Haydn Huntley’s Magball delta arms
I would like to get some Haydn Huntley’s Magball delta arms of 450mm/500mm for a delta of 500mm horizontal extrusion and 1200mm vertical.
I do not know how to get in touch with Haydn Huntley´s.Wiki link is not a page to shop.
You could make the arms thicker for those dimensions?
Would these arms be correct for those printer splices considering that I need at least 300mm in bed?
Thank you -
Try posting in the following thread https://groups.google.com/forum/#!topic/deltabot/485cfVFrFFU%5B526-550%5D
thank you very much, Dougal1957.
Or email him directly at haydn.huntley@gmail.com
fwiw I am using 360mm rods on a 300mm bed, if you're around 300mm diameter bed wise, you're way overshooting arm length required.
mine is 500 horizontals with a 360mm Diam bed and my arms are 450 long from haydn and they are about right could possibly have got away with 440 but I would rather go slightly longer than short
Dougal, were your arms made with the 6mm O.D. rods or does he offer larger diameter for that length?
He can do 10mm Carbon mine are 6 (in fact there just under) but are stiff enough.
The 100mm puts quite a price hike and he also has to but it in specially I believe.
