done
      frequency analysis
      • switch to tab "frequency analysis"
      • in "acceleration records" section you see a list of profiles recorded
        • clicking on the entry DELETEs it form the session!!! (it is lost!!!)
      • in "filter" section the show/hidden graphs are displayed
        • un-checking an axis will hide or show all charts of an axis group
      • in chart section
        • individual graphs can be shown or hidden by pressing the colour next to the name
      • press "FFT" button to show FFT representation of the graph
      • press "Time" button to show time representation of the graph
      recommendations
      • switch to tab "recommend"
      • select a record of type "none" from the first table
      • run recommendations, thism might take a while...
      • sort second table with recommendations by integral
      • ideally the record with the smallest integral should be provide the best configuration
      • add configuration to session
      • switch to tab "configure" to review added configurations
        • see section "configure session"
      limitations
      • currently no data is stored permanently!!!
      • everything is volatile so avoid hitting browser's reload
      what's next?
      Potential next steps are
      • store session in a local file or in browser's local storage or
      • load session from local file or browser's local storage
      • recommend input shaping parameters
      • improve input validation
      • add translations
      Visit me on github at https://github.com/mfs12/
      • oliofundefined oliof referenced this topic
      • T3P3Tonyundefined T3P3Tony referenced this topic
